Just a heads up we did test the ported intake manifold we recently released this past week. We tested it on the shop car with our turbo kit. the results were quite promising. What we realized on the drive to the dyno was and increase i both top end and mid rnge torque. When we rolled onto the dyno the results spoke for themselves. The car made the exact same power as before on the last 37owhp pull with roughly 2-2.5 psi less boost. What was the end result was an increase of roughly 8%. We will be testing on a NA vehicle later on this week ime permitting.
FYI the manifold will not be available for use on our turbo kit until more testing can be done. For NA application we have immediate release. The turbo cars are quite a bit more dangerous to go about modding with proper testing and extended driving. NA cars dont require as much drivabilty testing since they run smaller injectors and and dont suffer from the small issues. |
honestly we dont anticipate turning the boost up anytime soom. we like where we are at right now and mainly just are concerned about safety. we are working on some other things to increase the overall power but can only go so far. we are working with what we are given it has never been our goal to exceed the limitation of the ecm but to fully understand it and use ts full potential until a complete standalone becomes available.
#11 (permalink) |
since it was dyno'd on the shop car we will not be posting pics. most of the thing we manufacture are developed on that car so we would rather not provide detailed information. we usually only released detailed info on vehicles that carry our production products.
#14 (permalink) | |
Great response. Get the most out of the engine without compromising it's quality and durability. Straight economics; you build a product that can outperform others and combine it with quality, reliability and some great PR and you will shortly own the market. |
| JDM Accord R intake manifold... | k20civicSi | Intake & Spacer Discussion | 7 | 08-28-2006 01:20 AM |
| How to install heat shield intake gasket and bypass TB coolant on 06 si. | 06redsi | Civic SI | 30 | 08-16-2006 11:20 PM |
| 06 si vs 02-05 rsx intake manifold and throttle body.. | OneSi | Intake & Spacer Discussion | 11 | 12-28-2005 09:02 PM |
| Ford plastic intake manifold settlement | Shemmy | Garage | 6 | 12-24-2005 12:14 PM |
