Fuel Injector Chat and Discussion - Page 4 - 8th Generation Honda Civic Forum
Old 01-28-2010, 09:55 PM   #61 (permalink)
maiku's Avatar
Maiku (m-ai-k)
Just sayin', but I've never had any idle problems with my RC 650's. It idles super smooth and AF is around 14.8.
My only issue is the car doesn't want to start up easily as I've mentioned 100x without resolve.
The cold start issue is not temperature related. I live in FL.
maiku is offline   Reply With Quote
Old 01-28-2010, 11:23 PM   #62 (permalink)
Supa Ninja's Avatar
Nick
Have you tried adding some timing, helped me.
Supa Ninja is offline   Reply With Quote
Old 01-28-2010, 11:23 PM   #63 (permalink)
Str8JDM's Avatar
Full Race FA5
wow wish i knew what the hell everybody is talking about...lol
Str8JDM is offline   Reply With Quote
Old 01-29-2010, 12:19 AM   #64 (permalink)
soxfan143's Avatar
Nick, check your IAT and coolant temp cranking comp tables in the fuel parameter. That could be your problem along with the cranking trims. You could be dumping WAY too much fuel while cranking because of the comp tables. Then when it does fire the car might be pulling fuel like crazy causing it to go really lean for a bit.
Just thinking out loud here.
soxfan143 is offline   Reply With Quote
Old 01-29-2010, 01:17 AM   #65 (permalink)
Bugermass's Avatar
Chris
Use the dead times provided with the inejctors plain and simple. If the map you have was tuned on 1000s of another brand and were run on the base dead time tables then you are going to have to retune. I know.. It Sucks... but its better to do it that way.
I forgot who posted the question, but open loop with primary wideband enabled, just 0 out the min and max trims.. Keep in mind if you disable the primary O2 you will have to retune your whole map as this forces the ECU into a totally different fueling routine and will throw off the whole map.. ( I know cause I did it once and was pissed... )
And yeah hondatas fuel % stuff is calculated weird. The commanded change % doesn't always = % change in AFR.. Thats why i wish calvin would make the equivalent of eCtune for K series.. Its so much nicer to use somthing that works like its supposed to. ..
Bugermass is offline   Reply With Quote
Old 01-29-2010, 01:25 AM   #66 (permalink)
soxfan143's Avatar
So if you tune a map with the primary disabled then activate the O2 it will be all whacked out and you will have to retune it again of you want closed loop operation? hat sucks!
Old 01-29-2010, 09:44 AM   #67 (permalink)
Supa Ninja's Avatar
Nick
Just a little update, I'm using the greddy's timing/cam angle's. I have the ID1000 60psi latencies and it was 37F this morning, it started after I squrted some carb cleaner onto a vacuum port. I took all the default values for the IAT compensation cranking and divided them by 2. This cold start problem is really pissing me off. The rest of you guys need to hurry up and those IDs in so you'all help me figure it out.
Old 01-29-2010, 01:53 PM   #68 (permalink)
soxfan143's Avatar
If it started with carb cleaner then you need to add fuel in the IAT comp tables at that temp. You don't have enough fuel cranking.
Old 01-29-2010, 02:52 PM   #69 (permalink)
Supa Ninja's Avatar
Nick
I tried it mike, it had cooled down but it was 45F do no the real test, tomorrow lows in the 20's and snow.
Old 01-29-2010, 04:29 PM   #70 (permalink)
maiku's Avatar
Maiku (m-ai-k)
I dunno if anyone has looked for this information, but I asked RC for it.
Not sure if it'll even help or if it's relevant. I don't remember the inputs in the flashpro. I'm about to go out and check tho.
Here are the injector latency times for the SL4-650:
10v 1.08ms
11 0.86
12 0.69
13 0.54
14 0.41
15 0.31
Old 01-29-2010, 04:40 PM   #71 (permalink)
Jay
Maiku, before you go and put those in FPM. 2 things to note.
1) those values need to be converted to uSec (multiply by 1000).
2) they are for 43psi fuel pressure. Our car is 10 psi higher stock. This increases the latency values, you'll need to increase them by 10% or so, and even then they may not be ideal.
mucter is offline   Reply With Quote
Old 01-29-2010, 09:47 PM   #72 (permalink)
maiku's Avatar
Maiku (m-ai-k)
Crap. Here I thought I might be onto something. lol. Without the exact figure it'd probably be a waste of time.
Well wait, with that logic, if they change with the fuel pressure then could that be Nick's problem since he has a return system?
Old 01-29-2010, 10:04 PM   #73 (permalink)
Jay
Unlike RC, ID supplies the applicable latency at a variety of fuel pressures, including the pressure Nick is running. So he would have put the proper latency in. Even so, he's still having issues. We need to rebuild a new map for the 1000cc injectors using the proper latency. I'll be attacking this soon when I install mine.
Old 01-29-2010, 10:09 PM   #74 (permalink)
soxfan143's Avatar
I'll be waiting..... I need to get my injectors in to. lol..
Old 01-29-2010, 10:11 PM   #75 (permalink)
Jay
.....I can feel the pressure now....lol
Old 01-29-2010, 11:05 PM   #76 (permalink)
Bugermass's Avatar
Chris
Yes Sir.. Found that out the hard way... Called doug thinking it was a bug and he told me that its written in the manual..
Old 01-29-2010, 11:09 PM   #77 (permalink)
soxfan143's Avatar
Ridiculous. I thought you were supposed to tune in open loop then activate closed loop after you're done. At least that is what my local tuner/buddy does with K-pro and the S300.
Old 01-29-2010, 11:35 PM   #78 (permalink)
Jay
Yeah, guess you just do the min / max STRIM hack instead. That's the FP version of disabling closed loop. Easy enough so nbd.
Old 01-30-2010, 07:24 PM   #79 (permalink)
BlueSi4's Avatar
Oriol
It's funny that we just were talking about the ID's and RC's this past week. I actually was at this shop today and we were talking about the injectors and such, and he said he's switched to Bosch and ID injectors, he's been having problems with the RC's and getting them to idle properly, so all the cars he does now recommends the owners not to use RC injectors. He mentioned he hasn't had any problems with the ID's, they idle perfect.
So if so many people talk about a product, there's a reason why.
BlueSi4 is offline   Reply With Quote
Old 01-30-2010, 08:55 PM   #80 (permalink)
Supa Ninja's Avatar
Nick
I have messing around with my fuel maps and IAT cranking compension map. My battery has taken a nose dive with cold wave but I may have gotten it. Next week I'm ordering a Deka and a PWJ battery mount. It's better but I still need keep plugging away at it. I wish I could have a accurate AFR reading while cranking that would make this simple. I'm using the 60 psi latencies but since my 1:1 FPR reduces fuel pressure in vacuum I think is one of the reasons I'm having difficulties. Tomorrow I'm going to put the check valve back on it and see if that makes it better. With the check valve I'll be at 60 psi all the time.
Fuel Injector Cleaners statuschanged Civic Coupe And Sedan 4 01-23-2010 12:45 PM
Stock SI Fuel Injector CC's midnitesi Engine Swaps, Mounts, Pulleys 26 01-21-2010 01:25 AM
Fuel Injector pigtail clips???? darrman25 Mechanical Problems & Technical Chat 1 11-29-2009 09:11 AM
Fuel injector cleaner? jpv027 Mechanical Problems & Technical Chat 6 01-09-2007 07:22 PM
Fuel injector question onefastsi Forced Induction And Nitrous 0 04-29-2006 01:50 PM
