#122 (permalink) | |
Moderated
at least 5 hours of labor. actually, maybe only three but I seriously doubt that. you can expect a 300 dollar bill, and it would be for a part that cost you, what, 50 bucks? NOT worth it. |
#123 (permalink) | |
Moderated
bottom line, don't go to a shop or a dealer- you could spend your 350 on an X intake or something else and get way better power gains for your money. what's nice about the IMG is that it is fairly inexpensive and it is a great way for you to learn about your car (if you don't already know how to do something like this). believe it or not, I actually installed my IMG without taking off the front end, and it wasn't that bad. I'm not sure I'd want to do this again- if I helped someone else with it, I would DEFINITELY want to charge them something. |
#130 (permalink) |
I didn't see anything mentioned about any form of gasket sealer. I did the gasket just the other day being the car is garaged for winter. When I installed and torqued to spec (which I thought was 16 ft/lbs from what is on here. I started the car and let it run for a bit and coolant came out from the side the coolant ports are on. I tightened the bolts a little bit more and it stopped, but now I fear it could possibly be leaking into the manifold.
#134 (permalink) |
Moderated
I'm not sure of the sequence, but here's the order in which I did it- I tightened the top leftermost down part of the way, then the bottom rightermost, top center, bottom center, et cetera. once they were mostly tight, I went back over all of them and gave them a little more.
I don't have any coolant leaks, and my car runs great, so I must have done something right. ![]()
#135 (permalink) |
That sequence is how I did mine so must be ok there. Probably my leak occurred from not going back over them a second time which I did after finding that leak. I'm just paranoid that somehow the pressure from the bolts isn't distributed as well to create a tight seal around the coolant passages. It's all in my head I'm sure. Did you add any gasket sealer for your installation?
#138 (permalink) |
Northeast-the place to be
i would imagine you can get away with draining "some", but why take the chance. just drain it all and put it back when you're done.
Northeast 8thcivicfest 08' day 1 5/17/08 Northeast 8thcivicfest 08' day 2 5/18/08 |
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/44275-diy-hondata-img-install-q-style.html
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 02-25-2008 07:22 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-03-2008 08:23 AM | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| How easy is it to install the Hondata IMG......... | Dwn4nythng | Bolt-Ons And All-Motor | 14 | 05-20-2007 05:11 PM |
| Hondata IMG Install ? on 06 Si | Nox | Bolt-Ons And All-Motor | 4 | 09-14-2006 12:58 PM |
| IMG install?!? | SonicK20Z | Bolt-Ons And All-Motor | 1 | 06-21-2006 05:45 PM |
