Fuel Injector Chat and Discussion - Page 10 - 8th Generation Honda Civic Forum
Old 03-07-2010, 09:55 PM   #181 (permalink)
nycclaye's Avatar
Nick
ok... question.
1.) Is is essential for me to use the "crush tool" that comes with the CTSC Kit on my walbro for the ID1000's to run right?
2.) Has anybody been running the ID1000's without crushing the damn thingy?
nycclaye is offline   Reply With Quote
Old 03-07-2010, 09:58 PM   #182 (permalink)
Supa Ninja's Avatar
Nick
Originally Posted by nycclaye View Post
ok... question.
Your not crushing your walbro, your crushing your FPR. It should run fine with the stock pressure, just atomization won't be as good at the lower fuel pressure. You have plenty of over head with those injectors.
Supa Ninja is offline   Reply With Quote
Old 03-07-2010, 09:58 PM   #183 (permalink)
nycclaye's Avatar
Nick
Originally Posted by Supa Ninja View Post
You mean a comptec fpr cruching tool and a walbro fuel pump?
yes, that's what i meant fyi..
Old 03-07-2010, 10:02 PM   #184 (permalink)
nycclaye's Avatar
Nick
that's what i meant, sorry it's been one hell of a weekend....
when you say "wont be as good", the only time I should see that being an issue is in the higher rpm range, where I'm most worried about detonation, and knock...
Old 03-07-2010, 10:03 PM   #185 (permalink)
Supa Ninja's Avatar
Nick
I'm just busting your chops buddy, he he.
Btw welcome to 21st century injector technology, they are fantastic injectors.
Old 03-07-2010, 10:05 PM   #186 (permalink)
Supa Ninja's Avatar
Nick
They seem to idle even smoother at the higher pressures too. You'll be fine man.
Old 03-07-2010, 10:07 PM   #187 (permalink)
nycclaye's Avatar
Nick
ok....
Old 03-09-2010, 01:38 PM   #188 (permalink)
sushicheffff's Avatar
brandon
Just to chime in here. This is an excellant thread, and thanks 100x over to everyone who put theyre input in. I really had no idea how damn complicated the fuel system could be til i started trying to figure out the best setup for my ride. After reading this thread I have to admit im still a little boggled on a few things, but I definatley learned alot. Now the only thing im worried about is getting my set up properly tuned.
sushicheffff is offline   Reply With Quote
Old 03-09-2010, 02:27 PM   #189 (permalink)
brandon
BTW, forgot to ask, everyone is still running the stock fuel rail correct?
Old 03-09-2010, 02:35 PM   #190 (permalink)
Supa Ninja's Avatar
Nick
Stock fuel rail is plenty. I had to run a aftermarket rail because of the fuel return.
Old 03-11-2010, 11:50 PM   #191 (permalink)
maiku's Avatar
Maiku (m-ai-k)
If I remember correctly, I began having the cold start (regardless of outside temp) issues after I installed the 650cc injectors. (takes foreeeeever to start...)
Did anyone else have this problem? And if you did, did it go away when you installed the ID 1000's?
maiku is offline   Reply With Quote
Old 03-11-2010, 11:54 PM   #192 (permalink)
Supa Ninja's Avatar
Nick
I think FPM gives us some wack cranking percentages when we up the injectors. Just takes a little more tuning.
Old 03-12-2010, 12:01 AM   #193 (permalink)
maiku's Avatar
Maiku (m-ai-k)
Tuning where? Fuel? Timing? I wanna fix it nao. x__x I've been dealing with it for waaay too long and it's terrible on the engine and embarrassing as hell.
Old 03-12-2010, 12:04 AM   #194 (permalink)
Supa Ninja's Avatar
Nick
I know the feeling. start by adding a little fuel. its a tough one because it only happens when the engine is cold.
Old 03-12-2010, 04:49 AM   #195 (permalink)
Jay
To really troubleshoot this, you need to start datalogging every start.
When you have a bad start up, look at the ECT it happened at, find that in the fuel coolant compensation cranking table. Once you've done that, look at your datalog about 10-12 seconds after the car starts you'll see the o2 sensor come on. It'll immediately read either really rich or really lean.
When editing the cranking ECT comp table, do it in very small increments. If the value you are adjusting is -80%, try .5% adjustments at a time, if it's closer to -40% try 1% increments.
If it's really lean (when the o2 first comes on), try increasing the fuel in the ECT cranking comp table. So if the value you want to edit is -70% and you want to add 10% fuel, you would change the value to -67%.
If it's really rich, try decreasing the fuel in the ECT cranking comp table. If the value you want to edit is -70% and you want to remove 5% fuel, you would change the value to -71.5.
This math is based on the Hondata help file. I popped their equation into an excel spreadsheet really quick to get the calcs. You can do the same very easily.
mucter is offline   Reply With Quote
Old 03-12-2010, 12:07 PM   #196 (permalink)
maiku's Avatar
Maiku (m-ai-k)
I tried datalogging the start-up before but it didn't work. Does it have to be connected to the laptop?
Old 03-12-2010, 12:15 PM   #197 (permalink)
Supa Ninja's Avatar
Nick
Ya I have the same problem tring to datalog during start up. So I came up with a technique to see if it's rich or lean durning startup. I pull the vac line off my bov, squirt some starting fluid into it. If it fires right up then I add some fuel to the ect comp table.
Old 03-12-2010, 01:08 PM   #198 (permalink)
Jay
Make sure you have the newest (beta) version of FPM. It'll update your FP firmware. They fixed the issue with datalogging startup a long time ago. It works flawlessly for me. Just put the key in on, wait for the FP to show power, push the datalog button and start the car.
When updating to the newest FPM, make sure you also open and save/re-upload your cal to the FP and then flash the car first. They changed some stuffs with how certain things are datalogging.
Old 03-12-2010, 02:10 PM   #199 (permalink)
Supa Ninja's Avatar
Nick
That's good news, I already upload the new stuff to my ecu. E85 cold starts suck balls, I'm going to try and sort that out.
Old 03-12-2010, 08:20 PM   #200 (permalink)
maiku's Avatar
Maiku (m-ai-k)
Sweet, your right. It did work. ;D I had went and tried it again before reading this and it worked. I was really flustered b/c I swore I did it that way last time. Lol. Glad they updated it. I did a datalog so I'll try and get that on my compie and see if I can figure it out.
Thanks.
Fuel Injector Cleaners statuschanged Civic Coupe And Sedan 4 01-23-2010 12:45 PM
Stock SI Fuel Injector CC's midnitesi Engine Swaps, Mounts, Pulleys 26 01-21-2010 01:25 AM
Fuel Injector pigtail clips???? darrman25 Mechanical Problems & Technical Chat 1 11-29-2009 09:11 AM
Fuel injector cleaner? jpv027 Mechanical Problems & Technical Chat 6 01-09-2007 07:22 PM
Fuel injector question onefastsi Forced Induction And Nitrous 0 04-29-2006 01:50 PM
