#1 (permalink)
Powered by VTEC
centrifugal supercharger vs. turbocharger
Since there are a couple of centrifugal superchargers on the horizon for our cars, I would like to know the advantages and disadvantages of each. A centrifugal supercharger is basically a belt-driven compessor while a turbocharger is an exhaust-driven compressor, right?
u wont see 100% boost on a centri till ur about to redline, cuz its driven off the belt. also takes some hp away cuz its wasted attempting to spin the centri. honestly, i cant think of one good reason to go with a cetri except that u can fit one anywhere. if ur going to supercharge and sacrifice hp, then go with a twinscrew or roots blower, atleast ull have instant boost.
the following is only in the case of a properly sized turbo!!!!! u will barely lag, trust me, from a digg, ur going to lag no matter what, but with a properly sized unit, u will barely lag. Outstanding topend too. the bad thing about a turbo is only in the case that u didnt have a pro install it. oil leaks, water leaks, boost leaks etc etc etc. if ur gonna dish out 3-5k on a turbo kit, get it installed by an actual performance shop! otherwise ull be doomed to leak like a mad man! dont be fooled by those cute ASE certifications! |
Cereal Killer
There he is. I was wondering where you've been. Thanks for the info. And Ditto on an actual performance shop. Leaks. Thats the one thing I'm fearing going turbo.
"Did you ever notice how in the bible, when god needed to punish someone or make an example or needed a killing ...He sent an ANGEL?" ![]() Visit my mini-city. |
#4 (permalink) | |
Powered by VTEC
Thanks sheek360! I've got another question. Jackson Racing claims that their new Rotrex supercharger systems will have the throttle response of a Roots supercharger. Is that possible?
http://www.jacksonracing.com/home.htm
#6 (permalink) | |
MoDiFiEd
one thing i can say is....
i've never had a leak of any kind from day one...... not boost, not oil, not coolant ... no leak of any kind.
#9 (permalink) | |
#11 (permalink) | |
Powered by VTEC
#12 (permalink) |
Powered by VTEC
I did a little research. Let me know if I'm correct.
Roots superchargers produce a significant amount of boost early in the rpm range. Roots superchargers "blow" air in rather than compressing air in like turbos and centrifugal superchargers do. Turbochargers have lag in the lower rpms but build boost very quickly once the exhaust flow is great enough to spin the impeller. When the turbo starts spooling is when it begins attaining near maximum boost levels. Centrifugal superchargers, which are basically the compressor side of a turbo driven by a belt, start with a little boost and build it in a linear fashion, attaining maximum boost in the high rpm range. It seems like the worst of the three options to me because full boost comes so late in the rpm range. Especially in our high-strung cars would the centrifugal supercharger be at a disadvantage to the other two. I don't understand the physics behind it all though. For example, why does the Roots supercharger make boost early when the centrifugal charger makes boost doesn't make as much boost until later. Also, why do turbos have lag in the beginning and seemingly suddenly start spinning when the exhaust flow is great enough rather than having a more linear boost curve. ![]()
#13 (permalink) | |
#14 (permalink) | |
Powered by VTEC
The twin-screw design sounds great but, unfortunately, I doubt anyone would ever step up and design one for the Civic. I've read that they are more expensive to produce because they must be designed with much closer tolerances so they will properly compress air while a Roots supercharger just "blows" it into the intake (hence, the name "blower).
#17 (permalink) | |
what good is an increased volume of boost if u dont see 100% of it till about 1 second before you shift into the next gear? |
#18 (permalink) | |
if only vehicles could implement turbocharging configurations that the planes i see use.. but a man can always dream. |
#19 (permalink) | |
