#241 (permalink) |
J. M. back by popular demand!
The AFR's will all be the same (or damn near the same) as he uses exact specs when modding the MAFs..The reason I stressed getting a dyno in the DIY is that if you DIY you might not have done it correctly...
![]() Visit my city! Free vagin for every resident (in direct contrast to the other cities that only provide free Fleshlites!) http://eat-mykhram.myminicity.com/ |
#245 (permalink) | |
Moderator
X and Cali- I can't rep either one of you at the moment, but both of you deserve it. Thank you very much. I can't say how much I appreciate you two getting together and doing this.
hawk and I did this a while back to our stock lids, but this DIY reinforces the belief I had essentially put into X that his intake is far superior to anything else on the market right now. Emmanuel- thank you, you have my respect. I modified my airbox, but if I ever decide to go back to an SRI (I've been thinking about it) you'll have my order.
#246 (permalink) | ||
Moderator
you couldn't do a 5 degree angle all the way back. no- the fins are EXACTY that- fins. a fin guides a fish through the water, or a rocket through the sky, &c. the fins in your maf housing guide air around the MAF itself. removing them would not be a good plan, and once you start thinking about it, it really makes sense.
#247 (permalink) | |
#248 (permalink) | |
BBoy_Burst, the fins are guide vanes to keep the airflow laminar past the MAF sensor, keeping it smooth and even across the area that the sensor measures. As I take it from some other posts, its measuring the flow, not the pressure, as as such, a laminar flow seems to be what the sensor needs, hence Honda's guide vanes. My Si is stock for now, but it sounds like most/all of the aftermarket SRIs and CAIs have no guide vanes, which sounds like is resulting in a turbulent airflow in the area of the MAF sensor. X and Cali, thanks for the DIY and vids! I think im finally convinced that i'm going to build one of these sooner or later :) ![]() |
#250 (permalink) | |
#251 (permalink) | |
#253 (permalink) | |
Moderator
I am theorizing a little here- but everywhere that you move restrictions on air flow (even if you don't increase the total potential volume of flow) you are increasing the amount of air that can go into the engine per minute, second, &c. maybe this isn't right, but reducing the drag that the stock fins can be causing makes sense. In fact, I have to wonder if anyone at honda actually thought of making the fins angled in order to cut the air better...
#254 (permalink) |
TWFA5FTMFW
![]() Join Date: Feb 2007
Resident Si Sedan Hater Hater
so you can reuse the factory clamps and such, you just need the crv tube and the filter? and then the mouting bracket. where is the pic of that?
#257 (permalink) |
Looking good Q. I have to get rid of this HKS filter I have. Not only does the Apexi out flow and out filter it, it looks so much better. I hate my HKS filter. But it was the only one that I could find with an 80mm flange at the time.
I need to get a red coupler. I like that. I can't wait to hear what you have to say the first time you get on it. It suprised the s*** out of me. It's so fun. And it sounds so good in vtec. Good luck bro. |
#258 (permalink) |
Looks great Q! Let us know how it feels!
