8thcivic Sponsor
![]() Join Date: Nov 2006
Returnless Fuel Systems - what is the limit?
I have had a lot of people asking me when they need to add an external FPR and a fuel return line - however after spending a day with tuner-extraordinaire jeff evans of Evans Tuning - EFI Tuning Specialists he let me know some interesting things i wanted to share with you guys. ** these estimations assume an equal length header turbokit and ID 1000cc injectors tuned properly
-a walbro 255 high pressure intank pump, can flow enough fuel for ~440whp on stock intank FPR, and ~500hp on a crushed FPR "Comptech Style" -a bosch motorsports intank fuel pump, can flow enough fuel for ~480whp on stock intank FPR and ~550hp on crushed 'Comptech Style' FPR -if you install a product called "Boost-A-Pump" mfg'd by Kenne Bell, this will jump the fuel pump's voltage supply to 20V (perfectly fine for the fuel pump, in fact good for it!) and allow the walbro to flow close to 600hp and the bosch beyond this i hope this helps some guys realize its not absolutely necessary to add the return line and external fpr, of course for anyone looking to run 30+ psi or have a race car the FPR may prove to be a wise investment, but not at all needed for 99% of the builds out there (these cars are too damn nice to turn into drag cars anyway!) |
#9 (permalink) | |||||
8thcivic Sponsor
that is definitely the injector size to use, and i recommend the ID 1000cc because they offer the finest quality spray pattern and corresponding performance Quote:
neither are really proper fuling solutions persay, bu they both get the job done obviously...
#11 (permalink) |
8thcivic Sponsor
great question! thats what the boost-a-pump is all about -- take a look and read up if you have a minute Kenne Bell Boost-A-Pump
the fuel pressure would not be increased at a 1:1 rate like ideal, but this is a returnless system so that is not an option! |
#12 (permalink) | |
#13 (permalink) |
The only thing I would like to add to this is that in a supercharger application the whp figures given are way lower do to the fact that the blower has a lot of parasitic drag compared to a turbo setup. I never would have made my 407 whp with my Lysholm Twinscrew blower without a return setup because of this. I am running the ID 1000 injectors with a full -6an return setup. Best injectors on the market by far.
Good thread I am eager to see more on this topic. |
#15 (permalink) |
Geoff, I was reading over the mfr's specs and they are stating that there is no increase in fuel temps. My understanding was that part of the issue in a deadhead system is that the fuel heats up once the car goes into boost, as the pump is trying to work harder to force it through the injectors against manifold pressure. Can you comment on the fuel temp issue?
#16 (permalink) |
with non return system the fpr cant compensate for boost, so if you are boosting a higher ammount than 10psi, this can affect the ammount of fuel delivered because of the pressure differential, its better just to switch to a return system if you are serious about boosting. A greddy kit or similiar should be fine with the returnless system.
#17 (permalink) | |
It makes sense that getting higher and more consistant voltage to the fuel pump is a good thing but what isnt being addressed is the spray pattern that can be effected by lack of regulated and correct pressure. With a FPR you can adjust you are sure you are maximizing the injectors ability to spray correctly by giving it the correct regulated fuel pressure. No matter how good an injector is it can only be as good as the systems that support it. In the case of the injector dynamics injectors that we all love I would suspect that they would be the best of the bunch at being able to maintain a good spray pattern but even these would be open to the above concept I would think. Interested in thoughts in regards. |
#18 (permalink) | |||||
8thcivic Sponsor
***KEEP IN MIND: Fuel pump output pressure - boost level = fuel rail pressure*** Quote:
#19 (permalink) | |
#20 (permalink) |
![]() Join Date: Nov 2007
Well from what I've read on the Boost a pump it uses a vacuum reference to know when to up the voltage to the pump. So at idle the fuel pressure will remain at the stock pressure and once the boost a pump sees 5psi+ it will up the voltage accordingly. Now my question is how does it know how much voltage to add to keep the fuel pressure from spiking all over the place? Once 5psi hits does it increase voltage in increments or does it just jump right to the max 20v?
| Halloween Age Limit?? | Matt_Roze | Water Cooler | 62 | 10-05-2009 09:25 AM |
| greddy kit -Release the fuel pressure in the fuel system | RR_Si | Turbocharging | 6 | 04-15-2009 07:00 PM |
| IMPORTANT: Fuel Return Kit and Fuel Filter Issues | blue1 | Forced Induction And Nitrous | 196 | 04-27-2007 02:09 PM |
