#141 (permalink) | |
Doesn't the bypass just reroute coolant flow from the throttle body only? Even if you have done the bypass isn't there still coolant flow between the intake manifold and cylinder head? For starters I don't have the bypass done because I live in Toronto, its cold here in the winter.![]() |
#142 (permalink) | |
#145 (permalink) |
yeah i wanted to see the difference my filter on my injen cai was 65 degrees it got hotter towards the maf but right back down to about 70 at the throttle body then up to the hottest point i could find on the monifold was 150 to 160 then after the gasket about 110 to 115
#148 (permalink) |
i mean doing a coolant bypass from the throttler body to the engine to keep the throttler a little cooler. is that good on the long run?
"honda only runs there coolant make sure you only run theres bad news if not" what did you mean by that? i can only use honda coolant? what wrong with other coolant? |
#153 (permalink) | ||
I'm not sure if maybe the changed it for '07, but my '07 Si has the blue coolant that is sold in the dealership. I'm using it. Have had it on for about 10k miles now with no problems. ![]() |
#157 (permalink) | |
Northeast-the place to be
you mean the reflash man? it's not a chip. you send out your ecu to Hondata and they tweak it a bit. yes, there are quite a few people on this board that have it done. search in the "bolt ons and all motor" section.
Northeast 8thcivicfest 08' day 1 5/17/08 Northeast 8thcivicfest 08' day 2 5/18/08 |
#159 (permalink) |
hey guys, just did this task today with a friend, 3 hours total. the POS clamp that everyone were talking about, is it require to use adjustable clamp, because i put the old one back on, and it fits good. i did relocate the ground wire. Great DIY, helps a lot.
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/44275-diy-hondata-img-install-q-style.html
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 02-25-2008 07:22 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-03-2008 08:23 AM | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
