Old 01-22-2008, 12:28 PM   #521 (permalink)
I got a mangina!
"Ridge"Racer's Avatar
Justin
Originally Posted by dwm5f5 View Post
From what I've seen, we all may have the same cars with the same engines...but there are huge differences between how they act. Earlier in this thread there were people with huge differences in stock power. And, as nighthawk pointed out, there are Si's that work great with aem/injen/etc intakes and others like mine and qshooters, apparently, that just suck with them.
TW FG2 Sold....
"Ridge"Racer is online now
Old 01-22-2008, 12:39 PM   #522 (permalink)
dwm5f5's Avatar
Dan
Originally Posted by "Ridge"Racer View Post
Btw ridgeracer...I love your quote, I have a huge bruise on my right shoulder from my gf punching me every time I hit 5500.
dwm5f5 is offline
Old 01-22-2008, 12:42 PM   #523 (permalink)
dwm5f5's Avatar
Dan
6000 I mean...
dwm5f5 is offline
Old 01-22-2008, 01:14 PM   #524 (permalink)
Moderator
Qshooter151's Avatar
Jordan
Originally Posted by MrKaz View Post
Qshooter151- Do you have pictures of the vains by any chance? I really want to do this DIY, however, I am scared I will have problems.. (plus I already bought all my supplies ) .. Thanks for the help.
i do have some pics. i'll post them up...
On the contrary, several users on this site (including myself) have had problem with aftermarket intakes causing this idle behavior...a search for intake problems on this site will confirm that. X, correct me if I'm wrong, but this is one of the major problems that prompted you to create your own intake. Yes, missing/defective vanes cause a bad a/f...and that causes the poor idle.
Even if Qshooter's problem was unique, you're saying that a completely different problem with the tb occurred within inches of modification of the MAP sensor and there is no connection between the two? And a return to the stock intake corrected the problem? I really doubt it.
when i installed my DIY intake on the dyno, the car started and ran fine. there was no CEL and i gained 2 whp up top over the stock box. i have yet to see what i gained in the middle cuz i have not yet received my run files via email. i'm becoming more annoyed by the hour. they told me i'd have them first thing monday morning. but whatever, that's another issue...the vanes are perfectly symetrical and even. i will be measuring the angle tonight. on the way home from the dyno i drove my car pretty hard for 2 hrs and it was fine.
also, my car was idling steady for over an hr before it started idiling erratically. when it happened, i turned it off, then restarted it IMMEDIATELY. the car started and idled fine. i drove it home then to autozone to have the code pulled. then grabbed food and drove home. the car ran fine the entire time. no issues at all.
Originally Posted by PhalanX View Post
im gonna have to agree w/ this one. thats almost TOO much of a coincidence.
____________
Also, Jordan... I still think part of your issue (with low readings) is partially due to your 70mm exhaust. That piping just might be too large and with the amount of flow through the exhaust, the actual air may not be being forced out because of the larger piping (i know what i mean but i dont know how to express it)
However... after thinking about it more... if you had this issue then Will wouldve had it as well, so i could easily be wrong. But the larger piping could also explain Oriol's 'low' numbers as well.... i dunno.
We'll just need to go to bristol again. try and convince them not to sell their dyno equipment.
____________
Have you recieved the email yet with your charts? i havent got mine yet
bristol may be out. he told me to contact them again in a week. no i still have not received my run files.
Qshooter151 is offline
Old 01-22-2008, 01:17 PM   #525 (permalink)
Xtreme Thunder's Avatar
Joey
Xtreme Thunder is offline
Old 01-22-2008, 01:19 PM   #526 (permalink)
1337 h4xZ0r
Phalanx's Avatar
MASShole
Hmm... maybe Piotrush can try and get some info on the place supposedly in Stamford, CT that has an AWD dyno, so that Dani's hubby's EVO can get on the dyno too.
I'd really like to get my run-files so i can start to keep documentation on mods.
Phalanx is offline
Old 01-22-2008, 01:45 PM   #527 (permalink)
dwm5f5's Avatar
Dan
That sounds really similar to my experience with my aftermarket intake. It drove absolutely fine for the first day and a half...felt power and idle was fine. Then it randomly would start doing the rev deal and it threw a cel. I reset the cel and disconnected my battery and it ran fine for a couple hours but then started right back up again with the cel. The power increase seemed unaffected (by the butt dyno), but the idle problem kept becoming more and more frequent until I went back to stock.
Trust me, I want your intake to work probably as much as you do...I diy'ed my own and it's sitting in my living room waiting on the filter/stand. As for what's actually going on, I have no idea...and I definitly am not accusing your workmanship on your vanes. I'm just saying there's no denying the fact that it's probably the intake that's causing the problem, not an unrelated tb issue...despite what the code is.
dwm5f5 is offline
Old 01-22-2008, 01:55 PM   #528 (permalink)
Moderator
Jordan
yeah, i didn't give it a chance to happen again, the stock box went back in within hrs. whats' the design of the weapon r intake?
ya know, i'm not quite sure it's gonna work well with a race header and 70mm exhaust at all. here's the pics i have right now. when i get it apart tonight, i'll take more...
first vane almost done...
both vanes completed...
Old 01-22-2008, 02:18 PM   #529 (permalink)
dwm5f5's Avatar
Dan
The Weapon R was just a hollow aluminum tube...no vanes, nothing. But whatever my car didn't like about that intake, it seems your car doesn't like about your intake.
Btw, your vanes look almost identical to mine, I'm a little scared that mine is going to do the same thing. Have you ever had any other intake on yours?
Didn't X want to take a look at the pics of your housing? Did he have any suggestions or thoughts?
dwm5f5 is offline
Old 01-22-2008, 02:43 PM   #530 (permalink)
Halt American Polizei!
MrKaz's Avatar
Qshooter151 thank you for the pictures, I hope this problem gets resolved. Thanks for keeping us updated!
MrKaz is offline
Old 01-22-2008, 04:28 PM   #531 (permalink)
Moderator
Jordan
yeah, i had an AEM SRI for a year. no CEL ever...yes, he asked for pics. i'll be getting them tonight.
no problem man. it's been resolved...lol. i took the intake out. almost time for redshift anyway. ...i may hit another dyno. not quite sure yet. looking into it...
Old 01-22-2008, 11:57 PM   #532 (permalink)
I got a mangina!
Justin
aem sri, three cel, none lately and cant find a problem so whatever, code cleared itself.
TW FG2 Sold....
Old 01-23-2008, 01:07 PM   #533 (permalink)
Moderator
Jordan
welp, here it is.
blue run is with stock airbox
red run is with my DIY intake
other affecting mods are DCRH, skunk2 70mm cat back, hondata reflash, hondata IMG
Old 01-23-2008, 01:12 PM   #534 (permalink)
1337 h4xZ0r
Phalanx's Avatar
MASShole
I think im gonna order some parts tonight... and work on one of these.
Phalanx is offline
Old 01-23-2008, 01:14 PM   #535 (permalink)
Moderator
Jordan
i may have some for you...lol. not sure what i'm doing yet. i don't really wanna spend my f/i monies...ya know...
Old 01-23-2008, 01:19 PM   #536 (permalink)
1337 h4xZ0r
Phalanx's Avatar
MASShole
let me know. im in a DIY mood lately
Phalanx is offline
Old 01-23-2008, 01:39 PM   #537 (permalink)
onefastsi's Avatar
I M SPEED
welp, here it is.
so you have all those mods and only picked up that little HP?? What was the base HP before mods? I thought you'd easily be over 200HP with reflash, intake, header, etc...???
onefastsi is offline
Old 01-23-2008, 01:41 PM   #
