Go Back   8th Generation Honda Civic Forum > Civic Technical > Do It Yourself Articles > Exterior Style Mods
Old 05-04-2007, 05:36 AM   #81 (permalink)
MrEmO's Avatar
Originally Posted by MrEmO
im sure you can find a bracket just like it at any hardware store
i bought the part. but im sure you can make one yourself. if you guys would like me to make a DIY on how to make one yourself, just lemme know. ill try to stop by home depot when i have time and take pictures of brackets that might work.
MrEmO is offline
Old 05-04-2007, 11:22 AM   #82 (permalink)
Coastale's Avatar
What MrEmo said. . .
I've just seen that a couple of times (not recently) where people think "look at my lack of plate!" is clever. That's middle school humor.
Coastale is offline
Old 05-06-2007, 05:44 AM   #83 (permalink)
sk33ny's Avatar
Aaron
Just did this on my sedan and it worked well.
But instead of cutting up the frame, when i flipped the mount upside down i noticed it would fit perfectly in the grill. But the holes where offset slightly.
So i thought about using some nuts, washers and long screws.
So i looked around and eventually found some Crown Bolt wall mounts.
(http://www.homedepot.com/prel80/HDUS...4+4078&pos=n20)
They worked perfectly. I think if you put a little Loctite on there it wont go any where.
sk33ny is offline
Old 05-06-2007, 05:55 AM   #84 (permalink)
sk33ny's Avatar
Aaron
Well i just found out the hard way that you cant edit your posts, so sorry for the double post. After posting, i noticed the link doesnt work. So i found a link that does. (note: These arnt the exact bolts i used, there just a example)
http://www.homedepot.com/prel80/HDUS...=12-23334346-2
sk33ny is offline
Old 05-06-2007, 11:52 AM   #85 (permalink)
Gyro's Avatar
James
I have an '07 coupe and I just did the flip. No dremel tool, but a Swiss Army Knife worked fine (just gotta be patient). Very helpful DIY and looks a lot better than the OG way.
Gyro is offline
Old 05-06-2007, 06:00 PM   #86 (permalink)
06RREX's Avatar
Drew
^^ Yeah I did it to my car and it looks A+. Especially in central Ohiya... where do you live at Gyro?
06RREX is offline
Old 05-06-2007, 10:12 PM   #87 (permalink)
Moisted's Avatar
I noticed the same thing, the frame when flipped fits perfectly in the grill if you drop it one notch lower. But the problem is the screw holes (on the grill and the frame) now won't align; the frame is a little lower.
I still haven't come up with a way to overcome that problem, do you have a picture of how you used that part from Homedepot?
Moisted is offline
Old 05-06-2007, 10:23 PM   #88 (permalink)
*loving not having to have a front plate*
Cam
Camshaft2 is offline
Old 05-06-2007, 11:52 PM   #89 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
Did you cut anything?
Yodums is online now
Old 05-07-2007, 04:07 AM   #90 (permalink)
sk33ny's Avatar
Aaron
I dont have any pictures, but i can describe it.
I just hooked the crown bolts onto the back of the grill and used long screws.
No cutting, no modifying. I used the factory holes in the license plate frame. If the heads on the screws arnt big enough, just throw some small washers on there.
You can probably also use washers instead of crown bolts, but they would be a pain to get on there.
sk33ny is offline
Old 05-07-2007, 04:52 AM   #91 (permalink)
haha i did the same today( actually yesterday at this time). i used a Swiss Army Knife. it took a good 15 minutes. or maybe 30....
crazi3 is offline
Old 05-07-2007, 09:17 AM   #92 (permalink)
Moisted's Avatar
I see... thanks. I will attempt this tonight or tomorrow, and will take pictures as I'm doing it.
Moisted is offline
Old 05-08-2007, 12:47 PM   #93 (permalink)
K757's Avatar
Keith J (CP3 owner)
Great tip! THANKS
K757 is offline
Old 05-08-2007, 12:50 PM   #94 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
Originally Posted by K757
ROFL @ Your front plate. It's even positioned in a way so the people looking in the rear view mirrors will read it correctly.
Old 05-09-2007, 07:19 PM   #95 (permalink)
07NytHwk's Avatar
just did this. shouldve come that way from the factory. then i guess i would have to flip it the other way though!!!
07NytHwk is offline
Old 05-11-2007, 11:09 AM   #96 (permalink)
Englishe30's Avatar
Mark
Took a little longer than expected but it was worth it I am satisfied....Great DIY and easy to boot...
Englishe30 is offline
Old 05-11-2007, 11:14 AM   #97 (permalink)
shawn-o's Avatar
holy crap, Im suprised this has been used by so many people. Go me!
Most done DIY FTW!!!
shawn-o is offline
Old 05-11-2007, 12:03 PM   #98 (permalink)
Moisted's Avatar
+rep
Moisted is offline
Old 05-11-2007, 12:35 PM   #99 (permalink)
brdhouse's Avatar
Lloyd Christmas (Bill)
I did this awhile ago too. To get a better fit (and to get rid of the gap), I also knotched out the section that overlaps the bumper as well as took down the bottom (formally top) edge that rests on the lower lip. I used a rounded file (rasp). here's a pic of what it looks like:
brdhouse is offline
Old 05-21-2007, 04:16 PM   #100 (permalink)
what length screws are u guys with sedans using for this, i gotta go buy some before i finish..
stylez23 is offline
LinkBack to this Thread: http://www.8thcivic.com/forums/exterior-style-mods/16473-diy-front-license-plate-flip-w-pics.html
Front License plate - Page 2 - GreenHybrid - Hybrid Cars This thread Refback 03-01-2008 01:15 AM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-19-2008 10:44 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-03-2008 08:16 AM
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
