Old 01-02-2008, 08:30 AM   #121 (permalink)
i-VTEC your Mom
BLouIsGod's Avatar
Brad
the apex filter has the adapter with it that youll use in conjunction with the spectre coupler to mount it to the maf. other filters and maf adapters are set-up in the reverse order.
2008 ASM FA5 w/ Navi and Summer Tires
BLouIsGod is offline
Old 01-02-2008, 09:15 AM   #122 (permalink)
Northeast-the place to be
Qshooter151's Avatar
Jordan
Originally Posted by CrackThatTec45 View Post
does this mean mine is next??? muaaaahaha
yep, sure does bro
Originally Posted by xfactorwrx View Post
close but not exactly, looks like you hand filed in and out motion rather than side to side. did you use a trianglar file? anyway i got a surprise for everyone. when i hit the dyno, i might have figured out how to get gains for a exhaust on my set up.. question is which system do i put on, skunk2 70 or the LSD...
you are correct. i did not use a triangle file. i went in and out with a crescent file. worked great.
see avatar for answer to your question...
Qshooter151 is online now
Old 01-02-2008, 10:57 AM   #123 (permalink)
Bears can paint...srly!!!
Nomar06's Avatar
Originally Posted by Qshooter151 View Post
mine is done. juss needs a lil cleanin up...
some more pics for you guys :)
Hey Q, Look at the edges of the vanes where is meets the round part. Looks like your is not as flat as X's intake. Just an obsevation.
Nomar06 is offline
Old 01-02-2008, 01:33 PM   #124 (permalink)
Jordan
yea, that's why i said it needs a lil cleanin up. i didn't have a small file on hand when i did this. it'll be taken care of though. thanks man.
Old 01-02-2008, 04:15 PM   #125 (permalink)
Hey X, (or anyone that knows) is there an specific width/thickness you aimed for when you were sanding down the vanes? And how is it that you figured out you had a 5% angle at the front (does the Jig let you get that specific angle?)
Thanks for the DIY
SiBEAR is offline
Old 01-02-2008, 04:19 PM   #126 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
when you get to 5 degrees or so the vanes will be the right thickness. use a small compass.
is Missy a squirter?
Zeuceone is offline
Old 01-02-2008, 04:37 PM   #127 (permalink)
ibanez37's Avatar
Blake
Curious about the exhaust trick you have in store and thanks for the DIY! Might just try and tackle this after all.
ibanez37 is offline
Old 01-02-2008, 04:39 PM   #128 (permalink)
ibanez37's Avatar
Blake
Anyone have an example of these mini compasses and where to find em?
ibanez37 is offline
Old 01-02-2008, 07:39 PM   #129 (permalink)
soxfan143's Avatar
I just got a protractor and used it to cut out a 5 degree angle out of a piece of cardboard and used it as a template to slide over it.
soxfan143 is offline
Old 01-02-2008, 07:58 PM   #130 (permalink)
JZILLA's Avatar
will reseting my ecu lock my radio? please respond im about to do it and have a long drive tomorrow and dont wanna be without it
JZILLA is offline
Old 01-02-2008, 08:00 PM   #131 (permalink)
TWFA5FTMFW
0720Steve's Avatar
Resident Si Sedan Hater Hater
where is the pic that shows the 5 degree thing. is it the outsides (top and bottom) or the insides (middle inside part of vanes) and the front or back or both of the maf in terms of airflow.
0720Steve is offline
Old 01-02-2008, 08:01 PM   #132 (permalink)
yes
slesholdofthreep is offline
Old 01-02-2008, 08:02 PM   #133 (permalink)
Undispu7ed's Avatar
Jon
Awesome. Vids are pretty thorough.
The true measure of a man is how he treats someone who can do him absolutely no good.
Undispu7ed is offline
Old 01-02-2008, 08:02 PM   #134 (permalink)
JZILLA's Avatar
how do I get the key for the radio?
JZILLA is offline
Old 01-02-2008, 08:05 PM   #135 (permalink)
Jordan
it's on a small business size card. should be with your manual and your quick reference guide. that's where i keep mine anyway...
Old 01-02-2008, 09:58 PM   #136 (permalink)
ibanez37's Avatar
Blake
I think I'm a bit confused on this. The angle is from front to back right? Wouldn't that mean you would have to put the template along the side? And it being a cylindrical object, that doesn't quite work lol.
ibanez37 is offline
Old 01-02-2008, 10:15 PM   #137 (permalink)
udumkid's Avatar
Rene....
Yes. You need to get your radio code ready if you plan on reseting the Ecu.
udumkid is offline
Old 01-02-2008, 10:18 PM   #138 (permalink)
udumkid's Avatar
Rene....
Also the radio code is in the pre delivery booklet.
udumkid is offline
Old 01-02-2008, 10:39 PM   #139 (permalink)
soxfan143's Avatar
I use a thin piece of cardboard I use a protractor to draw a 5 degree angle on it and cut out the inside of the angle. Then I slide it into the MAF housing over the vane thats been filed. If it fits then the angle is correct. If it doesn't fit then it needs to be filed more.
Old 01-02-2008, 10:45 PM   #140 (permalink)
ibanez37's Avatar
Blake
Cleared it up. Thank you sir!
ibanez37 is offline
