Ajp owners help!! - 8th Generation Honda Civic Forum
Old 03-21-2007, 10:24 PM   #1 (permalink)
06Si_LoveR's Avatar
Ajp owners help!!
So I go to change my oil filter today for the first time... And I vaguely remember someone saying that you don't have to disconnect the downpipe to remove the oil filter... Well I guess every install that AJP does is not the same because my the first thing I noticed was that my oil filter had a small indentions in it from where the downpipe had been rubbing against it... needless to say, they were about 10 mm apart... So the first thing I was thinking was that this isn't gunna work... Well it didn't :Mad: Anyone who has done this please shed some light
06Si_LoveR is offline
Old 03-21-2007, 10:29 PM   #2 (permalink)
Did AJP install your kit?
The downpipe should be no where near the oil filter. It sounds like you are referring to the dump tube coming off of the wastegate. Can you take and post a PIC showing the clearance around the oil filter?
blue1 is offline   Reply With Quote
Old 03-21-2007, 10:38 PM   #3 (permalink)
06Si_LoveR's Avatar
Naw the dupe tube is definitely not in the way... I sent you a pm with a pic... I maybe wrong... dunno if they changed something with my install or something... thought everyones was like mine...
And yes AJP installed my kit
06Si_LoveR is offline   Reply With Quote
Old 03-22-2007, 10:14 AM   #4 (permalink)
mikepesikan's Avatar
The guy who installed my kit told me I would have to remove the dump tupe to change the oil. Havent done it yet but soon.
mikepesikan is offline   Reply With Quote
Old 03-22-2007, 11:18 AM   #5 (permalink)
I received your PM..You provided a link to another thread where you posted PICs however, I did not see a PIC showing the downpipe and wastegate dumptube installed. Without seeing these parts installed, I can only guess that it is the dumptube that is very close to the oil filter.
Most of the kits AJP sold are the same unless you were an early bird like myself. The early kits used a Tial 38mm wastegate which was changed to a Tial 44mm wastegate shortly after the kit was released. Most people that have the kit received the 44mm wastegate. I ended up upgrading to the 44mm, but am waiting on the manifold and turbine housing to come back from being coated before I can reinstall the parts.
Old 03-22-2007, 11:29 AM   #6 (permalink)
06Si_LoveR's Avatar
I need a digital camera :Mad:
Old 03-22-2007, 11:40 AM   #7 (permalink)
06Si_LoveR's Avatar
Ok I just got off the phone with Ben... and he said I have to loosen the V-clamp on the downpipe... dunno why everyone else has to mess with the dumptube mine is no where near the oil filter... anyways my downpipe has to be slightly rotate upwards to remove the filter... trying to find a camera to post some pics... anyways thanks for all the help guys.
Old 03-22-2007, 12:44 PM   #8 (permalink)
Thanks for the update...If you have to loosen the V-band clamp on the downpipe to remove the oil filter, then you may want to look into getting a remote oil filter kit. That would make it easier to change down the road.
Old 04-12-2007, 11:04 AM   #9 (permalink)
As an update, I installed the turbo assembly and downpipe and can access the oil filter without having to remove anything. The bend in the downpipe is a little more than an inch away from the corner of the oil filter when installed. The wastegate dumptube is even further away from the filter.
Old 04-13-2007, 01:08 AM   #10 (permalink)
honda06si's Avatar
justin
^yea from the begining ive never had to take anything off to change my oil...ive done it about 5 times now
Old 04-13-2007, 03:03 PM   #11 (permalink)
Here is a PIC of mine showing the clearance near the oil filter connection:
Old 04-16-2007, 04:35 PM   #12 (permalink)
06Si_LoveR's Avatar
I don't see your oil filter in that pic
I will be chaning my oil tomorrow and I will take pics...
Old 04-16-2007, 05:31 PM   #13 (permalink)
Hehe...That's because it is not there. I'll take and post a better PIC of it installed.
Old 04-17-2007, 10:07 PM   #14 (permalink)
06Si_LoveR's Avatar
Haha thought so... awaiting the pics
Old 04-17-2007, 10:08 PM   #15 (permalink)
06Si_LoveR's Avatar
Just finished chaning my oil and sparks... boy does she run good with em fresh took some pics on my cousins camera should have everything up by tomorrow
Old 04-17-2007, 10:28 PM   #16 (permalink)
Sorry about that...I'll try to remember to post a PIC tomorrow.
Old 04-18-2007, 11:32 PM   #17 (permalink)
06Si_LoveR's Avatar
Well here are the pics of my downpipe in relation to the oil filter... as you can see its virtually impossible to get that thing off w/o rotating the downpipe... only a couple of mm between the two
And heres a pic showing just how hard it is to access that V-clamp... for once its good to be skinny
Old 04-18-2007, 11:34 PM   #18 (permalink)
honda06si's Avatar
justin
^your junk is dirty
Old 04-18-2007, 11:35 PM   #19 (permalink)
airportguy770's Avatar
Dave
Damnn And I thought it was a pain getting to the filter with the thing stock. I feel for ya ever 5000 Miles.
airportguy770 is offline   Reply With Quote
Old 04-19-2007, 12:51 AM   #20 (permalink)
sickyute's Avatar
Marvie
that's retarded and can be a fire waiting to happen!!!!!!!!!
Shift when it blinks!
Pit Bulls dentrecords Water Cooler 26 10-15-2010 08:41 PM
For Greddy turbo kit owners. BATANG CITY JAIL Turbocharging 59 12-26-2006 11:20 PM
