Installed DCRH & Tanabe catback!! - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Civic Technical > Bolt-Ons And All-Motor > Exhaust Discussion
Old 11-02-2006, 02:33 PM   #1 (permalink)
RomesKdUB's Avatar
Roman
i installed my DC racing headers and Tanabe touring medallion exuast on weds. I was a *****! lol. Tuesday night i stayed up all night tryna get the damn screws off of the stock peices. Finally after 3 1/2 hours of scratches and dirtyness, i took everything out with the exception of one bolt of the stock header.i woke up the next morning and finally got it off and was tuggling to get the right agle to take the header out. It was another tussle getting the DCRH in but finally did. Then through on the Tanabe on..ITs sweet@!!!! lol. its fairly quiet but today its starting to get louder. i feel the difference like whaaaa!
???My question is that if there is supposed to be like a little rattling under the car once in a while when i reverse or take off??? i am pretty sure that i tightend all the bolts and got the hooks of the exaust into the rubber sleeves/holdings. ive heard that that goes away after a while???? So if anybody has any answeres i would appreciate it..THANKs!
RomesKdUB is offline
Old 11-02-2006, 03:08 PM   #2 (permalink)
It should not rattle. It could be because you put the tanabe on instead of going with the DC catback. Im not sure though. Also, it could be one of the rubber hangers came loose or something. Hope it works for ya!
vetkiller is offline   Reply With Quote
Old 11-02-2006, 03:52 PM   #3 (permalink)
finally someone else that has that problem. i have the race header and the stock exhaust and i get that same rattle. it's only on startup and when i go into reverse.
jkocr2 is offline   Reply With Quote
Old 11-02-2006, 04:04 PM   #4 (permalink)
Hankey723's Avatar
John
Its bcause you bought a DC Sports product ..
Hankey723 is offline   Reply With Quote
Old 11-02-2006, 04:14 PM   #5 (permalink)
mort's Avatar
I got that rattling on my older civic. It was the shift linkage touching the exhaust pipe. Not sure if it applies here though..
mort is offline   Reply With Quote
Old 11-02-2006, 04:25 PM   #6 (permalink)
no shift linkage here. cable linkage on the new si
Old 11-02-2006, 04:27 PM   #7 (permalink)
And you know this because you've had a bad experience? or are you just going off what others tell you
Old 11-02-2006, 04:34 PM   #8 (permalink)
blaznhot_23's Avatar
MS Motorsports kicks ass!!!
did you torque all the bolts back down to specs or close to??? also check your connenction from the end of the header back where the collector is. i would assume its some on the exhaust is not tightened properly because you said it only does on start up...the exhaust when it gets warm expands and takes it some slack when you start driving partially eliminating the noise....double check every bolt and connection when cold is what i suggest
blaznhot_23 is offline   Reply With Quote
Old 11-02-2006, 04:44 PM   #9 (permalink)
checked all bolts and tightened everything to spec then retightened after 500miles. I have a feeling it's just rattling against the heatshield. I don't notice it so much anymore.
it sounds as if it's coming from directly below the shifter when sitting in the car.
Old 11-02-2006, 05:43 PM   #10 (permalink)
civsnake's Avatar
English Classassin
I don't know what the fitment and clearance is like for DCRH, but if it's closer to the firewall or other components the issue could be engine movement. If the header is attached to the back of the engine and the engine twist along an axis under power it would move the header and exhaust along with it. I may only happen in reverse because the suspension loads in a different direction and could be shifting obstructions closer to one of the exhaust components that would move away from those components under forward motion. I dunno, just a theory.
