Old 05-31-2008, 08:50 PM   #81 (permalink)
[hwy]Hagen's Avatar
ok this may sound noobish but instead of taking out the whole Resonator why not just disconnect the rubber tube that connects the Resonator to the air filter box? it saves time and effort! i dont know if it works or not i was just wondering for those who are too lazy to take out their bumper or inner wheel well.
[hwy]Hagen is offline   Reply With Quote
Old 05-31-2008, 08:56 PM   #82 (permalink)
07NHBCivicSi's Avatar
Curtis
You can do that and you will get the same affect in the sound of your engine but some people like to leave some of the pipeing in there so they can suck in cold air when they are moving, since just removing just that rubber tube supposedly just sucks the hot air from the engine especially at idle. But none of this should be to notieable unless you were on a dyno then maybe. hope that makes sense and helps and answers your question.
07NHBCivicSi is offline   Reply With Quote
Old 06-02-2008, 03:08 PM   #83 (permalink)
JKinATL's Avatar
Jeff
Ditto on that. You will get colder air if you leave the piping connected so that it draws air from the cavity left by removing the intake resonator.
Also, as a test, I just removed the rubber piping from the filter box and ran it like that for a weekend, and the sound was really crappy. In my opinion, it had a rough, crappy-sounding and low-pitched sound at above 3,000 RPMS... I didn't like it, so I switched back to the no-resonator-extended-piping setup, with it's really nice and easy-on-the-ears roar at high RPMS, and am staying there!
JKinATL is offline   Reply With Quote
Old 06-03-2008, 12:46 PM   #84 (permalink)
Curtis
^^^ Haha. Yeah I noticed that too. But it didnt bother me that much.
Old 06-04-2008, 09:16 AM   #85 (permalink)
dgaddis1's Avatar
I noticed a difference! To confirm my butt dyno, I borrowed a friend's GTec Pro one evening. The butt dyno was correct. Go here to see the G-Tec's "dyno" differences:
Did some testing on my car, interesting results
dgaddis1 is offline   Reply With Quote
Old 06-05-2008, 02:29 AM   #86 (permalink)
Curtis
^^ I am glad you were able to notice a difference. I just noticed a big sound difference when I had this done.
Old 08-12-2008, 09:45 AM   #87 (permalink)
FastTimesAtFGHigh's Avatar
http://jdmfg2.wordpress.com
I'm going to install the Top Fuel SRI and there's obviously no connection between the SRI and the stock resonator tubing. If I leave the resonator tubing on, will it flap around and hit things? I mean, it's not connected to the stock airbox any longer once I put the SRI in. I was gonna remove the resonator tubing altogether but you guys make a good point about leaving it in to still draw in cold air from the fender. Did that make sense?
FastTimesAtFGHigh is offline   Reply With Quote
Old 08-12-2008, 07:42 PM   #88 (permalink)
HAND BANANA!!!!!!
citizh's Avatar
JOE
so all and all this is worth it?
*Mid Atlantic Crew-#1*
Tonight....You*Dont Click*
Welcome to teh 8th!™
citizh is offline   Reply With Quote
Old 08-13-2008, 01:08 AM   #89 (permalink)
Curtis
If you want to hear your car more yea. It makes it deeper and a little louder.
Old 08-14-2008, 05:08 PM   #90 (permalink)
JKinATL's Avatar
Jeff
It probably won't flap around, but it's so easy to take out, I say go for it.
The statement that it will still draw in cold air is a myth. M-Y-T-H.
The snorkel comes out in the right of the engine bay, so that's not very cold air, but the overriding fact is that if you have no pressure gradient, you have no air pressure. The only reason air comes into the intake in a naturally-aspirated engine is because the internal combustion in the engine creates a vacumn that pulls it in. You could force air in with either a turbo or with a ram-air effect through the cowl, hood, or bumper.
