Go Back   8th Generation Honda Civic Forum > Civic Technical > Do It Yourself Articles > Exterior Style Mods
Old 03-12-2008, 01:03 AM   #1 (permalink)
DIY Mugen Spoiler instructions.
I know this is in the wrong Forum, but it wouldnt let me post a new thread in the DIY one. Moderator, please move if possible.
I created this for another member, & thought it could help out more in the future. Here Goes...
Step 1. Lay everything out. if you are like me, you rec'd everything you see here...
Lower Spoiler & Parts
Upper Spoiler
Step 2. The Spacer Set (bag with silver brackets at right) is NOT needed for install. Try to return if possible. Upper Spoiler comes attached with 4 of the 8 black Hex Screws (used to adjust) shown in middle. You will only need 2 of these to use to attach the Upper spoiler to Trunk Deck.
Step 3. Open Trunk Deck & remove (2) nuts holding stock spoiler on at each end of Trunk Deck. (Keep these nuts! They are re-used to attach Upper Spoiler).
Step 4. Completely remove carpet insulator (if its 2007 model) Keep all plastic pins in a baggie to re-install later.
Step 5. Once carpet is removed, carefully remove the (2) nuts you can see holding the stock spoiler on.
Unclip the wiring harness used for the 3rd brakelight.
Step 6. The Scariest One!! Carefully remove the stock spoiler by evenly pulling up. The white pins eventually will POP! Once Spoiler is off, use needlenose pliers to remove the Female Plug Adapters left in Trunk Deck. (Place in Baggie to use for later) Carefully remove the (2) screws for the 3rd brakelight from Stock Spoiler. (Place in Baggie to use for later with Mugen Lower Deck Spoiler.)
Step 7. Clean top surface of Deck Lid thoroughly. NOTE: All holes will be used, with NO additional ones needed.
Step 8. Carefully install Side Brackets to Trunk Deck.
For this step, I Re-used the White Plastic Pins that held down the Stock Spoiler to create "Pivot Pins". I sanded the female ends top surface flat. Then I carefully "thinned" the round flat horizontal portion of the Male End.(the part that rests on top of the female Pin (same diameter) This creates a "Pivot pin" and plugs the hole. NOTE: You have to properly sand these down as thin as possible so you the side brackets sit flush on the Trunk Deck. Place the female "Pivot Pin" portion in these holes in Rear deck. Place Male "Pivot Pin" portion into holes in Female portions already in Deck Lid. I would suggest not pulling off all 3M tape on Side Brackets so you can dry fit the Upper Spoiler to insure proper placement. The "Hollow" hole each of the Side Brackets goes around the "Pivot Pin" you inserted in the holes shown below.
Step 9. Once proper placement of the Side Brackets is made, Carefully install Upper Wing. Use the nuts you removed from the ends of the stock spoiler to attach Upper Wing screws to the front hole of each Side Bracket. The rear hole uses (1) Black Hex Screw on each side to secure.
Step 10. Install 3rd brakelight into Lower deck Spoiler using screws from stock Spoiler.
Step 11. Thread 3rd brakelight wire through hole in Rear Decklid. Carefully align screw posts from Lower spoiler into holes in Rear Decklid. Once aligned, push down along front edge of Lower spoiler to "POP" the plastic pins through holes and into place. Reuse the (2) nuts you removed from Stock Spoiler Screw Posts to secure.
Step 12. Reattach 3rd brakelight wiring harness and carpet insulator pad & you are DONE!!!
Please let me know if you have anymore questions. I'll be happy to help out anyway I can.
Nate
n8ssi is offline   Reply With Quote
Old 03-12-2008, 03:44 AM   #2 (permalink)
david3558's Avatar
David
Where can you get the USDM Mugen Si spoiler?
david3558 is offline   Reply With Quote
Old 03-12-2008, 04:43 AM   #3 (permalink)
07FG2's Avatar
Brandon
well i know someone that just bought a mugen and they are cool with me wanting to buy parts but i want to know
1 did you get this from the dealership..?
