#62 (permalink) |
There are lots of ways it could have been resolved. I took the high road and called them directly but they found every reason or excuse to bail on me after spending 700 bucks... Since I placed the calls there would not be any emails except for the ones they never responded to. As far as the exhaust fitment they make a front pipe that works on stock cars and a optional pipe that only works with the turbo kit. they sent me the wrong pipe which is stainless, bent, flanged, and expensive to duplicate. Im not expecting everyone to agree with my opinion but if anyone wants to debate a bad experience with AJP they should also debate any positive posts to keep things equal.
#66 (permalink) |
Still dropping trout
![]() Join Date: Jun 2006
Justin Credible.
Wow, first time I've read this:
akinaspeedstars1 has a blown head gasket ![]() *the mouse over message for having negative rep* Anyways, I'm suprised that ajp was so unwilling to work with you man. There was initially a problem with esx005's intercooler when it was being installed.. ajp was called and they promptly said they would send a new intercooler to replace it. From being around him throughout this whole ordeal I would say that IMO they take waaaaaaaaaaaaay too long to ship out parts. To be fair I wasn't the one talking to them though so idk.. |
#67 (permalink) | |
FG*SQUAD #87
Money: AJP>Full Race Quality: Full Race>AJP so basically you get what you pay for... if you want to half ass it and have a |
#69 (permalink) | |
Justin Credible.
I've said it before and I'll say it again, with exception of a lack of tunable engine mangement the ajp kit really is a good kit. Is it pretty? No, not at all. But 3 shops in the dfw area alone (that's just that I've spoken with) have said that the welds look solid. I also haven't heard of a single person blowing their motor because of a kit itself, with exception of bad installation and that was a comptech s/c kit. I've heard of no cracked manifolds either.. The only other thing that bothers me about the ajp kit is the fact that it's so fickle with its placement. If everything isn't just right then it will have some sort of problem from what I've read on here. The running so rich at idle that it smokes would be a huge problem to a lot of people, but I would rather run really rich than run lean as hell and see detonation in my near future. :shrugs: Plus, that goes away with some sort of e-manage or k-pro and a good tune. Luckily Jeremy happens to live about 4-5 hours away from st00pidfast so a good shop to have his car tuned at isn't really out of reach. |
#70 (permalink) |
![]() Join Date: Jan 2006
Marvie
on the 3" exhaust ordeal ...
i have no idea what was said or done ... but what i usually tell people is ... before u buy anything do the research urself .... u can't expect a 3" exhaust to simply bolt up to the stock piping because it's not the same diameter ... it's kinda obvious that some sought of modification would have to be made ... the majority of the people on here i've seen have either asked for a smaller flange but even that won't be enough as u'd need some sought of reducer to reduce the diameter before the flange can be used ... now some probably don't know that and would just to buy the exhaust ... then u get it and u stuck and find out u have to do the modifications ... some companies will help u out ... and some won't ... i guess AJP left u on ur own to deal with it ... which imo is not good ... yes they should let u know it won't bolt on to the stock cat side ... but the question is did u even inquire before buying ... if u did and they said it would and it didn't then that's a whole different ball game .... but if u didn't and bought the thing without knowing anything then ur lack of knowledge hurt you ... either way IMO they should have tried to help ... but either way u'd have to pay the money to get the extra parts u needed and to have the work done... from all the pics i've seen of that exhaust it seems as if the piping is longer so u cut accordingly and it doesn't come with a flange at the cat site ... i may be wrong though.
