DIY Cat-Back Exhaust S.I. 06-08
Exhaust installed is LSD Power 4
Tools needed 1/2 inch breaker bar for the 14mm nuts there on there tight ! ratchet 14MM socket 10mm socket White grease Spray can PB blaster Behind the cat there are 3 14MM bolts spray PB blaster to loosen up rusted nuts let them soak for minimum 10 minutes Once all 3 14mm nuts are removed spray white grease on all the hangers !!! this will make everything a breeze there a 3 hangers you will need to soak in white grease once the exhaust no longer hangin from the hangers you have to remove 2 10MM bolts Holding the axleback exhaust these can be easily reached by just spinnin the entire exhaust to the desired location where you can remove those 2 axleback nuts Removal of the rear passenger wheel will be neccesary and make everything real easy once axleback is removed everything just floats right off ON NEW EXHAUST >>>spray white grease on ALL hanger locations put everything on LOOOOOSE once everything is on now you can tighten all bolts ![]() ![]() ![]() ^^^^^ ^^^^^^^ ^^^^^remove rubber hanger and relocate onto new exhaust ![]() ![]() ![]() ![]() ![]() ![]() hope this was some kind of help took me about Hour and a half since i was by myself and had to find extra wood in the backyard to stack up under the car just to insure my safety ALWAYS USE STAndS for car i didnt have any so i used 2 jacks and 2 large stacks of wood lol goodluck ![]() ^^^ ^^^^^ ^^^^ ^^ you can see the wood i used and how i stacked it up Last edited by 07_FG_4Dr_S.i.; 05-13-2008 at 07:34 PM. |
#3 (permalink) | |
I Would have to say yes because behind the the rotor there are 2 10mm bolts to remove axle-back I mean you could try without but I saw it as impossible so I just threw up the e brake and removed tire its a piece of cake better to take 3min to take wheel off then get mad and struggle with trying to remove those bolts
| DIY installation of Exhaust Axle back? | KEVtec | Bolt-Ons And All-Motor | 6 | 11-15-2007 11:34 AM |
| Cat-Back Exhaust for '06 Civic Choices | peliROJO | Bolt-Ons And All-Motor | 28 | 08-22-2006 09:16 PM |
