Old 01-20-2008, 06:50 PM   #421 (permalink)
ovur ur headz
Qshooter151's Avatar
Jordan
installed DIY intake today at the dyno. did a before and after run. it got me 2 more hp up top, that's it. not sure what it got me in the midrange yet. waiting for the file from the dyno so i can graph them together. they only graphed my highest run. also, they could not monitor my afr.
with stock intake(lower piping removed)-194.5
with DIY intake-196.5
other affecting mods- DCRH, skunk2 70mm, hondata reflash, hondata img
i left the intake in for the ride home. i did notice a big difference in engine response from 3k up.
disappointing day.
Qshooter151 is offline
Old 01-20-2008, 06:52 PM   #422 (permalink)
TWFA5FTMFW
0720Steve's Avatar
Resident Si Sedan Hater Hater
uhh oh
0720Steve is online now
Old 01-20-2008, 06:54 PM   #423 (permalink)
saiaba's Avatar
Ryan
Originally Posted by 0720Steve View Post
uhh oh
saiaba is offline
Old 01-20-2008, 06:54 PM   #424 (permalink)
Emmanuel
wow, my friend with a 07 FA5 with my intake and my old ported DCRH did 206WHP on a dynojet, but his car is a factory freak. can you get the AFR from the lower run? just to get an idea?
xfactorwrx is offline
Old 01-20-2008, 06:54 PM   #425 (permalink)
dwm5f5's Avatar
Dan
?? Well that's no good...this may be a stupid question, but did you reset the ECU b/t the stock and DIY intake runs?
dwm5f5 is offline
Old 01-20-2008, 06:54 PM   #426 (permalink)
I got a mangina!
"Ridge"Racer's Avatar
Justin
uh oh what?
TW FG2 Sold....
"Ridge"Racer is offline
Old 01-20-2008, 06:56 PM   #427 (permalink)
dwm5f5's Avatar
Dan
Originally Posted by "Ridge"Racer View Post
uh oh what?
"uh oh" = I'd rather get a spacer/gasket for 2hp and a lot less $$.
dwm5f5 is offline
Old 01-20-2008, 06:57 PM   #428 (permalink)
Emmanuel
ive reset the ECU on the dyno before. i havent seen a difference with it reset or not reset. his car should have broke 200 easy
Old 01-20-2008, 06:57 PM   #429 (permalink)
ovur ur headz
Jordan
cannot get my AFR's. they were not recorded at all. what's the correction factor on the dyno you're referring to?
i thought about this, no, i did not. i didn't have the luxury to make everyone wait 15 mins for my ecu to reset. there were like 25 cars that got on the dyno today...
Old 01-20-2008, 06:58 PM   #430 (permalink)
ovur ur headz
Jordan
i agree X. i have no f'ing idea why i didn't.
Old 01-20-2008, 06:58 PM   #431 (permalink)
Emmanuel
well he just spent money on parts to make his own. so he isnt at a loss really
Old 01-20-2008, 06:59 PM   #432 (permalink)
dwm5f5's Avatar
Dan
agreed
Then why is it necessary to reset after intake (or any other part)?
dwm5f5 is offline
Old 01-20-2008, 07:00 PM   #433 (permalink)
ovur ur headz
Jordan
also, i haven't seen what i gained in the midrange yet. that will be tomorrow when i get the dyno file. i will graph them together.
Old 01-20-2008, 07:00 PM   #434 (permalink)
Emmanuel
his correction smoothing was 5. hes redynoing at the superflow chassis dyno pretty soon, i expect his car to do high 190's
Old 01-20-2008, 07:00 PM   #435 (permalink)
dwm5f5's Avatar
Dan
I know, I was just playin. It's just that there seems to be something else wrong here, your intake has consistently shown more gains than that.
dwm5f5 is offline
Old 01-20-2008, 07:01 PM   #436 (permalink)
Emmanuel
i have reason to believe your car is going into closed loop were the ECU is just dumping ALOT of fuel up top killing you top end number. your mid should be good still.
Old 01-20-2008, 07:02 PM   #437 (permalink)
ovur ur headz
Jordan
not the smoothing, but the correction factor. ie;STD, DIN, SAE...etc etc.
i'm confused myself.
Old 01-20-2008, 07:04 PM   #438 (permalink)
Emmanuel
ima call him see if he even has his sheets still. but it was a corrected number. his raw number that day was 205
Old 01-20-2008, 07:04 PM   #439 (permalink)
ovur ur headz
Jordan
yeahhhhh well, ain't nothin that a redshift stage 2 can't fix. that's next.
his uncorrected # is going to be 10whp more than his SAE corrected #. guaranteed.
Old 01-20-2008, 07:04 PM   #440 (permalink)
