Go Back   8th Generation Honda Civic Forum > Civic Technical > Do It Yourself Articles > Exterior Style Mods
Old 04-09-2008, 08:43 PM   #61 (permalink)
fg2!kid's Avatar
エリク eric
Originally Posted by ErichPryde View Post
the Red wire I am referring to is the power wire at the back of your turn signal bulb. you can clearly see it pictured in the DIY pictures near the bottom. You shouldn't have to do anything with the wiring diagram or the hazard wires, this is a simple splice-into-the-turn-signals kind of thing.
k got it thanks
fg2!kid is offline
Old 04-10-2008, 06:56 PM   #62 (permalink)
hc806's Avatar
Harry
gj but i dont lek side markers on our coupe imo
hc806 is offline
Old 04-10-2008, 07:38 PM   #63 (permalink)
sk8nava's Avatar
Justin Case
Nice DIY man....looks good!!!
FG Crew #65
sk8nava is offline
Old 04-11-2008, 12:30 AM   #64 (permalink)
fg2!kid's Avatar
エリク eric
well i have been looking at some pics of the FD2 it seems like the side marker is flush with the wheel cutout on the fender lower then the pics that have been posted
fg2!kid is offline
Old 05-19-2008, 02:46 AM   #65 (permalink)
Check out my JDM dual-color LEDs sidemaker DIY.
ay01 is offline
Old 05-19-2008, 03:13 AM   #66 (permalink)
Sorry, the last pic is only a GIF simulation and it's not correctly made.
ay01 is offline
Old 06-03-2008, 07:56 AM   #67 (permalink)
Moderator
ErichPryde's Avatar
Erik
This is correct. the sidemarkers on the FD2 are lower than the sidemarkers that are pictured. when I installed my sidemarkers, I went to great pains to ensure that they were essentially in the same location as CrackthatTec45's, JrMartinez's, and a couple of other members here.
Please note that in the DIY I suggest that since there is no incarnation of the FG2 with sidemarkers, you can essentially put them where you wish (as long as they are even) and you don't really need to follow my measurements.
Originally Posted by Slowride View Post
My only Si complaint is that I opened the radiator cap with the car running at full temp, and though common sense would have told me otherwise, I got sprayed in the face with scalding hot liquids.
ErichPryde is offline
Old 06-04-2008, 02:01 AM   #68 (permalink)
fg2!kid's Avatar
エリク eric
yea i ended up doing it more like the fd2 lower ill take pics and post them up
fg2!kid is offline
Old 06-04-2008, 08:11 PM   #69 (permalink)
Truplatano's Avatar
Felix
how do you pop out the sidemarkers to change the bulbs?
Truplatano is offline
Old 06-04-2008, 08:34 PM   #70 (permalink)
Cr8tive_leo's Avatar
Adrian
You don't.
You reach up , twist the socket and it comes out. replace teh bulb, and re-insert the socket into the sidemarker.
Cr8tive_leo is online now
Old 06-08-2008, 03:29 PM   #71 (permalink)
fg2!kid's Avatar
エリク eric
hear's mine .....
fg2!kid is offline
Old 06-08-2008, 03:32 PM   #72 (permalink)
Ahhh! Domokun!
Ruthless909's Avatar
4dr WhOrE!!!
Looks good fg2k!d....
Ruthless909 is offline
Old 06-08-2008, 04:14 PM   #73 (permalink)
fg2!kid's Avatar
エリク eric
thanks
fg2!kid is offline
Old 06-09-2008, 02:47 AM   #74 (permalink)
Moderator
ErichPryde's Avatar
Erik
thanks
did you line it up bulb to bulb? Also, I'd like to see some additional pictures/angles if you've got them.
looks good!
Old 06-09-2008, 02:48 AM   #75 (permalink)
Moderator
ErichPryde's Avatar
Erik
Originally Posted by Cr8tive_leo View Post
You don't.
right- you change the bulb by removing the fenderlining and popping the bulb out JUST like you would change your turn signal bulb. or a headlight.
Old 07-07-2008, 10:39 PM   #76 (permalink)
eh3
eh3's Avatar
Jordan
PAINT:
After you've got all of your cutting done, you'll want to do your primer and touch-up paint. wait ten minutes or so between coats of primer and paint- I recommend two layers of each. be careful not to get paint on your finish!
IF you decide to use a silicone sealant like I did, you will have to wait for the paint to dry completely, because otherwise the sealant will take it right back off.
Very nice write up! ! +rep
My only question... what did you paint? Around the signal because it got a little scratched while cutting...?
eh3 is offline
Old 07-07-2008, 10:43 PM   #77 (permalink)
Adrian
the area you cut, prime and paint to make a protective seal. you can add some clear silicon to that too if you really want (I did a little to be different)
Old 07-09-2008, 03:35 PM   #78 (permalink)
would you need to add a relay?
et0201 is offline
Old 07-10-2008, 01:58 AM   #79 (permalink)
fg2!kid's Avatar
エリク eric
no
fg2!kid is offline
Old 07-10-2008, 03:47 PM   #80 (permalink)
Yeah... that's me
FBP FG2's Avatar
Great DIY. I have everything I need. I'll be cutting into my fenders this Saturday and I will be putting it in the same spot as fg2!kid.
2006 Honda Civic Si Coupe
CLICK ON MY SIG FOR MY RIDE THREAD
FS: BNIB VIS OEM CF Hood for 2 Door FG
FBP FG2 is offline
LinkBack to this Thread: http://www.8thcivic.com/forums/exterior-style-mods/70037-sidemarker-diy.html
YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 2 This thread Refback 03-01-2008 01:02 AM
YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 1 This thread Refback 02-04-2008 07:38 PM
YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 2 This thread Refback 01-15-2008 09:34 PM
YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 2 This thread Refback 01-09-2008 02:20 AM
Honda » Sidemarker DIY This thread Pingback 12-19-2007 09:18 PM
Thread Thread Starter Forum