If that were the case, you would have to either find the point of contact and add a buffering material or get stiffer engine mount bushings.
civsnake is offline   Reply With Quote
Old 11-02-2006, 06:22 PM   #11 (permalink)
stevenshizzle's Avatar
Steven
I had this same problem with my older civic. Never pinpointed the problem though.
stevenshizzle is offline   Reply With Quote
Old 11-02-2006, 06:23 PM   #12 (permalink)
hatchbac_smokin_you's Avatar
it is prolly the flange...
hatchbac_smokin_you is offline   Reply With Quote
Old 11-02-2006, 06:43 PM   #13 (permalink)
tmac1221's Avatar
Tim
Question
How do you like the set-up besides the rattle, sound and performance wise? I was thinking about the same set-up...
tmac1221 is offline   Reply With Quote
Old 11-02-2006, 08:58 PM   #14 (permalink)
thats a good question for many like myself...
Old 11-02-2006, 10:26 PM   #15 (permalink)
tmac1221's Avatar
Tim
I'd really like to see some vids. And let us know if you figure out that rattle. Do you think it's because of the way it fits with the tanabe, or just the header itself. Any plans on dynoing it? Thanks dude.
Old 11-03-2006, 12:44 AM   #16 (permalink)
Hankey723's Avatar
John
Going off past experiences ... I rather find out for myself then judge something just because everyone else is.
Old 11-03-2006, 06:12 AM   #17 (permalink)
RomesKdUB's Avatar
Roman
Ima grab a legit camara and try to get some footage tomorow.. the combinations sound sweet actually. i could still hear my sri sucking in hella air...then that little hiss and power sound from the dcrh.and finally that nice growl from the tanabe..i think the sound is just perfect..not super rice loud like my old pipe..it like a sleeper or luxury sports. the tanabe is starting to get a bit deeper in these last days which is great for me its just what i expected. I just installed on weds morning so hopefully the rattling goes away..i really want to get under it and pin point the rattles. BUt other than that i think its a great setup..
RomesKdUB is offline   Reply With Quote
Old 11-03-2006, 06:19 AM   #18 (permalink)
RomesKdUB's Avatar
Roman
ya im gonna try getting under it one of these days prolly tomorrow..the tanabe fits perfect with the dcrh. same demensions as the triangle pattern of the dc..the gaskets that come with the tanabe fit perfectly also..i think ya like everybody is saying thats its probably the black semi circle heatsheild/cover that is directly below the header where it begins to bend straight. but also could be the rubber mounts that the exaust and headers rest on..
About dynoing it...lol..i was just gonna do it today..i really want to dyno it..i know a place pretty close..theyre charging like 150$ per hour..and tune like i think he said 200 per hour.
Old 11-03-2006, 06:24 AM   #19 (permalink)
RomesKdUB's Avatar
Roman
sound and performance is GReat i love the mid to high range in it.. i have on 6th in the freeway going about 70-80 and it picks up alot faster..im talkin youll be like what im doing 112 already!? lol.setup makes a sleeper also..the tip the tanabe is chill..ima try to get some footage tomorrow l
Old 11-03-2006, 12:19 PM   #20 (permalink)
hook up those vids...if you can get some shots of the header installed on the car i'm curious how the whole setuo looks like...thanks
LinkBack to this Thread: http://www.8thcivic.com/forums/exhaust-discussion/18914-installed-dcrh-tanabe-catback.html
Installed DCRH & Tanabe catback!! - 8th Generation Honda Civic Forum This thread Refback 12-13-2007 08:25 PM
Tanabe Medallion Concept G axleback installed on EX Coupe stevieray Bolt-Ons And All-Motor 27 10-08-2007 02:42 AM
Installed Tanabe Sustec Underbrace larryd Suspension and Brakes 51 11-14-2006 10:43 AM
Anyone have Tanabe Medalion Touring Catback Exhaust? ShaggySi Exhaust Discussion 26 09-02-2006 05:31 PM
PIC REQUEST: Tanabe Exhaust BLU BY U Exhaust Discussion 6 06-04-2006 12:49 AM
TANABE OR GREDDY CATBACK EXHAUST? irichard Turbocharging 5 05-01-2006 06:31 PM
