Old 06-20-2008, 11:29 AM   #81 (permalink)
Lan Evo VIII's Avatar
Anthony
if i take off the valve cover, will i need to change any gaskets?
Lan Evo VIII is offline   Reply With Quote
Old 06-20-2008, 11:32 AM   #82 (permalink)
Anthony
never mind i found there answer. Hmmm why cant i edit the first post i did
Old 08-21-2008, 01:27 AM   #83 (permalink)
jackolee's Avatar
dude this is very nice. but i have one question. the cardboard doesnt burn up being in the oven for 2 hrs at 200F?
jackolee is offline   Reply With Quote
Old 08-21-2008, 10:19 AM   #84 (permalink)
Excalibur's Avatar
Jeremy
It's fine. It takes alot more to start a fire.
Old 08-21-2008, 10:55 AM   #85 (permalink)
Shreaded's Avatar
Rick
link to buy the valve cover and gasket please?
BTW, it looks great!
Shreaded is offline   Reply With Quote
Old 08-21-2008, 11:16 AM   #86 (permalink)
Excalibur's Avatar
Jeremy
Look around on different honda parts sites. You can also get it at your dealership.
Old 08-21-2008, 11:22 AM   #87 (permalink)
I am Godzilla U R Japan
St Jude
gotsnodooks's Avatar
Russ
There are a couple of valve covers, by members, for sale on the site here...just look in the for sale sections
you are still alive so that fatal error must have fail'd
Never take life seriously. Nobody gets out alive anyway.
gotsnodooks is offline   Reply With Quote
Old 08-21-2008, 11:25 AM   #88 (permalink)
Shreaded's Avatar
Rick
thnx!
Old 08-21-2008, 04:24 PM   #89 (permalink)
jackolee's Avatar
hey i looked on those sites selling honda parts but im not sure what im suppose to buy
Old 08-21-2008, 04:25 PM   #90 (permalink)
jackolee's Avatar
oh and can you make one telling how to remove the cover? cause the ones out there already arent that clear
Old 08-21-2008, 06:37 PM   #91 (permalink)
Excalibur's Avatar
Jeremy
1. Take the cowl off.
2. Take off the metal piece under the cowl.
3. Take off the spark plug cover.
4. Unscrew the 2 screws on the right side of the valve cover
5. Take off all the bolts that hold the valve cover down (break them loose first before taking them completely off)
6. Remove the spark plug coil pack from the cover (don't sit on a hot header)
7. Pull off the cover.
Old 08-21-2008, 07:03 PM   #92 (permalink)
and dont overtorque the bolts when you put it back on, the slightest bit of overtorque and they shear right off, not too expensive to replace but still sucks. i know from exp
civicsifg2 is offline   Reply With Quote
Old 08-21-2008, 08:07 PM   #93 (permalink)
infiniti_4_life's Avatar
Artem
I reused the old gasket when I installed my JDM valve cover. A honda mechanic who helped me with the install said since the car only has 15K on it, the gasket is still good. Its when the gasket is old, torn up and cracking that you replace it. I also used some silicon around the edge and 10K later, nothing is leaking and everything is perfect. (he told me if it ever starts leaking, he will come over and install a new one) I don't think that its gonna be an issue tho.
You can get a new gasket if you want, your choice.
infiniti_4_life is offline   Reply With Quote
Old 08-21-2008, 08:11 PM   #94 (permalink)
Excalibur's Avatar
Jeremy
Me too. I broke 2 of them. Use the smallest ratchet you have and just use your wrist and when it feels tight; stop. Alternate in a starlike pattern to get it to settle somewhat equally.
Old 08-27-2008, 07:13 PM   #95 (permalink)
^^^So i wont need a torque wrench? and the bolts wont come loose later?
and also when I cure the paint in the oven will it smell or anything? and that wont mess up the oven for later use when i cook food right?
and lastly how hot does it get in the engine w/ a turbo?
cto424 is offline   Reply With Quote
Old 08-27-2008, 07:18 PM   #96 (permalink)
Excalibur's Avatar
Jeremy
In the engine bay, it will get warmer, but you'll be fine as long as the hot-side isn't closer than an inch I would say.
It will smell when you bake it. Your entire kitchen and maybe more than that will smell like the paint somewhat, but it will subside as time progresses. If your wife is picky about stuff like that, do it when you have the day off and she has to work or is shopping. Maybe open the doors and light some inscents afterwards.
I didn't use a torque wrench and I broke two studs. I had to order them 8bucks a pop and tighten them just a little all around and let honda do it. I don't know what's wrong with me, but I break stuff very easily. People say it's b/c I'm big. I'm not sure if that's the problem or what, but the best of luck to ya. If you torque them down, use the smallest torque wrench you can buy and check with the dealership with what it should be at. I can't remember off the top of my head.
Old 08-28-2008, 12:59 AM   #97 (permalink)
i see thanks for the info. oh and what silicon/sealant did you use?
Old 08-28-2008, 04:38 AM   #98 (permalink)
Excalibur's Avatar
Jeremy
Where would you use sealant?
Old 08-28-2008, 09:35 AM   #99 (permalink)
GlxyGry06Si's Avatar
i think he is talking about the gasket. i have never taken it off but is there a gasket?
Old 08-28-2008, 12:02 PM   #100 (permalink)
Excalibur's Avatar
Jeremy
In that case, get a new gasket.
JDM Type R valve cover installed... blue rocket Mechanical Problems & Technical Chat 80 04-24-2009 02:56 PM
R18 Valve Cover Install Help! bad_andy0881 Bolt-Ons And All-Motor 5 02-13-2009 10:54 PM
NEED HELP valve cover gasket 7002iSciviC Bolt-Ons And All-Motor 12 01-16-2008 09:31 PM
Valve Cover Material!? therra978 Inside and Out 1 01-10-2008 10:46 PM
