DIY: Moonroof Visor Removal - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Civic Technical > Do It Yourself Articles > Exterior Style Mods
Old 10-04-2008, 01:40 PM   #1 (permalink)
ooskers's Avatar
I didn't like the look of the moonroof visor on my car so I decided to remove it. Today I finally got around to it and figured that I would make a DIY as well!
Things you will need:
Pliers - I chose needle nose
Screwdriver - Phillips head
Some rags
Something to clean up dirt and scratches (Polish - not like the wax I have pictured below)
The first thing you will want to do is open the moonroof all the way. Look under the visor and you will see a black ribbed bar (at the very front of the moonroof opening) and some brackets holding the visor in place. On top of the visor are four screw heads.
In the picture below, I have circle two of the brackets in red.
You can now remove the two outside screws. Reach under the spoiler with your pliers and grasp the small plastic nut under the screw. Then, start backing the screw out. Once your are done with that, set the screw and nut aside and slide the black bracket out.
Then do the same for the two screws in the middle. To remove the brackets, push down on the ribbed black bar. It is plastic and should be very obvious. This is the easiest way to remove the inside brackets. Notice that the inside brackets are longer than the outside ones. You should wind up with this hardware in the end.
Depending on how long the visor has been on your car, you may notice a lot of dirt under the rubber gasket. I had mine on for a little over five thousand miles and there was quite a bit of dirt. Over time, the visor left two parallel scratches on my roof.
In my first picture, I have a jar of wax representing the item that you will need to clean up. I would take a rag to wipe off the dirt and asses the damage. I plan on buying some polish to work the scratches out. They aren't terribly deep but they are long and have dirt in them to make them very overt.
Removing the visor is painless. Hopefully you won't have a set a scratches to remove. I'm not too bent out of shape though. Reply or PM me if you have any questions!
ooskers is offline
Old 04-06-2009, 02:32 AM   #2 (permalink)
p1904's Avatar
Micho Rizo
Good write up
p1904 is offline   Reply With Quote
Old 05-16-2009, 12:40 PM   #3 (permalink)
I need to do this.
n612ua is offline   Reply With Quote
Old 05-20-2009, 10:46 PM   #4 (permalink)
8thhere's Avatar
one question, are the steps for removing all honda Moonroof Visors the same?
8thhere is offline   Reply With Quote
Old 05-20-2009, 10:53 PM   #5 (permalink)
Jeff Butler
Would that be a coupe that you have? if so would you be willing to sell the visor?
JBut1987 is offline   Reply With Quote
Old 06-21-2009, 07:01 PM   #6 (permalink)
BaconSampler's Avatar
Cool.
BaconSampler is offline   Reply With Quote
Old 03-24-2011, 02:02 AM   #7 (permalink)
gt35rdanny's Avatar
nice diy
gt35rdanny is offline   Reply With Quote
Old 03-24-2011, 10:14 AM   #8 (permalink)
RitcheyRch's Avatar
Rich
Nice DIY. I'm sure glad the previous owner never installed one of these on the car.
RitcheyRch is online now   Reply With Quote
Old 06-12-2011, 01:29 PM   #9 (permalink)
nice diy
deff doing
07joe4drsi is offline   Reply With Quote
Moonroof Visor?? IceMurder Civic SI 6 08-08-2008 06:44 AM
So I just took my moonroof visor off... definingmoment Inside and Out 22 06-15-2007 09:57 PM
Moonroof Visor!!! TheRumBucket Inside and Out 13 04-20-2007 11:34 AM