Old 08-20-2008, 02:38 AM   #91 (permalink)
ummmmm's Avatar
David
When I go into the wheel well to do this, what wheel well is it? The left one or the right one? Thanks.
ummmmm is offline   Reply With Quote
Old 08-21-2008, 12:03 AM   #92 (permalink)
Curtis
The left wheel it will be right there after the fender liner.
Old 09-23-2008, 11:17 PM   #93 (permalink)
bulit184's Avatar
yo can someone please post up a video i wanna hear it!
bulit184 is offline   Reply With Quote
Old 09-28-2008, 10:01 PM   #94 (permalink)
Matt
Props on the write up and info.
I'm definitely going to do this mod. I'd like to see some pics of how the Mugen RR's airbox is setup exactly???
Not sure I have the money to get the carbon fiber airbox though! lol
agoldenau is offline   Reply With Quote
Old 09-28-2008, 10:08 PM   #95 (permalink)
R18 35+ MPG FTW!
Juan_Cheese's Avatar
Juan
Originally Posted by JKinATL View Post
For the sake of documentation, I noticed a difference:
When I first did the mod, I disconnected the pipe from the resonator that leads up to the pipe that's mounted under the battery tray, and left it as such, so that the tip of the intake system was the tip of the pipe under the battery tray. I worried, later, that this was too close to the radiator, so, like the original mod suggests, I cut off the pipe from the resonator right where it joins the resonator box, and then re-attached that to the pipe under the battery tray. After a couple days driving it like this, it seems 'punchier' than the previous version. I'm slightly baffled, because, instinct says, because the piping is longer, then throttle response should be reduced, but it's actually better. The only thing that I can think of is that perhaps it is drawing in much cooler air, from extending the intake all the way into the cavity left by the resonator. Neato!
I did this as well...
You Only Wish You Were As Fuel Efficient As I Am!
I Need A Pixel Car...
Help Is Appreciated...
Car 1
Car 2
Juan_Cheese is offline   Reply With Quote
Old 09-28-2008, 10:19 PM   #96 (permalink)
Curtis
damn talk about thread revival. lol. I am glad that my DIY is still helping people out.
Old 09-30-2008, 10:36 PM   #97 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
Originally Posted by dgaddis1 View Post
Just thought I'd post an update for this....
I have a 2008 FA5, and I removed my resonator tonight, and I was surprised to find it only mounted with two bolts; not three. My car didn't have the mount under the battery tray.
Also, I didn't remove my front bumper to get it out. I removed a panel underneath the front bumper, and part of the fender liner, and that was it.
Thanks for figuireing this out.
is Missy a squirter?
http://killyourself1.myminicity.com/tra build my city.
Old 09-30-2008, 10:45 PM   #98 (permalink)
Why remove the resonator? The stock intake brings cool air directly in from the fender well area and flows it down through the resonator up to the filter and to the intake, I don't see any head soak issues there...?
High Revs Si is offline   Reply With Quote
Old 10-01-2008, 12:24 AM   #99 (permalink)
Curtis
People do this beacuse it seems like there is a little bit more response and it makes your car louder but a nice loud. Its like a deeper sound from your engine and a little from your exhaust.
Old 10-01-2008, 01:39 AM   #100 (permalink)
Teach me how to take pics
maximus20895's Avatar
Max
P2R TBS/TBGs / Fujita SRI / Skunk2 10th Anv. Knob/Radiator Cap / TWM SS/ Auger Boot
TWM Cable/Base Bushings / StrutKing DP Cover / JDM Dipstick / Cleared Head/Tails /
My Car Build Thread - Amilia
maximus20895 is online now   Reply With Quote
X's Intake FAQ xfactorwrx Bolt-Ons And All-Motor 2398 03-10-2008 01:28 AM
Intake Manifolds and camshafts silverspoon1996 Bolt-Ons And All-Motor 2 02-18-2008 02:54 PM
Ford plastic intake manifold settlement Shemmy Garage 6 12-24-2005 11:14 AM