#71 (permalink) |
Communication also seems to be a problem. I sent my orignial downpipe to them for a core and paid them to build a new downpipe. Here are the specifications that I provided to Ben moving from the turbine housing to where the downpipe connects to the midpipe (3" piping from end to end):
First part: 1) V-band flange for the turbine housing to downpipe connection. 2) After the 90 degree bend on the downpipe, I wanted a flex joint to be welded somewhere inline along with an bung for the stock O2 sensor. 3) V-band flange to connect to the second part. Second Part: 1) V-band flange to connect to the first part. 2) 3" Random Technologies cat. 3) V-band flange to connect to the third part. Third part: 1) V-band flange to connect to the second part. 2) Bung in for the other stock O2 sensor. 3) Three bolt flange to connect to the midpipe. For the second part, I also said that I wanted a test pipe of the same size (so I could easily remove the cat when at the track). I also asked for another O2 bung to be welded somewhere so that I could connect my wideband O2 sensor. Ben communicated this information to Toni and he went to work. I had no further communications with them until the part arrived. I opened the box and the part was not built to the specification that I had requested and paid for. Here were the problems: 1) The first part in the above list did not have the flex joint incorporated. 2) The second part in the above list was fine. 3) The third part in the above list was fine however, they added the bung for the wideband O2 sensor. I don't know why this location was chosen since the wideband O2 sensor should be connected before the cat. As you can see from the above list, there is one part still missing (i.e., the flex joint). It turns out that the flex joint was welded into the test pipe that was made. So what this means is if I want to use the cat, the assembly will not have a flex joint. If I want to use the flex joint, then I cannot use the cat. I called and spoke to Toni about the problem and described the way that I wanted the part configured as in the first list in this post. His response was, "Ben did not tell me that was how you wanted the part made." I said that I was clear about what I wanted when I spoke to Ben and if there were any questions, they should have called or sent me an email to ask (for example, if I used the downpipe with the cat, I would not have the flex joint...When the part was being built, that should have raised a flag of concern). I then asked what they were going to do in order to correct the error since it was a miscommunication between Ben and Toni. Toni's response was that he would have to get back to me as to how much more it would cost to build the part as requested. At that point, I said that the error was not my fault and I should not be the one having to pay for the mistake. He held his position, I eventually just hung up and have not spoken to them since. |
#72 (permalink) |
Marvie
agree with u ..... 105% but ... like i've told some people on here ... if u can ... speak to Tony and only Tony about whatever problem/problems you may have ... toni = FIAT on here i've been seeing a lot of "I spoke to Ben" ... and what i gather is "I spoke to Ben" = some **** is not done/not right/no help ... etc ... i know Tony is a busy busy guy in the shop ... but if one can have patience and see to it that they speak with him only... a lot of stuff can be avoided ... cuz he makes and knows about all the stuff... he's the one guy i'd always talk to.
#73 (permalink) | |
It is not my responsibility as a customer to know who I should or should not speak with at the company when placing an order. If someone calls AJP to place an order, it is the responsibility of the worker that answered the phone to get it right since they are a representative of the company. If the representative screws up, management should correct the issue so that the company as a whole does not look bad. If Toni is the only person that can do it right, then he should be the only one answering the phone. I became upset since they were reluctant to do the right thing. Now I am going to have to pay someone else to fix what they should have gotten right the first time. |
#75 (permalink) |
Marvie
ron's back in town...
see if u can talk to him ... but again i agree with you .... someone should be held accountable ....
#76 (permalink) | |
After I received the part, I called and spoke to Ben briefly. He then transferred me to Toni where we spoke for about five minutes. Toni was not willing to change his postion at all. So in the end, if I wanted the part fixed I would have one of two choices: 1) Pay AJP to fix it as well as shipping charges; or 2) Take it to my local shop where I won't have to pay them until the work is completed and I can verify that it is correct. |
#77 (permalink) | |
#78 (permalink) |
Marvie
well ...
just trying to help ... but word of advice is always talk to tony ... don't depend on anyone to get the message to him or whatever ... most of the time he's usally pissed that he messed up on something because somebody didn't relay the correct info. to him ... atleast that's what i've seen sometimes when i'm there... just my 2c.
#79 (permalink) | |
#80 (permalink) | |
*All Motor Beast*
LinkBack to this Thread: http://www.8thcivic.com/forums/forced-induction-nitrous/35647-what-wrong-ajp.html
| What is wrong with AJP? - Page 10 - 8th Generation Honda Civic Forum | This thread | Refback | 01-18-2008 10:04 PM | |
| K2 fogs..I think I have the wrong harness? | grcivicsi06 | Lighting, H.I.D.'s, & Neon | 4 | 04-04-2007 05:25 PM |
| ajp kit n greddy exhaust? | futhermucker | Turbocharging | 9 | 12-26-2006 06:39 PM |
