#101 (permalink) | |
#102 (permalink) |
8thcivic Sponsor
We've heard 1 report of alignment of the 2 existing holes in the rear swaybar endlink bracket being different than our part. We did measured 2 cars and they were both the same, but it's possible that not all cars are the same.
Please let us know if your RedShift brackets align correctly or not. Thanks, Chris at RedShift |
#103 (permalink) | |
Webby's Minion
#104 (permalink) |
8thcivic Sponsor
I don't have that info specifically. It's on another Excelerate Thread in this forum.
Progress Sway Bar Special!!! Chris |
#105 (permalink) | |
#107 (permalink) |
Location: NorCal Most Of The Time / SoCal Some Of The Time
#108 (permalink) |
Ok, here's what I found If you flip the bracket one way there are alignment issues flip it back and no problem at all the install was a breeze!!!! Just follow your instructions and you should be done in about 20 min. tops! Sorry no pics as they look just like the pics in the instructions. These were installed on a 2007 Civic Si Sedan. Handling is much improved as the back of the sedan feels like it's in the back of my driver's seat now.{tight} Unfortunalty I'm running taller profile tires for winter and now the sidewall is flexing to death so, no radical moves right now just enjoying the expressway ramps at crazy speeds! Enjoy boyz!!!!!!!
#109 (permalink) | |
http://www.redshiftmotorsports.com/I...20SU06CSRB.doc |
#110 (permalink) |
i thought for 55 dollar pair of washers that the brackets would be perfect alignment. they are not. both washers are different dimensions. you can tell by the pictures that they do not fit very well. i am not that satisfied. i will make my official opinion thurs morning when i get a chance to throw them on the car. but so far by the alignment of it, i am not that happy.
![]() ![]() ![]() here are some bird eye view DIRECTLY above the brackets. i am not angling the camera, the brackets were drilled poorly and machined poorly. ![]() ![]() Last edited by 20civic07; 03-05-2008 at 12:18 AM. |
#111 (permalink) |
8thcivic Sponsor
Doesn't really matter side to side like you have them setup, sandwiched together...That makes no difference...I am sure that they will fit FINE!! ON BOTH SIDES...
BUY MY CIVIC |
#113 (permalink) |
8thcivic Sponsor
They do only go one way...
"Ok, here's what I found If you flip the bracket one way there are alignment issues flip it back and no problem at all the install was a breeze!!!!" HondaRacer Said that...If you have any install issues PM me for my Phone number I will help u... ![]()
BUY MY CIVIC |
#115 (permalink) |
8thcivic Sponsor
^^^Better wording than me
BUY MY CIVIC |
#117 (permalink) |
8thcivic Sponsor
As you are just adding an additional mounting location so as long as the exitsting hold and the endlink hole aling then your fine...
If its OFF Pm me I will get u a set I have personally tested.. ![]()
BUY MY CIVIC |
#118 (permalink) | |
8thcivic Sponsor
20civic07, and everyone else, From my point of view, these should be perfect. They were laser cut from our drawing and there is no reason they should be different. The outside of the part can be +/- 1mm so that's not bad (although I am puzzled by this because I personally QC'd about 10 sets and saw nothing like this). But the tolerance of Co2 Laser Cutting is .002"; so there should be very little variation overall. It's possible that the threading process is affecting it, but even that shouldn't cause any significant change in centerlines. The part is meant to have a bit of tolerance (.01" or so) built in for ease of install, like everything else in the world. Please let me know if you have a problem with the install. Chris at RedShift |
#119 (permalink) |
Make sure you have them facing in the correct direction if they don't line up flip them and everything should be fine. When you drill the new hole deffinetly use the larger size the 11/32 it made everything go together that much easier. This was a very simple install. Although I never stuck the 2 brackets together I had no problems with the install and it only took aprox. 20mins. for the brackets to go in place.
Handling!!!! thanks boyz for creating them! |
