Old 01-12-2007, 05:17 PM   #1 (permalink)
BLU BY U's Avatar
nitrous problem
Seems the car is getting too much fuel for the nitrous being used. I was always told that you wanted a lot of fuel when using nitrous, so, where is there a lot of fuel? I have a wet system and fuel is wet and there's a lot of it in the gas tank. I just never thought that 900 psi from the nitrous bottle plumbed into the gas tank would cause the injectors to just dump fuel and nitrous into the motor. I wonder if the ratio of fuel to nitrous in the gas tank was the culprit. Well, anyway, I've removed the nitrous nozzle and plugged the hole with a cork. I suppose I'll give it a little more thought and try to come up with a better place.
Now I guess I know why I had so much air in the tank when I opened the gas cap after a nitrous run
BLU BY U is offline
Old 01-12-2007, 05:58 PM   #2 (permalink)
Ur soul. I haz it.
jasonandre's Avatar
Disciple of Discord
I hope you used real cork and not the prefabricated kind.
FS: 2006 Civic Si NHBP w/OEM Navigation
Originally Posted by Special Ringpop View Post
Your ass isn't typically a reliable source.
jasonandre is offline
Old 01-12-2007, 05:59 PM   #3 (permalink)
BLU BY U's Avatar
how do i tell the difference?
BLU BY U is offline
Old 01-12-2007, 06:04 PM   #4 (permalink)
Ur soul. I haz it.
jasonandre's Avatar
Disciple of Discord
Real cork is very porous and has compression lines similar to Styrofoam. Prefabricated cork is much harder and has a plastic ring surrounding the icing in the middle. If your petrol dissolves the icing center, the sugar will clog your fuel injector intakes, causing the drive-by-wire to permanently idle at 4000 RPMs.
Biiiiiig no-no.
Old 01-12-2007, 06:07 PM   #5 (permalink)
BLU BY U's Avatar
well ****.
BLU BY U is offline
Old 01-12-2007, 06:10 PM   #6 (permalink)
I'm your Huckleberry
[IVI]'s Avatar
Bryan
Your problem could be that you have gaseous nitrogen mixing with fuel instead of liquid nitrogen. In order for that setup to work properly, you need an agitator (like what you would find in a washing machine) in the fuel tank to properly mix the liquid nitrogen with the fuel. This will produce the desired 50/50 ratio that you are seeking.
[IVI] is offline
Old 01-12-2007, 06:11 PM   #7 (permalink)
Minister of Discord
Janizary's Avatar
Gas thread Nazi
Nitrogenated petrol. Yummy. Like sparkling water that can run the car.
Janizary is offline
Old 01-12-2007, 06:13 PM   #8 (permalink)
Ur soul. I haz it.
jasonandre's Avatar
Disciple of Discord
You're such a l337 noob.
In before the lock!
Old 01-12-2007, 06:32 PM   #9 (permalink)
Minister of Discord
Janizary's Avatar
Gas thread Nazi
Hmmm...I just noticed you are also a disciple of Discord. How have I missed that?
Janizary is offline
Old 01-12-2007, 07:27 PM   #10 (permalink)
Ur soul. I haz it.
jasonandre's Avatar
Disciple of Discord
I left my robe at home. Amen.
Old 01-13-2007, 02:16 AM   #11 (permalink)
2RotorMotor's Avatar
The problem is that you need to get the nozzle closer to the fuel pump... That happend to me, and I could never have the tank passed 3 bars untill I figured it out.
2RotorMotor is offline
Old 01-13-2007, 07:24 AM   #12 (permalink)
BLU BY U's Avatar
excellent! i didnt even think of that!!!!!
BLU BY U is offline
Old 01-13-2007, 08:27 AM   #13 (permalink)
Craig
Why did you plumb into the gas tank and not the fuel line up front with a tee fitting by AN or Earls?
chullen is offline
Old 01-13-2007, 11:33 AM   #14 (permalink)
Because the way he did it is the best way. Its the perfect cheater way, noone see's nothing when you pop the hood.
Old 01-13-2007, 04:59 PM   #15 (permalink)
BLU BY U's Avatar
exactly
BLU BY U is offline
Old 01-13-2007, 06:26 PM   #16 (permalink)
Minister of Discord
Janizary's Avatar
Gas thread Nazi
There's a sucker born every minute
Janizary is offline
Old 01-20-2007, 12:42 PM   #17 (permalink)
what kit are you running?
psykotik maniak is offline
Old 01-20-2007, 01:59 PM   #18 (permalink)
Tom1222's Avatar
Tom Smith
I think the new Civics prefer the dry System.
Tom1222 is offline
Old 01-20-2007, 03:17 PM   #19 (permalink)
Omes's Avatar
Yeah, definitely invest in a dry system and plumb it into the fuel tank. It's the perfect workaround to the returnless fuel system. BTW, I think BLU BY U has too much pressure going into his gas tank. I would recommend getting a regulator and only allowing 600psi into the gas tank.
Omes is offline
Old 01-21-2007, 12:49 AM   #20 (permalink)
cant run dry kits without EM.. it wouldnt give a proper nitrous/fuel ratio
Window Problem waross Mechanical Problems & Technical Chat 14 12-17-2007 04:27 PM
rear shock problem ziggy Mechanical Problems & Technical Chat 30 04-07-2007 07:48 PM
Problem with Pioneer P880PRS install nuked99 I.C.E., Electrical, Security, & Navigation 2 11-12-2006 11:24 PM
nos on an si thmper4u Mechanical Problems & Technical Chat 12 08-10-2006 05:38 PM
