Go Back   8th Generation Honda Civic Forum > Civic Technical > Do It Yourself Articles > Exterior Style Mods
Old 01-02-2008, 02:30 AM   #41 (permalink)
Sambos | We the BEST!
infinite0216's Avatar
Andy
did the install a couple of days ago.. thursday i think and wow did this DIY help. thanks alot and anyone can do it. if not and need help in riverside county, let me know.
but thanks alot! this is a great diy!
+1 for u!
infinite0216 is offline
Old 01-02-2008, 07:02 AM   #42 (permalink)
Cr8tive_leo's Avatar
Adrian
Originally Posted by ErichPryde View Post
the sedan has the turn signals in the sidemirrors option- you could also go with that.
Oryl... do tell, I'm interested in doing this. (which wires in the side mirror to use would be the info I am looking for) thanks.
Cr8tive_leo is offline
Old 01-02-2008, 05:02 PM   #43 (permalink)
Moderator
ErichPryde's Avatar
Erik
the side mirrors I am talking about are the ones from the hybrid- I actually don't know much about wiring them, but the hybrids I have seen only use them as turn signals. the wiring should be something like that.
Try looking for someone who has replaced their sedan side mirrors, maybe? I'll look around and see if there's any more information.
ErichPryde is offline
Old 01-02-2008, 05:53 PM   #44 (permalink)
Jennifer
Great writeup! They look good on your FG.
jennerz22 is offline
Old 01-02-2008, 06:51 PM   #45 (permalink)
Adrian
It's all good, I didn't think the non-hybrids had it. There are DIYS on installing the hybrid mirrors and such. No worries.
Excellent write up.
Old 01-07-2008, 06:59 AM   #46 (permalink)
Moderator
ErichPryde's Avatar
Erik
thanks! :)
Originally Posted by ethlar
thats a negative ghost rider, the pattern is full
Old 01-08-2008, 03:24 PM   #47 (permalink)
Andy
i just finished creating the video for this. it's publishing, then i gotta split it into two parts then upload to youtube. should be up by tonight. hopefully mods can move it into the main part of the diy.
Old 01-08-2008, 10:38 PM   #48 (permalink)
Andy
here are the videos as promised, if erichpryde approves.. then hopefully it can be made part of the diy.
YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 1
YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 2
each video is almost 10 mins.
Old 01-09-2008, 11:39 PM   #49 (permalink)
Image Hosted by ImageShack.us
Toys For TotsMember
updated this on the first post...
bizzybearfigiblue is offline
Old 01-09-2008, 11:40 PM   #50 (permalink)
Moderator
ErichPryde's Avatar
Erik
every single person who reads this thread should thank bizzybear- he has helped me redit this DIY on several occasions to make it better.
Old 01-10-2008, 12:16 AM   #51 (permalink)
Andy
thanks bizzy and erich..
now people can come to more then one person for cutting.
oh and if ur in socal, i'd be more then happy to help you in ur cuts or just guiding u incase the videos weren't enough!
Old 01-10-2008, 12:33 AM   #52 (permalink)
Toys For TotsMember
thanx guys for all ur hlp with doing this mod so that others can see how it's done...
erik i fixed ur last post... thanx for putting that tho...
Old 01-21-2008, 06:56 PM   #53 (permalink)
The_D_Money's Avatar
Don
Thanks guys! Now I just gotta grow some balls and do this. I've had the sidemarkers for 3 months now, no "custom" shops around here want to do this. Looks like I may be my only choice. Great DIY!
The_D_Money is offline
Old 01-24-2008, 09:54 PM   #54 (permalink)
sleeperone's Avatar
08 TW accord coupe
very nice DIY
sleeperone is offline
Old 01-27-2008, 01:27 AM   #55 (permalink)
MeDetail4ULongTime
maiku's Avatar
Maiku (m-ai-k)
If you want option 3, wire your power wire from the sidemarker to the turn signal to the blue or brown wire and your sidemarker ground wire to the red wire.
hmm... I'll have to try that. here I thought I tried everything.. I was using relays, flashers.. nothing would work right. I wanted it to act exactly as the turn signal would. the best way would be to find a harness with 3 wires and a dual purpose bulb.
anjeru wa sugoi ne? ^_^v
maiku is offline
Old 01-27-2008, 01:56 AM   #56 (permalink)
Moderator
ErichPryde's Avatar
Erik
when you wire it like that, here's essetially what's going on-
when the turn signal is active, the wire not supplying power to the sidemarker acts as a ground wire.
when the parking lamp is active, the wire not supplying power to the sidemarker acts as a ground wire.
when both the parking lamps and the turn signal are active, both wires are trying to provide power to the sidemarker. there IS no ground, and this breaks the circuit, so the sidemarker turns off.
this wiring setup causes it to wig-wag ONLY when the parking lamp and turn signal are both on. If there was a 3 wire harness and a two stage bulb that would fit the sidemarker, I think that would make work in the same fashion all the time... too bad there isn't one.
but hey! I'm pretty happy with how it works right now.
Old 01-27-2008, 02:37 AM   #57 (permalink)
not for me but for each his own
deviousin10tion is offline
Old 04-09-2008, 01:54 AM   #58 (permalink)
fg2!kid's Avatar
エリク eric
well i just got some sidemarkers and iam going to be doing the install this weekend and iam looking at my wireing drigram and the only red wire i see is for the for the hazerd switch
fg2!kid is online now
Old 04-09-2008, 10:04 AM   #59 (permalink)
Moderator
ErichPryde's Avatar
Erik
the Red wire I am referring to is the power wire at the back of your turn signal bulb. you can clearly see it pictured in the DIY pictures near the bottom. You shouldn't have to do anything with the wiring diagram or the hazard wires, this is a simple splice-into-the-turn-signals kind of thing.
Old 04-09-2008, 10:52 AM   #60 (permalink)
Adrian
Hey, Hmmm.. Bizzy is coming to Montreal.. maybe I trek there and we can do some Sidemarkers.. hmmmm...
WOO!
J/K, mine arrive shortly, thanks all for this DIY, surely takes the angst out of it.
LinkBack to this Thread: http://www.8thcivic.com/forums/exterior-style-mods/70037-sidemarker-diy.html
YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 2 This thread Refback 03-01-2008 01:02 AM
YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 1 This thread Refback 02-04-2008 07:38 PM
YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 2 This thread Refback 01-15-2008 09:34 PM
YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 2 This thread Refback 01-09-2008 02:20 AM
Honda » Sidemarker DIY This thread Pingback 12-19-2007 09:18 PM
