Fuel Injector Chat and Discussion - Page 9 - 8th Generation Honda Civic Forum
Old 02-23-2010, 12:53 AM   #161 (permalink)
soxfan143's Avatar
Originally Posted by Supa Ninja View Post
AEM has one too
Didn't AEM stop making the K series rail? They don't have a listing on their site anymore.
soxfan143 is offline   Reply With Quote
Old 02-23-2010, 02:05 AM   #162 (permalink)
Supa Ninja's Avatar
Nick
i wasn't aware of that
Supa Ninja is offline   Reply With Quote
Old 02-23-2010, 08:50 AM   #163 (permalink)
nycclaye's Avatar
Nick
im runnining a FP guage on my stock rail, into the car. What's the problem with tapping into the stock line?
nycclaye is offline   Reply With Quote
Old 02-26-2010, 11:50 PM   #164 (permalink)
Str8JDM's Avatar
Full Race FA5
saw this on clubrsx and wanted to know...
would this work?
Str8JDM is offline   Reply With Quote
Old 02-27-2010, 12:06 AM   #165 (permalink)
Supa Ninja's Avatar
Nick
i don't see why it wouldn't work, i prefer my regulator out of the way.
Old 02-27-2010, 12:31 AM   #166 (permalink)
Str8JDM's Avatar
Full Race FA5
i didnt know that a regulator would work like that without a return line. what if you ran a short fuel line to it and tucked the regulator out the way?
Old 02-27-2010, 07:59 AM   #167 (permalink)
Supa Ninja's Avatar
Nick
he'll still need to use a return line. its obviously not finished, theres no fitting for the vac reference on the fpr, and the rail needs a plug where a gauge can go. you need a feed and a return line to a fpr.
Old 02-27-2010, 09:46 AM   #168 (permalink)
nycclaye's Avatar
Nick
^^news to me... that I didn't know. I was thinking I could just run the comptech fpr and be ok without a return.
Old 02-27-2010, 09:55 AM   #169 (permalink)
Supa Ninja's Avatar
Nick
Ext fprs need a return line, that's how the regulate.
Old 02-27-2010, 10:00 AM   #170 (permalink)
nycclaye's Avatar
Nick
well I found out that I had a HUGE boost leak coming from my greddy downpipe. out of the 6 bolts, 3 were loose, and 1 is completely lost.
that being said, I plan on taking a matching bolt to the nearest Harbor Freight to see if i can find one.
with the addition, hopefully, of mike's boost controller, and everything sealed up, plus the ID1000's, how much boost, safely can I run with those injectors? I wanna turn up my boost to 11psi, but I'm thinking that might be too much.
Old 02-27-2010, 10:09 AM   #171 (permalink)
Supa Ninja's Avatar
Nick
There are only 5 bolts on the downpipe. That's an exhaust leak not a boost leak. Talk to your tuner before you start cranking up your boost. If you crush your fpr you will have plenty of fuel with those injectors. I know mike is going for crazy boost levels but he has a badas mani and a better turbo. I think the lil greddy snails max effeciency is around 12 psi on this engine.
Old 02-27-2010, 10:12 AM   #172 (permalink)
Supa Ninja's Avatar
Nick
For example at 20+psi on pump gas with 70psi fuel pressure I'm only at 64ish IDCs. You will be just fine.
Old 02-27-2010, 10:27 AM   #173 (permalink)
nycclaye's Avatar
Nick
yea, but I have to get my hands on the walbro FP crush tool.
Old 02-27-2010, 10:31 AM   #174 (permalink)
Supa Ninja's Avatar
Nick
You mean a comptec fpr cruching tool and a walbro fuel pump?
Old 03-03-2010, 12:34 PM   #175 (permalink)
Chronic Whiner
PainIs4ThaWeak's Avatar
Mike (12.854@110.10)
I read this entire thread front to back, and noticed no one mentioned anything about aftermarket fuel lines. So I assume the stock fuel lines can withstand ~70psi?
(This thread makes me think the 520cc inj. included w/ the ct-e stg 2 w/ 3.15" pulley, crushed fpr, and stock pump isn't gonna cut it and will lean out - any input?)
PainIs4ThaWeak is offline   Reply With Quote
Old 03-03-2010, 12:58 PM   #176 (permalink)
soxfan143's Avatar
I have had the pleasure of driving my car with the ID 1000s for the last few days and they are everything they are built up to be. The drivability is so impressive and the idle is even more impressive. I'm running ~70psi base and the idle is smooth as glass. The part throttle and cruising and throttle tip in are like stock and possibly better. Injector Dynamics provides a sick product.
Old 03-03-2010, 01:29 PM   #177 (permalink)
Supa Ninja's Avatar
Nick
Sweet thats my exact same impression, you are just a lot better with words then me Mike
Old 03-03-2010, 01:34 PM   #178 (permalink)
Supa Ninja's Avatar
Nick
Ya the stock lines will be able to take that pressure just fine, noone has had a problem with the lines rupturing. Put a walbro in and you will have plenty of fuel for your setup. Us TC are running more boost then you can makde and higher power levels then you will ever see. if you switch to E85 then i recommend adding ID1000's too.
I can't emphise it enough install a walbro, the stock pump won't last long with the added load of larger injectors and and boost.
Old 03-03-2010, 01:48 PM   #179 (permalink)
Chronic Whiner
easy enough.
... off to buy a new pump
(Nick, always bringing the good info. thanks man.)
Old 03-03-2010, 01:55 PM   #180 (permalink)
Supa Ninja's Avatar
Nick
easy enough.
its a GSS342 if that helps any, i have seen them for as low as 70 bucks.
Fuel Injector Cleaners statuschanged Civic Coupe And Sedan 4 01-23-2010 12:45 PM
Stock SI Fuel Injector CC's midnitesi Engine Swaps, Mounts, Pulleys 26 01-21-2010 01:25 AM
Fuel Injector pigtail clips???? darrman25 Mechanical Problems & Technical Chat 1 11-29-2009 09:11 AM
Fuel injector cleaner? jpv027 Mechanical Problems & Technical Chat 6 01-09-2007 07:22 PM
Fuel injector question onefastsi Forced Induction And Nitrous 0 04-29-2006 01:50 PM
