#1 (permalink)
DIY Mirror Replacement
This is for the coupe... i'm not sure if the sedan is the same...
Since this part can be changed while still on the door i see no point in going through the steps of removing the mirror from the car... although that option is there... it's rather simple to do it has no screws or anything like that... it's just sticky stuff... a little bit of prying and it comes off ready for the new one... quick video of how this is done: YouTube - Removal of new civic mirror now keep in mind that i took the mirror off a few seconds beforehand and the sticky lost a bit of it stickiness so a little bit more pressure is needed than shown in the video... that does not affect the stickiness after it's set tho... it does get harder to take off once it's set again... quick pic removed:
Webby's Minion
![]() Join Date: Mar 2006
Nikon Squad Member #8
It does look surprisingly easy in the video.
![]() Thanks for the info!
Next NorCal Meet - North Bay http://i79.photobucket.com/albums/j1...ser/GGBsig.gif - 8 t h g e n u s e r - |
Six eyes
![]() Join Date: Apr 2006
Jason
Good info. When I took apart the Fiji test mirror that I got, for some reason I had to REALLY reef on it to get it off.
I'm so JDM, my girlfriend is Japanese. 私はあまりにもJDMなので、私の彼女は日本人です。 |
#4 (permalink) | |
#15 (permalink) |
Actual Mirror Replacement...
I replaced the physical mirror itself (the whole thing) by doing the following:
1) Remove the door card (this can be done with the door on or off the car). 2) Locate the 3 circular holes show below and remove the plastic grommets from them. ![]() 3) Inside the 3 holes, you will find that three 12 mm nuts hold the mirror to the door. Before you remove them, you will need to unplug the mirror harness from its connector. This should be easy to do. 4) After the harness is removed, remove the 3 nuts. Here's what it looks like on both sides when removed. ![]() ![]() Mike |
#16 (permalink) | |
#18 (permalink) | |
DIY: '08 Coupe Aftermarket Mirror LED Turn Signal Install Removing motor/mirror from assembly? |
#19 (permalink) |
Hey,
I have searched but could not find anything regarding mirrors and how to replace the 'casing' or 'shell' I currently have the black plastic look going on, but was going to order some shells/cases for the body color of my civic, I am not sure how to go about removing the plastic and then adding the metal colored shells... I don't want to replace the WHOLE mirror, just the casing/shell that is colored the same as the car, depending on the model. Is that confusing? |
#20 (permalink) |
Andy
Anyone know if you can buy just the passenger's side glass without the "objects in mirror are closer than they appear" text? No the whole mirror housing, just the mirror itself? I have decals I want to put on each mirror at the bottom in place of the existing text (which is only on the passenger's side). Link please, thanks!
LinkBack to this Thread: http://www.8thcivic.com/forums/exterior-style-mods/73542-diy-mirror-replacement.html
| Instalar Retrovisor com pisca do EXS no LXS | This thread | Refback | 08-11-2011 05:29 PM | |
| DIY: OEM Navi Conversion to DVD Receiver/Etc. | CameronJr9 | Audio | 55 | 02-04-2012 05:38 PM |
| X intake DIY + Install vids + AFR and Dyno Comparisons | CaliGuy | Engine | 923 | 08-21-2011 07:34 PM |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY | Jrfish007 | Do It Yourself Articles | 83 | 05-10-2011 09:19 PM |
| DIY Intake Video...The Moment You Guys Have Been Waiting For......... | Dwn4nythng | Engine | 159 | 12-30-2007 05:05 PM |
| My adventures in modding: a "Blog" of sorts | Phalanx | North-East | 63 | 10-18-2007 01:09 AM |
