Old 04-13-2008, 09:35 AM   #161 (permalink)
Northeast-the place to be
Qshooter151's Avatar
Jordan
thanks, glad it helped you guys out.
Qshooter151 is online now
Old 04-16-2008, 08:03 PM   #162 (permalink)
XingSi's Avatar
Oshooter151, is it require, better to use the adjustable hose clamp(the clamp you circled in yellow)? i put the stock clamp back in there and it fits good. thanks
XingSi is offline
Old 04-16-2008, 08:06 PM   #163 (permalink)
Jordan
no, not required. i did it cuz it was easier for me. as long as it doesn't leak, either way, you're good...
Old 04-27-2008, 07:26 PM   #164 (permalink)
dt07Si's Avatar
Dave
Bookmarked for install in a week or two...
dt07Si is offline
Old 04-27-2008, 07:43 PM   #165 (permalink)
maximus20895's Avatar
^i'm right with you..
What all do you need in terms of tools?
torque wrench
rachet w/ extensions
do you need any hondabond or anything else?
thanks.
maximus20895 is offline
Old 04-28-2008, 10:55 PM   #166 (permalink)
Also, should I drain all the coolant out and if so how much coolant is in there?
To verify the process of draining coolant is as follows:
Open radiator cap
Place bucket under car
open valve under radiator (white)
Let the coolant fall into the bucket
Close white valve
after w/ IMG install pour back the coolant back into the radiator
close the radiator cap
Am I correct?
Thanks
Old 04-29-2008, 06:53 AM   #167 (permalink)
Jordan
yeah, you'll need to run the car till the thermostat opens up and it flows through the motor, then add more coolant.
Old 04-29-2008, 07:49 AM   #168 (permalink)
^what do you mean?
Old 04-29-2008, 10:28 AM   #169 (permalink)
Vinc84's Avatar
Viną
Originally Posted by maximus20895 View Post
^what do you mean?
He means, after you finish the install and put coolant back in - start your car and let it idle for a while allowing the temperature to rise. This will allow the coolant to flow through the engine - then add a little bit more to top it off. Don't drive until you've done this.
Vinc84 is offline
Old 04-29-2008, 10:38 AM   #170 (permalink)
^alright thanks. I don't have any coolant right now where and what would you reccommend buying and how much should come out of the car?
Thanks
Old 05-08-2008, 11:41 AM   #171 (permalink)
Old 05-08-2008, 04:36 PM   #172 (permalink)
oHsevenGG_Si's Avatar
I'm hoping to do this install tomorrow, advice tips or advice? or anyone in socal whose done this and is willing to help?
oHsevenGG_Si is online now
Old 05-09-2008, 05:36 PM   #173 (permalink)
my god. lol. thats a job, took me roughly 4 hours cause well... i kept coming inside and lookin at the DIY then i had to go buy an extension cause i didnt have one long enough. few breaks cause its hella hot.
oh and that stoopid hose. thanjks to the diy and everyones trials on it, i was able to get it off with ease lol. +1 for those who've struggled before me. jus get urself a needle nose clamped on the ends and pry with a flathead, comes pretty easy.
Old 05-09-2008, 08:16 PM   #174 (permalink)
Jordan
haha, nice work.^^^
Old 05-09-2008, 10:31 PM   #175 (permalink)
Old 05-09-2008, 10:36 PM   #176 (permalink)
Honda Dealer is where I got mine. I'm fond of the blue coolant lol. and i drained mine until it didnt drip lol... to fill it took more than a gallon so id buy 2 gallons so you have more than enough.
Old 05-10-2008, 12:28 AM   #177 (permalink)
Awesome! Thanks for the help I just have to buy a torque wrench and some coolant and I'm all set.
I'm going to do this Tuesday I think
Old 05-10-2008, 01:42 AM   #178 (permalink)
TQ wrench FTW lol. I almost had to buy a new one then I found my hiding from me. :P Goodluck with the install. +}
Old 05-10-2008, 12:13 PM   #179 (permalink)
^ Thank you I greatly appreciate it.
I'll post here to tell ya how it went :)
Old 05-10-2008, 06:32 PM   #180 (permalink)
Wait...why did you buy 2 gallons? Shouldn't you of just poured the same coolant that came out and then top it off with just a little bit of new coolant?
Why did you replace all the coolant w/ brand new coolant?
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/44275-diy-hondata-img-install-q-style.html
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 02-25-2008 07:22 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-03-2008 08:23 AM
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
How easy is it to install the Hondata IMG......... Dwn4nythn
