#502 (permalink) | |
#507 (permalink) |
J. M. back by popular demand!
Have you reset the ECU and done the learn procedure?
![]() Visit my city! Free vagin for every resident (in direct contrast to the other cities that only provide free Fleshlites!) http://eat-mykhram.myminicity.com/ |
#510 (permalink) | |
hmmmmmmmmmmz
![]() Get your ass over here and bring that intake of yours |
#511 (permalink) | |
actuator, the throttle valve, throttle position (TP) sensors A and B, the throttle actuator control module, the ETCS control relay, the accelerator pedal position (APP) sensor, and the engine control module (ECM). The APP sensor is operated via the throttle cable to determine the accelerator opening value when the driver presses the accelerator pedal. The accelerator pedal opening value is converted to a signal in the APP sensor and transmitted to the ECM to compute the target position. The target position signal is then transmitted to the throttle actuator control module. The throttle actuator control module determines the throttle valve target position according to the signal received and operates the throttle actuator to move the throttle valve to the target position. The actual throttle valve position is determined by TP sensor A installed in the throttle body. The throttle actuator control module compares the throttle valve target opening angle and the actual throttle valve opening angle from TP sensor A, and when the difference exceeds the specification, the throttle actuator control module transmits the malfunction data to the ECM. When the ECM receives the malfunction data from the throttle actuator control module, the ECM detects the malfunction of the throttle actuator system and a DTC is stored. |
#513 (permalink) |
Moderator
thanks Rene. yeah, the problem is definitely with the throttle body. the manual said to check for loose connections, and to test it with a HDS. if code is still appearing then clean the throttle body.
stock airbox is now back in and i had the code cleared. if it happens again, i'll take it to Honda. my brother works there so i get treated well. |
#514 (permalink) | |
#516 (permalink) | |
missing/defective vanes may cause the car to have a bad a/f...but it should not cause any kind of jerky idle. i think this is just a coincidence of somthing wrong with the throttle body. |
#517 (permalink) | |
Even if Qshooter's problem was unique, you're saying that a completely different problem with the tb occurred within inches of modification of the MAP sensor and there is no connection between the two? And a return to the stock intake corrected the problem? I really doubt it. |
#518 (permalink) | |
1337 h4xZ0r
____________ Also, Jordan... I still think part of your issue (with low readings) is partially due to your 70mm exhaust. That piping just might be too large and with the amount of flow through the exhaust, the actual air may not be being forced out because of the larger piping (i know what i mean but i dont know how to express it) However... after thinking about it more... if you had this issue then Will wouldve had it as well, so i could easily be wrong. But the larger piping could also explain Oriol's 'low' numbers as well.... i dunno. We'll just need to go to bristol again. try and convince them not to sell their dyno equipment. ____________ Have you recieved the email yet with your charts? i havent got mine yet |
#519 (permalink) |
From what I've seen, we all may have the same cars with the same engines...but there are huge differences between how they act. Earlier in this thread there were people with huge differences in stock power. And, as nighthawk pointed out, there are Si's that work great with aem/injen/etc |
