Turbo tuning options?
I have a 07 Si and am going to decide on a turbo system in the next few months. I have already installed the AJP 3" exhaust in preperation. Im looking at the Greddy and AJP systems. Ive called both companies and am told that both make nice HP and both are upgradeable. The problem is anything above stock levels of boost requires retuning and a level of experience with either system. I personally can install the kits but have no level of tuning experience. I want to be in the 8-10 PSI range running close to 350HP. this should put me well into the 12 sec. quarter mile range under proper conditions. Are there any easy solutions or miracle tuning boxes that will cure my problem or do I have to start looking for Honda tuners in the New England Area close to my home in Southern Maine?
#2 (permalink) | |
go with AJP i know that their kit makes more power then greddy hands down running lower psi, also im not sure how much boost AJP makes but without building your motor i would only consider 8psi safe with fuel upgrades pump, injectors if not included, reg, all that good stuff but even with 8psi you will make good 300 + power with mods
#4 (permalink) | |
#6 (permalink) | |
#7 (permalink) | |
FG Squad Member #15
#8 (permalink) | |
#9 (permalink) | |
![]() Hello fellow New Englander :). I'm just going to co-sign and tell you to go with AJP, because that's who I went with. They're a bit more expensive than Greddy, but I don't trust Greddy to take care of their issues. They allegedly denied their fuel map wasn't right and was causing the vehicle to run poorly, and their power levels are nowhere near where they're advertising. Give AJP a buzz. They've been nothing but helpful and accomodating to all of us who've inquired about their kits, and will soon have the AFC-NEO, Hondata reflash and Greddy e-Manage (Ultimate, I believe) as tuning options. The NEO is already done, the reflash is supposed to be shipping within the next few weeks and the e-Manage is coming. Now to just find someone to tune it here in New England
#10 (permalink) | |
#11 (permalink) | |
Actually, I believe the fuel controller is only capable of 4psi. On the Marvie kit that was good for 300whp. They used it on the shop car, if I recall, to 350-400whp at 7psi. |
#12 (permalink) | |
#13 (permalink) | |
#14 (permalink) | |
Moderator
#15 (permalink) |
Moderator
hondata reflash should be done really really soon as sema is now over...
YAAAAAYYYYYYYYYYY!!!! i'd say go with AJP not cuz i have it but because ur other option is greddy... i'll tell u that htec17/local member on here, the first with his greddy kit on here went through shit and more and back...well after a greddy rep flew over here to help him out...things got a lil better but still wasn't what it should be...can u imagine??? well he's getting his money back.... he's not the only one who had issues either...search the boards. where tunning is concerned... strangely the emanage worked on the AJP shop car without issue. afc neo works but to a point...it can't do to the 8th gen Si what it can do to prior hondas so here u are limited to some fuel tuning...some fuel tuning cuz u can only tune fuel to a point or to a certain rpm with it...imo after the ecm learns with it on there u can remove it. hondata reflash as stated above will be completed in the very near future.. hondata ECM controller(what i call it) will be out soon. how soon? i don't know. what i do know is there is something in the making...what i've heard from good sources is that it won't be a standalone but a piggy back unit that will allow u to do everything the kpro does, but don't quote me on this...it's what the highly touted sources say :) i have a hint of how it works but it's not concrete info. so i'll keep that to myself. AJP or go home!!
#16 (permalink) | |
#17 (permalink) |
Moderator
haha...
there's a new greddy unit... that's better than the emanage...made especially for vehicles like ours... the emanage couldn't alter vtec on the i-vtec engines and so on but the new one can do that an alter timing accross the whole rpm range... it looks good ... it's called the V - manage .... something to look out for :)
#18 (permalink) | |
#19 (permalink) | |
Marvie, correct me if I'm wrong, but didn't they have the NEO on the shop car and one day decide to take it off and see how the car ran? And it turns out that the car ran a little smoother with no piggyback. That was what I understood from speaking with Ben. Anything past 7psi needs some form of management because the car runs a little lean on top end. Ben or Marvie, can you add anything or correct me if I'm wrong please? Thanks. |
#20 (permalink) | |
| 2006 Civic Si vs 2006 Civic Si S/C and or 2006 Civic Si Turbo | nnorton | Autocross & Sanctioned Drag Racing | 21 | 12-04-2007 08:55 AM |
| Tuning and turbo | CaliGuy | Forced Induction And Nitrous | 3 | 10-01-2006 07:13 AM |
| stuck on turbo options | honda06si | Forced Induction And Nitrous | 3 | 09-07-2006 03:43 PM |
| Civic Coupe Turbo | FujiBlueSi | Civic Coupe And Sedan | 0 | 05-10-2006 08:26 AM |
| Honda Tuning R18 turbo | DarkFlareon | Civic Coupe And Sedan | 1 | 05-07-2006 12:04 AM |
