#1 (permalink)
![]() Join Date: Dec 2006
Jordan
*DIY-HONDATA IMG Install-Q Style
Let me start by saying this was the hardest mod I've done so far. Thank you BCJ for a little direction. I used a small socket set, needle nose pliers, a phillips screwdriver, an allen key, a 1 1/4" adjustable hose clamp, and a few metric wrenches to do this mod in my driveway. Halfway through, I decided to remove the front frame bracket. This step made it MUCH easier to perform this mod, trust me. For the time it took to remove it, it's well worth it. This write up is to show how I did the install and is intended to help others out. It is by no means "law" or the only way to do it. It's simply the way I did it and it worked for me.
Give yourself about 5 hrs for this install from getting the tools out to being all cleaned up. Some may need that much time, some may not. First thing you need to do is drain the coolant (white plastic butterfly plug at bottom of radiator) and remove your air intake. If you do not know how to do this, stop here, this is not a mod you should be attempting on your own... After draining the coolant lets remove the front frame bracket circled in red in this first pic. ![]() 1.You will remove this bracket by first removing these 3 bolts. ![]() 2.Next, remove the upper grille allen screw and bolt below it to the right. ![]() 3.Now remove the upper a/c radiator mount bolt which you will find behind the upper grille after doing step 2. ![]() 4.Now, between the battery and the front frame bracket, remove this bolt. ![]() 5.Now on to the passenger side. Remove these 4 bolts. ![]() 6.Remove the bolt from behind the upper grille. ![]() 7.Remove this bolt on the back side by the hood prop. ![]() 8.Next remove the hood latch assembly. ![]() 9.Now, remove all of the the plastic clips shown in the next two pics. I managed to keep all but one intact...the white one. I poped the clips out from the backside by going through the holes in the frame bracket with a screwdriver. ![]() ![]() 10.Now gently wiggle the bracket up until it comes out. ![]() Note the difference in the amount of room you have to work between pic A and pic B. A ![]() B ![]() Now on to removing the intake manifold! 11.Disconnect the feed & return coolant lines to the throttle body on the upper right side of the intake manifold. ![]() 12.Disconnect this breather hose on the upper right side of the intake manifold. ![]() 13.Disconnect this vacuum line on the lower left of the intake manifold. ![]() 14.Disconnect this wire harness and remove the bolt securing the wire clip. ![]() 15.Remove fuel rail nuts(one on each end of fuel rail. one is circled in the pic). Also remove fuel rail grounding wire bolt. ![]() 16.Now to remove the fuel rail. First pull off locking cover on the right side of the fuel rail. ![]() 17.After exposing this teal clip(pic below), squeeze both tabs towards fuel rail and slide to the left to unclip. ![]() Have a rag handy for this next step! You should now be able to wiggle the fuel rail off of the intake manifold. First make sure that there is no dirt or debris directly around the injectors that will fall in when you remove the fuel rail. Now you can rock it back n forth, to and from, while pulling up at the same time. Once it comes out wrap the entire thing in a rag before relocating it. Now find a spot to rest it out of the way. A little gas will leak from the end of the fuel rail. Are we having fun yet??? 18.Remove this bolt on the front of the throttle body. ![]() 19.Disconnect this wire harness and remove this bolt(circled in yellow). Notice the clip circled in red. This thing was the least fun of this entire project. I removed it by using a pair of needle nosed pliers in my left hand going from underneath and a screwdriver in my right hand from the top....It was stated in another DIY that you do not have to remove this clip. Follow this line (again, circled in red) to the right up to the top of the motor and you will find a bolt next to the plastic cover with all the engine wiring. Remove that bolt and it will give you enough slack to pull the coolant line out of the way when it comes time to remove the intake manifold. I thought of this myself, however I did not have any swivel sockets which is what's needed to remove that bolt on top. ![]() 20.Now pop this clip out and remove this bolt. Also follow the arrow down to find another bolt on the bottom of the black bracket and remove that bolt also(not in pic). ![]() 21.Now you're ready to remove the intake manifold. First make sure that there is no dirt or debris in the valley between the engine and intake manifold that will fall in once the intake manifold is removed.Remove the two nuts(arrows) and six bolts securing it...Circled in yellow is that stubborn ass clip from step 19. Don't worry about that for now...To remove the intake manifold is a little task all in itself. You just have to coax it out of there. At first it's gonna seem like, WTF, this thing's never gonna come outta there, but have faith and some patience. You will get it out. Besides you didn't come this far to put it back together with that flimsy ass metal gasket still in there! So take your time, use a little persuasion and elbow grease and it'll come out... ![]() Now we're having fun! 22.Remove the factory gasket and install the Hondata intake manifold gasket. If you're doing this install exactly as I did it, you must remove that factory hose clamp circled in yellow and replace it with the adjustable hose clamp. You will NEVER get the factoy hose clamp back in place, trust me... ![]() 23.Make sure you put the new hose clamp in a position to fully tighten it from up top. ![]() 24.Now it's time to put it all back together. Simply do everything you just read, only in reverse. The only thing you will need to do different is relocating the ground wire that was connected to the top of the intake manifold as recommended by HONDATA on the K series engines. You will need to relocate it to the top right valve cover nut. Using a screwdriver, once you get the plastic cover off of the wire housing, there is just enough room to reroute it through the hole on the opposite side where a wire goes out to the injector. See pics below. Then step back, pat yourself on the back and admire your work, cuz after that install...you deserve it. Old ground wire location. ![]() New ground wire location. ![]() ![]() ![]() I did this mod on 5/28/07 and have had no problems so far. Hope you found this helpful...-Q Last edited by Qshooter151; 06-17-2007 at 02:49 PM. |
#5 (permalink) | |
Jordan
justin
excellent write up. looks like it takes awhile to get that support bracket out...but i guess its worth it.
also in step 13 it says its a coolant line, but its a vacuum line, that is the pcv valve that hose is running to |
#8 (permalink) | |
Jordan
#12 (permalink) | |
justin
#16 (permalink) |
of the entire time i spent trying decipher batang's diy.. i didn't even think of taking that metal thing off. that wouldve easily saved probably an hour of extension changing and funny angles from the top and bottom of the car to get the bolts off.
nice. |
#17 (permalink) | |
Jordan
that's where i picked up my ecu(after reflash) and IMG. he showed me around his shop and i got a look at his fg2 that they were working on a turbo for...
#20 (permalink) |
![]() Join Date: May 2006
J. M. back by popular demand!
Outstanding write-up!
http://i61.photobucket.com/albums/h52/jbpray/cali-1.jpg Visit my city! Free vagin for every resident (in direct contrast to the other cities that only provide free Fleshlites!) http://eat-mykhram.myminicity.com/ |
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/44275-diy-hondata-img-install-q-style.html
| DIY Installing Hondata Heatshield - Honda-Tech | This thread | Refback | 08-25-2011 05:56 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 02-25-2008 08:22 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-03-2008 09:23 AM | |
| How easy is it to install the Hondata IMG......... | Dwn4nythng | Intake & Spacer Discussion | 14 | 05-20-2007 06:11 PM |
| Hondata IMG Install ? on 06 Si | Nox | Intake & Spacer Discussion | 4 | 09-14-2006 01:58 PM |
| IMG install?!? | SonicK20Z | Intake & Spacer Discussion | 1 | 06-21-2006 06:45 PM |
