AEM CDI Pencil Coil
AEM’s new CDI Pencil Coils are now available! Easily allowing the conversion to coil-on-plug ignition systems, these Pencil Coils will work with aftermarket engine-management systems. Additionally, when Pencil Coils are used in high-boost, high-RPM, or high-compression applications, an increase in spark energy can be seen over factory smart coils.
anyone running these on there car ? anything noticeable ? and what the heck is a cdi ignition module ? AEM - CDI Pencil Coil Must be used with CDI ignition module |
I remeber reading a while back that someone here was using this setup just don't remember who it's about $280 shipped for all 4 but if you NEED a ign module then might be a little too pricey for a better stronger spark ,
Wish we had a 2step available or MSD ign or something There's a few semi built bseries by me with 2 step sounds so sick Last edited by 07_FG_4Dr_S.i.; 11-20-2008 at 08:43 PM. |
The factory ignition is fine. The spark plug is only going to use as much voltage as it needs to jump the gap, no more no less. Say your factory ignition coil(s) are capable of producing 40,000 volts and while in boost (the time the air is most compressed thus providing the most resistance) you only need 30,000 volts, the spark plug is only going to use 30,000 volts even if you have 'better' coils that can produce 80,000 volts unluss you just want to have loads of reserve voltage.... If your looking for a longer spark you need to step the amperage up.
| Coil over question | infamousmodi | Suspension and Brakes | 3 | 10-14-2008 12:19 PM |
| has anyone seen those aem pencil coils | accordtocivicsi | Bolt-Ons And All-Motor | 3 | 08-11-2008 04:29 PM |
| Lowering HFP Vs Coil over | heron126 | Civic SI | 34 | 04-19-2007 11:59 AM |
| Coil-Overs in Winter | brownsgolf | Suspension and Brakes | 4 | 11-08-2006 10:05 AM |
| Please help!!! Windshield Spots the size of pencil lead!!!!! | baddazzcivic | Detailing | 7 | 07-11-2006 07:47 AM |
