#401 (permalink) |
Kill Your Self Krew
looks good. thanks.
#402 (permalink) |
TWFA5FTMFW
![]() Join Date: Feb 2007
Resident Si Sedan Hater Hater
thanks, i still need to remove the factory junk. at the time i left it there for some air flow, but then realized there isn't any actual draw to it. going to take it out when i put in the gaskets and spacer.
#403 (permalink) |
Kill Your Self Krew
same here.
#408 (permalink) |
I got a mangina!
![]() Join Date: May 2007
Justin
ok well, before i start, thanks steve. ok so i can use a router bit and a dremel tool to cut the housing? It looked like X had a much bigger and more powerful router than i do, but i have the best one that dremel makes. i have the same little file and the big file X used, that shouldnt be a problem. and steve, you said that the 3"to3" comes with that piece? or the 3"to2.5" kit comes with that piece i need? i know i need the 3"to3" for the filter to mate with maf housing. thanks and sorry for the paragraph.
TW FG2 Sold.... |
#409 (permalink) |
TWFA5FTMFW
it's one piece, look for it at autozone, it has an adapter/inner tube you shove in there to make the 3" diameter a half inch smaller. it will say on it 3to3 or 3to2.5. the extra tube is what you can use to protect the other side/rest to give the angle.
check this out see the insert hiding in there? ![]() |
#410 (permalink) |
TWFA5FTMFW
actually it says 3" to 2.5 or 3"....see if this pic works, no edit button. and it is spectre part number 8771
![]() autozone link |
#411 (permalink) |
I got a mangina!
Justin
awesome, thanks so much, btw and im sorry to have so many questions but i bought a router bit for my dremel, will that work to cut out the maf housing?
TW FG2 Sold.... |
#413 (permalink) |
I got a mangina!
Justin
well, until i get to the filing which wont be for another week or so i wont have anymore questions. i am pretty mechanically inclined and have an acute attention to detail so i should be ok. i just want to say thanks for going above and beyond to answer my questions. i would rep you again if i could, but thanks so much man!!!!!!!
TW FG2 Sold.... |
#414 (permalink) |
TWFA5FTMFW
no problem.
my "mechanical knowledge" or possibly my impatientness led me to do this and i must say it was very simple. 6 hours or so. just have the right tools and a brain and you can do it. famous words for anyone reading this....there should be nothing stopping you from doing it. even with the cost of tools i only spent a little over 150 (sears/craftsman sale ftw), 175 should cover it. if you consider yourself someone who likes to "work on your car", then just try it....and then get a dyno to be sure nothing is terribly out of whack. btw still hoping my a/f looks good enough. i'd like more people, including x, to chime in and tell me what they think. good luck guys, bite the bullet and get it done. |
#415 (permalink) |
I got a mangina!
Justin
well i dont think i can do a baseline pull because i threw away my stock airbox like a genius, but when im done with the intake i will def get to the dino and post results. i have however done a little research and with the help of my friend who just happens to be a mechanical engineer, i think i will modify the maf housing to a different spec based on an even better airflow design which in effect could create more horse whilst not affecting the maf sensor or making the vehicle run to lean. i will post dyno sheets when i can and pics of the design i want to try but i still need time to test it. (my buddys got a wind tunnel for this project!)
TW FG2 Sold.... |
#416 (permalink) |
I got a mangina!
Justin
footnote, im not implying that i could improve over x's design as i am not willing to put the hours into the r&d that he did but its worth a shot and with the dyno's ive seen it would be very hard to reinvent the wheel besides i think everyone owes him a huge thanks for giving everyone the diy and helping out fellow tuners when he could have concievably kept it to himself and profit all the more.
TW FG2 Sold.... |
#418 (permalink) |
So I finished filing down the vanes today...it definitely took some time and patience. I didn't have the right size files, I bought a $10 kit at lowes which included about 7 different ones. To get the angle right, I printed out a protractor .pdf, layed it behind a clear piece of plastic (I used the packaging from the spectre coupler), and exactoed a little plastic guide that I used every once in a while to make sure I was getting it right.
Just waiting for the filter (Corsport is the best price I could find!) and tube to come in . I also need to get the mount piece from X. Does anyone know the best way to get ahold of him? I also need to find a place that has a dyno around here. When I get it dynoed, I'll post a copy. Thanks to Caliguy for the vids and a huge thanks to X for agreeing to do the dyi. |
#419 (permalink) |
I got a mangina!
Justin
your just gonna have to pm him and let him know you want one and how to get him the money, i used paypal. and yeah, i am taking my time with tools so i get exactly the right ones, i ordered the little file from snapon so i will have the same tools he used to mimick the job completely.
TW FG2 Sold.... |