2 i looked online and saw that it cost 900 for upper and 400 for bottom spoiler.. is this at all close to what you paid..?
but i have not yet gone into the parts area at a dealer and asked the price im hoping there not that expensive ..
07FG2 is offline   Reply With Quote
Old 03-12-2008, 09:07 AM   #4 (permalink)
Millcitytech's Avatar
http://www.8thcivic.com/forums/inter...i-spoiler.html
Millcitytech is offline   Reply With Quote
Old 04-07-2008, 02:00 PM   #5 (permalink)
jackolee's Avatar
nice diy
jackolee is offline   Reply With Quote
Old 04-07-2008, 02:26 PM   #6 (permalink)
Getting ready for winter.
ocdcivic's Avatar
Ray
Originally Posted by Millcitytech View Post
So you're selling it again?
ocdcivic is offline   Reply With Quote
Old 04-07-2008, 03:06 PM   #7 (permalink)
Nope that was almost a month ago , the wing is already on my car. Tried to sell but no one bit.
Old 04-07-2008, 05:12 PM   #8 (permalink)
jackolee's Avatar
any more pictures to make this simpler?
Old 04-08-2008, 09:22 AM   #9 (permalink)
civic-type-r's Avatar
where can i get the center lid? i need it so badddd.....
civic-type-r is offline   Reply With Quote
Old 04-11-2008, 11:39 PM   #10 (permalink)
jackolee's Avatar
do you have other pictures of the bracket???
Old 04-11-2008, 11:43 PM   #11 (permalink)
I Vtec, do you?'s Avatar
Jeremy
Damnit I thought someone had somehow fabricated a way to actually make a DIY spoiler :P Wishful thinking eh?
I Vtec, do you? is offline   Reply With Quote
Old 02-21-2009, 02:17 AM   #12 (permalink)
a1j7g's Avatar
Andy
Nice DIY
a1j7g is offline   Reply With Quote
Old 02-21-2009, 02:22 AM   #13 (permalink)
Sle
Sle's Avatar
Sam
whats up with these year bumps.
it is a good diy though.
Sle is offline   Reply With Quote
Old 03-09-2009, 02:39 PM   #14 (permalink)
Tyler Hamilton
the mugen wing wouldnt fit on the si coupe would it?
thammy8991 is offline   Reply With Quote
Old 03-25-2009, 11:08 AM   #15 (permalink)
armyzfinest's Avatar
Rich
no
armyzfinest is offline   Reply With Quote
Old 04-15-2009, 06:04 PM   #16 (permalink)
wlam85's Avatar
William
anybody have any idea on how to get this spoiler? websites or dealer?
wlam85 is offline   Reply With Quote
Old 04-15-2009, 06:52 PM   #17 (permalink)
Bodin
or maybe even a significantly cheaper bootleg?
boweldi is online now   Reply With Quote
Old 04-15-2009, 07:01 PM   #18 (permalink)
NitrousG35's Avatar
Never Again!
Hehe, I got mine from the OP, the one you see in the pictures!
Fabulous Fiji FA5 with Mugen wing and beauteous black G35
Some cause happiness wherever they go: others whenever they go. -Oscar Wilde
Old 05-10-2009, 01:32 AM   #19 (permalink)
immasexyboy's Avatar
phil
nice!!!
immasexyboy is offline   Reply With Quote
Old 06-06-2009, 02:20 AM   #20 (permalink)
Asakura Yoh's Avatar
Asakura Yoh is offline   Reply With Quote
Who wants a legit USDM Mugen Si replica spoiler? (SEDAN ONLY) I Vtec, do you? Inside and Out 103 12-06-2008 09:29 PM
Chop the mugen spoiler on coupe plzzzszz zuck6977 Photoshop 25 02-03-2008 01:47 AM
mugen spoiler fit? xdanimals Inside and Out 5 01-16-2008 04:18 PM
2008 Honda Civic MUGEN Si High Speed at $29,500 trev0006 Civic SI 18 10-30-2007 11:56 AM
