Old 07-17-2006, 07:57 AM   #1 (permalink)
aznchzexr's Avatar
Chester
Turbo'd R18 in PAS mag !!!
http://pasmag.com/article.asp?ID=201
Ryan Shutt knows a thing or two about the Honda Civic. His 1997 Civic EX was featured right here in Performance Auto & Sound back in 2004 (Vol. 6, Issue 7). That Civic stood out from the pack and caught the attention of Honda Motor Co. USA. When Honda launched the new 2006 Civic EX it wanted to display a project version at the 2005 SEMA show, and Shutt was the perfect candidate to take on the task.
In September 2005 Shutt was handed the keys to the Civic and had six weeks to get the car ready for SEMA. Owned by Honda, the Civic is actually on loan to Shutt for use at various shows and events across North America. What this meant was the cost for the build was minimal to Shutt as most of the parts and service was provided by sponsorships.
Shutt stayed away from extensive performance modifications, choosing instead to focus on the exterior and audio system of the Civic. He left the 1.8L, four-cylinder V-tec engine in place and chose to add some boost to the 16-valve SOHC motor. To get some more power Shutt added a Top Fuel engine management system and a Turbosmart e-boost 3 boost controller. Turbosmart also provided the blow off valve. The turbo itself is a Precision Turbo ball bearing turbocharger with the piping and intercooler coming via Vibrant. The turbocharger is fed by a Nitrous Express nitrous oxide injection system with two bottles. The spent gases are expelled by a Top Fuel exhaust system.
Once the work under the hood was complete, Shutt turned his attention to upgrading the look of the Civic. To get the results he wanted, Shutt entrusted the body work to Detrich Auto Body in his hometown of Baltimore, MD. They quickly went to work moulding an Audio Originals custom body kit to the car. Audio Originals improved upon the Civic with custom front and rear bumpers, a custom grill and custom fenders. Not finished there, Audio Originals added some spoilers to give the Civic a more aggressive look on the street. Detrich Auto Body then scrapped the hood, roof and trunk in favour of carbon fibre versions. Finally, Shutt blacked out the headlights and taillights to give the car a unique style.
Once the body was complete, Detrich Auto Body focused on the graphic scheme that would make this Civic grab everyone’s attention on the show floor. Shutt opted for a two ton design using BASF custom colours, which gives the car a strong presence on the street or on the stage. Speed Design added the final touches with some accent graphics.
Of course, a sweet ride like this Civic is nothing without a good pair of shoes to take Shutt from place to place. Thus, Shutt upgraded the wheels to 19 by 8.5-inch Davin Speed S2 models and wrapped them in 215/35ZR-19 SP9000 rubber from Dunlop Tires. Shutt also improved stopping power by upgrading the front calipers to an SSBC Force 10 brake system. The suspension was improved via Eibach springs and struts up front. SPC Performance alignment components keep this Civic under control when it’s dropped to pavement scraping levels.
With the Civic now grabbing plenty of attention on the outside, it was time to focus on the inside and create something that would blow the doors off the competition. The interior upgrades were performed by Glen McKinney and he transferred the theme of the exterior into the interior with a seamless flow. The stock seats were ditched in favour of OMP racing seats and harnesses. The rest of the interior was treated to a slick re-design as McKinney used Tsunami suede on the dash, doors and trunk. After some carbon fibre found its way on the exterior, the door inserts were given the same treatment. The bottles for the nitrous system found their way inside, mounted on suede-wrapped panels attached to the rear quarter panels.
With so much already done to the Civic, it was no surprise that Shutt went big when it came time for the ICE system to be designed and built. Everything gets started via an Alpine IVA-D300 head unit that was mounted in the dash’s stock location. It is ISO-mounted with a custom steel bracket to solidify its presence. The Alpine plastic trim was moulded to the dash as well as a Tsunami display. The two sides of the OEM plastic pieces were glued together with epoxy and smoothed with body filler to give the dash its clean look. As part of that panel, Shutt added several gauges from Stewart Warner. But the gauges didn’t stop there as Shutt also had some moulded to a second trim piece closer to the windshield and around the shifter.
From the Alpine head unit, the audio levels really get kicked up a notch throughout the system as Polk Audio pieces fill the interior. A Polk Audio C300.2 amp handles the rear fill while running the SR6500 components in the trunk. An interesting modification here is that this part of the system is only operable when the trunk is open. A C500.1 amp handles two SR124 woofers at a 2ohm mono load. That leaves two C400.4 amps to handle the mid range and run the front stage. One of the amps runs the door mounted SR6500 while the other is responsible for the SR5250 components in the A-pillars. The C300.2 and C500.1 are hidden while the C400.4 amps are bolted to square steel tubes mounted on the rear deck.
To mount the SR5250 components to the A-pillar, Shutt used a child’s mini-volleyball to shape a fiberglass enclosure for the 5.25 inch mids. A three-quarter inch MDF ring was attached so the mids could be mounted. The enclosures were then moulded to the A-pillar with Duraglass and body filler. Tweeter mounting rings are angled off just above the enclosures. A quarter inch threaded insert was welded to each a-pillar so the pods could be bolted on directly. A pair of SR124DVC subwoofers resides in a modified db212-2 vented enclosure while the mid bass is the responsibility of a pair of SR6501 drivers. To make sure there was enough power to run this system, Shutt installed a Tsunami battery under the hood and added two more to make sure there’s never a power issue. Shutt also used Tsunami for the main power wire and distribution blocks.
