Old 03-18-2008, 12:19 AM   #21 (permalink)
Survivor's Avatar
Originally Posted by rotor_powerd View Post
I've seen a 8.5:1 VR6 put out 210 PSI in more than 1 cylinder.
Probably the cam itself was advanced which can cause an increase in pressure.
Survivor is offline
Old 03-19-2008, 04:52 AM   #22 (permalink)
20civic07's Avatar
i'm sure people will want to know how to do this so im bumping this
20civic07 is offline
Old 03-19-2008, 05:06 AM   #23 (permalink)
Behind Firmhonda's beard, there is only another shaved beaver.
ErichPryde's Avatar
Erik
Moved into the DIY index. very nice!
Originally Posted by Slowride View Post
My only Si complaint is that I opened the radiator cap with the car running at full temp, and though common sense would have told me otherwise, I got sprayed in the face with scalding hot liquids.
Originally Posted by ImTheVoiceOfGod View Post
But I dont wanna be banned
ErichPryde is offline
Old 03-23-2008, 01:37 AM   #24 (permalink)
fg2!kid's Avatar
エリク eric
cylinder volume has a roll in what kind of reading you get from enging to engine too
fg2!kid is offline
Old 03-24-2008, 03:30 PM   #25 (permalink)
+ REP FOR YOU
I've been waiting for something like this for a while. you're awesome
rcracin13 is offline
Old 03-24-2008, 04:40 PM   #26 (permalink)
20civic07's Avatar
took a while to get put in the diy forums haha... i dont know why i couldnt post in there anymore.. but my compression was around 185 across all four cylinders... factory manual says 135 +-28psi. i talked to several techs at the dealership, they said that 185 seems normal, very healthy, 135 +- 28 seems wrong.
Old 04-09-2008, 02:24 AM   #27 (permalink)
20civic07's Avatar
anyone else get results for their test?
Old 07-18-2008, 01:31 AM   #28 (permalink)
when you do this test in the FSM it says to keep the gas floored read the manual i have all data pro
bluek20z3 is offline
Old 08-04-2008, 04:15 PM   #29 (permalink)
GlxyGry06Si's Avatar
ok. lets say that your compression is low in one of your cylinders what is the problem? How do you fix it?
GlxyGry06Si is offline
Old 08-04-2008, 04:34 PM   #30 (permalink)
kenny rogers's Avatar
Greg
At that point you will need to do a Leakdown test to determine what is causing the low compression.
kenny rogers is offline
Old 08-04-2008, 04:35 PM   #31 (permalink)
and what are some common reasons why something would cause low compression. when you lose compression what happens to the car? (poor mpg, performance, ect)
Old 08-05-2008, 04:17 PM   #32 (permalink)
Greg
^^^ There are a number of different reasons for compression loss... most of them expensive fixes. Valves, pistons, rings, headgasket... to find out which one it is you do a leakdown test.
Old 08-13-2008, 02:04 AM   #33 (permalink)
20civic07's Avatar
if you have loss of compression in one of the cylinders, you best take it to a qualified mechanic if you don't know how to diagnose it yourself.
Old 08-20-2008, 11:10 AM   #34 (permalink)
Bad piston rings, bent valves, blown headgasket.
rotor_powerd is offline
DIY Satellite Radio Install (lots of pics) geminon2k7 Audio 18 08-05-2008 07:53 PM
