Old 01-10-2008, 10:20 PM   #101 (permalink)
nelsonr31's Avatar
Subscribed to a EXCELLENT DIY.
nelsonr31 is offline
Old 01-11-2008, 08:18 AM   #102 (permalink)
GlxyGry06Si's Avatar
OK
GlxyGry06Si is offline
Old 01-11-2008, 12:11 PM   #103 (permalink)
nelsonr31's Avatar
Old 01-11-2008, 12:19 PM   #104 (permalink)
you had big letters and so did i. check neg!!
Old 01-11-2008, 07:46 PM   #105 (permalink)
nelsonr31's Avatar
WTF do your posts have to do with this thread?
Old 01-11-2008, 09:26 PM   #106 (permalink)
Agnt004's Avatar
Greg
Both of your recent posts have nothing to do with this thread. However, I sense sarcasm in GlxyGry06Si's OK comment, because you can click on thread tools at the top of the page and subscribe from there without making an unrelated post in a thread saying "subscribed". I just made a very unrelated post as well though....
Agnt004 is offline
Old 01-11-2008, 10:27 PM   #107 (permalink)
nelsonr31's Avatar
Thanks, I really didn't know about the thread tool thing, but it was an excellent diy imo that's why i posted it. I also sense sarcasm from GlxyGry06Si's OK comment but if he wants to be a prick then so be it. I guess I have to verify with GlxyGry06Si first before I post anything with capital letters "YEAH RIGHT, I DON'T THINK SO". Oh well,I just added another unrelated post
Old 01-12-2008, 03:10 PM   #108 (permalink)
King Starscream
I<3MyHonda's Avatar
John
thanks for the great DIY but does anyone know how tight to screw in the little plug on tha back of the spacer?
I<3MyHonda is offline
Old 01-15-2008, 02:28 PM   #109 (permalink)
Toys For TotsMember
samx109's Avatar
Sam
The front-most bolt is the easiest. Seriously, run out to the nearest store to get some Vise-grips or some other knock off (if you already don't have one-- lost mine -- heheh -- around a 6" long or greater handle), and get that lower, far back, bolt broken off the manifold (not literally, just loosened). It does come off. The one diagonally is also on the manifold. All told, four bolts; the long ones P2R provides works fine to replace with the 13mm socket. Loosen it slowly a few turns at a time; you'll be able to use your fingers at some point.
Here's the generic vise on the first (easy) bolt:
uh so my bolt doesn't come off -_- is there other way i can take them off?
and do you just screw it before you put the spacere or what?
samx109 is offline
Old 01-15-2008, 03:57 PM   #110 (permalink)
iomatic's Avatar
There is another piece of advise about threading two nuts on, then you use the inner nut as a bolt head and reverse it out. Let us know if this helps.
iomatic is offline
Old 01-15-2008, 04:07 PM   #111 (permalink)
Moderated
ErichPryde's Avatar
Erik
I've got some pictures on the way that might help lay these questions to rest...
ErichPryde is offline
Old 01-15-2008, 04:14 PM   #112 (permalink)
Moderated
ErichPryde's Avatar
Erik
put the nuts onto the stud like THIS:
and then, using something (my ratchet in this case) to hold the outer nut still, use something else (like a crescent wrench) to turn the other one. because the nut you are holding still will not move, this will cause the stud to move.
and finally, here's a shot of the plug in the spacer!
Old 01-15-2008, 10:42 PM   #113 (permalink)
Toys For TotsMember
samx109's Avatar
Sam
i took them off after using my aligator wrench and hammering against it.. idk, but my bolts were screwed in too hard.
everything looks good, but i'm worred about my injen CAI. the TB and the top of CAI piping are too close together, so it might not suck enough air in than before.
samx109 is offline
Old 01-15-2008, 10:43 PM   #114 (permalink)
Toys For TotsMember
samx109's Avatar
Sam
wow that makes everything easier. why didn't i think about that? =[
you know that plastic screw? did you screw that all the way in or what?
samx109 is offline
Old 01-16-2008, 11:49 PM   #115 (permalink)
Agnt004's Avatar
Greg
Mine came with a metal (brass I think) screw...
Agnt004 is offline
Old 01-17-2008, 12:06 AM   #116 (permalink)
so did i
Old 01-17-2008, 08:33 AM   #117 (permalink)
Halt American Polizei!
MrKaz's Avatar
Awsome pics man +1.. I was wondering how you do that.. I remember my dad doing that once when he was working on his 1969 1/2 RS/SS Camero
MrKaz is offline
Old 01-17-2008, 04:41 PM   #118 (permalink)
Moderated
ErichPryde's Avatar
Erik
the "first generation" of spacers came with a brass screw- the newer ones come with plastic. simply screw it in until it is tight and cannot be screwed in any more.
Old 01-24-2008, 02:19 AM   #119 (permalink)
speedstyles408's Avatar
Andy
i'm still curious on this install with injen cai, when u install this would you have to do some custom to move the intake so it doest rub against the upper radiator hose?
speedstyles408 is offline
Old 01-24-2008, 07:54 AM   #120 (permalink)
formal but likes to party
Mabuz's Avatar
Some people have left it pushed up against the radiator...some have gotten a longer radiator hose to replace the one that the CAI would be pushed up against...all depends on how you want to do it.
Mabuz is offline
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
keeping track ... mods + dyno numbers sickyute Bolt-Ons And All-Motor 111 05-06-2008 09:23 PM
P2R throttle body spacer info ... !!!! sickyute Bolt-Ons And All-Motor 54 09-14-2007 07:15 PM
p2r spacer... rkalloo Mechanical Problems & Technical Chat 0 07-11-2007 11:35 PM
Skunk2 Pro Series TB with P2r Spacer & Gaskets NewYorkJon Bolt-Ons And All-Motor 15 06-25-2007 08:02 PM
Injen CAI + P2R TB Spacer Question NewYorkJon Bolt-Ons And All-Motor 4 06-24-2007 09:53 AM