Shutt truly established a great ride with his version of the 2006 Honda Civic and it’s hard to believe he did it all in a six-week window. While Shutt spent in the neighbourhood of $4,000 out of his own pocket, the real heroes of this build are all the sponsors that contributed, including: Honda, Polk Audio, Davin, Detrich Auto Body, Glosser, Eibach, SSBC, OMP, Precision Turbo and Nitrous Express. All that help has already generated some positive feedback and Shutt took home the Dunlop MAXXED OUT award at SEMA.
This Civic is a head turner and Shutt gave Honda something it can display at every show it attends. “The big story of this vehicle is how well it came together given how little time we had to work on it,” said Shutt. “I use the system to blow people away at car shows with volume and sound quality. I hope I’m doing my part to save the world from the incredibly bad sound that you usually hear coming out of modified cars at shows. I’m demonstrating that car audio doesn’t have to be sloppy bass and shrill treble — you really can make a system that sounds like real music, plays loud and looks flashy at the same time.”
aznchzexr is offline   Reply With Quote
Old 07-17-2006, 09:08 AM   #2 (permalink)
Storm's Avatar
Thumbs up to the paint job
Storm is offline   Reply With Quote
Old 07-17-2006, 09:30 AM   #3 (permalink)
how much for that turbo?
SkyeHack is offline   Reply With Quote
Old 07-17-2006, 10:09 AM   #4 (permalink)
The turbo set-up from what I could read must cost a lot of $$$ which I could not afford but definitelty awesome, most haul as***!!
As for the audio, I'm not a big fan of those plastic audio add-ons, but I understand it is a show car not a daily driver
PR8thgen<ivi> is offline   Reply With Quote
Old 07-17-2006, 10:25 AM   #5 (permalink)
[IVI]'s Avatar
Bryan
That car was also featured in Honda Tuning magazine recently.
[IVI] is offline   Reply With Quote
Old 07-17-2006, 11:51 AM   #6 (permalink)
Zuli's Avatar
I'm right there with you. The shiny plastic look is not my cup of tea, but I do like the paint scheme. I've been toying with the idea of having the same two tone paint scheme done to my car in alabastar silver/black.
Zuli is offline   Reply With Quote
Old 07-17-2006, 12:44 PM   #7 (permalink)
Zesti1's Avatar
Joseph
Flipped through the article @ Chapters a couple of weeks back. Not bad.
I like the fiberglass gauge bessel that was made. Colour scheme is good to.
Hopefully you R18 owners will find out a price on that kit soon!!!
Zesti1 is offline   Reply With Quote
Old 07-17-2006, 01:34 PM   #8 (permalink)
brooklynscat69's Avatar
brooklynscat69 is offline   Reply With Quote
Old 07-17-2006, 04:44 PM   #9 (permalink)
06CivEXJon's Avatar
Jon
Thats Ryan Shutts car it was at Sema show last year its insaine (awesome) thats a fresh/clean install on the parts for the R18 engine.
Old 07-17-2006, 04:56 PM   #10 (permalink)
yigger's Avatar
yigger is offline   Reply With Quote
Old 07-17-2006, 11:53 PM   #11 (permalink)
CivNick's Avatar
body kit.. ugly
paint job... good.. but the body kit kills it for me
interior.. only good part is the fiberglass dash..
i really wanna see better pics , specs , layouts, of the motor ..
nice show car though
CivNick is offline   Reply With Quote
Old 07-18-2006, 10:34 PM   #12 (permalink)
moaltar's Avatar
That car is pretty cool! I also saw that in Honda Tunning Magazine a few weeks ago. I found the website of the people who made that turbo manifold, that whole setup is custom. I would prefer to have a prefab kit for my EX, for reliability issues.
moaltar is offline   Reply With Quote
Old 07-18-2006, 10:41 PM   #13 (permalink)
I saw this car twice at HIN events and plan to see it again in NY. I don't like the cut outs in the side skirt or rear bumper extension, but I've seen this car in person and I have to say, if you get a chance to see it you'll like it a lot.
Old 07-18-2006, 11:11 PM   #14 (permalink)
aznchzexr's Avatar
Chester
skittles can u contact him and find out about the turbo set up?!
Old 07-18-2006, 11:33 PM   #15 (permalink)
I'll ask about it if I can next month. He should be in NY on the 12th for Nightshift. He's local to Maryland so I'd imagine he'd be up there.
Old 07-19-2006, 08:18 AM   #16 (permalink)
Torredo
Guest
Posts: n/a
what i cant figure out is the guage pods?
i cant seem to find anything for my R18 Civic yet?
Old 07-19-2006, 03:17 PM   #17 (permalink)
strCIVIC's Avatar
damn!!!lets give it up for another "WEll DONE" civic..
strCIVIC is offline   Reply With Quote
Old 08-08-2006, 05:27 PM   #18 (permalink)
mikeg210's Avatar
that body kit is
but the rest is good
mikeg210 is offline   Reply With Quote
Old 08-09-2006, 12:07 AM   #19 (permalink)
Just to say, turbo's usually run around $3,000 or more....so don't expect a $1,000 turbo. $3,000 without install, and I don't think it'd be easy to do self-install (Install'd be expensive too).
RSwanson26 is offline   Reply With Quote
Old 08-10-2006, 02:07 AM   #20 (permalink)
Nexus's Avatar
I'd paint the trunk black.
http://img93.imageshack.us/img93/7010/blackfk8.jpg
Nexus is offline   Reply With Quote
R18 vs D16 Ep3racer954 Civic Coupe And Sedan 12 02-25-2008 09:48 PM
R18 Turbo Kit 1zach4 Forced Induction And Nitrous 143 12-22-2007 04:14 AM
