Old 10-19-2007, 02:32 PM   #101 (permalink)
Driversound's Avatar
Is it worth doing this? What are the pros and cons? Seems like a lot of work for a gasket.
Driversound is offline
Old 10-19-2007, 03:25 PM   #102 (permalink)
Blouch
HanCivicSI's Avatar
G
Pros: Lower your intake temperature
Cons: Putting it on!
Before you install, let car warm up to optimal temp, then (carefully!) place your hand on the intake manifold. It will be lava. After installing the IMG, place hand on IM at operating temp, it will be warm but not hot. Hot IM bad, colder IM good. Cheap mod for what it does.
Matauz, it takes a little more time to take of the brace in front of the intake but definitely worth the space you gain to wiggle that damn intake off!!
HanCivicSI is offline
Old 10-19-2007, 04:18 PM   #103 (permalink)
ley
Dimitri
Mine just got done this morning. Its not as hard as this DIY makes it out to be, especially if you have the right tools.
-You don't have to completely remove your intake, just disconnect it.
-You don't have to take off the front frame bracket, the OP just did it to make it easier for himself.
Make sure you drain the coolant. If you do this without draining the coolant, not only will it leak everywhere, but you might get an air bubble inside, and then your car will start revving up by itself. We had this problem on a 2003 RSX-S we did the IMG for.
Took 1 hour and a half.
ley is offline
Old 10-19-2007, 04:44 PM   #104 (permalink)
Thanks for your help guys. I am going to drain the coolant before I do this anyway but I'm a little confused about the air bubble that would have my car rev. Air bubble where? And it causes it to rev?
Old 10-19-2007, 10:42 PM   #105 (permalink)
Northeast-the place to be
Qshooter151's Avatar
Jordan
thanks for the input guy but everything you stated here is in my DIY. well other than you botching up the RSX IMG install of course. and it took you an hr and a half cuz you followed my DIY glad i could help...
Qshooter151 is online now
Old 10-20-2007, 02:48 AM   #106 (permalink)
ley
Dimitri
I am sorry did you take offense or something? I came to this DIY after I did my install lol to see what people were saying about their gains.
Sorry didn't see where you said you have to drain the coolant, but you say you have to remove the intake and the front frame bracket, both being completely unnecessary and adding probably 30 more minutes of time, thats all I was saying bro. People were probably looking all the steps to remove just the bracket and getting overwhelmed so I was just helping them out.
BTW I just have a random question. Why does Hondata say to reroute the ground wire? I didn't and no problems here. I guess Hondata thinks the IM isn't grounded anymore because its not connected to the metal gasket? Its still contected to the body of the car via the black bracket underneath.
ley is offline
Old 10-20-2007, 12:55 PM   #107 (permalink)
Jordan
just simply stating that what you posted is in the DIY. that's all. thanks for the input and the rep.
I do not know why Hondata says to relocate the ground wire. it's also connected through the studs.
Old 10-20-2007, 03:04 PM   #108 (permalink)
ley
Dimitri
I just did it last night to be safe. I felt like I was going to break that plastic cover into 100 pieces though.
ley is offline
Old 10-30-2007, 09:46 PM   #109 (permalink)
TRobJunior's Avatar
06 GG Si
I just put my hondata IMG in 2 day & I must say... It wasent fun, it was so hard 2 get the manifold off. BUt ne way got it done, nice right up.
TRobJunior is offline
Old 10-30-2007, 09:48 PM   #110 (permalink)
Whos The Whore NOW
07mugencivic's Avatar
Tony
nice write up
07mugencivic is offline
Old 10-30-2007, 09:56 PM   #111 (permalink)
Checoman's Avatar
This should be at the beginning of the thread .... and I thought bumper removal was a PITA
Checoman is offline
Old 10-31-2007, 12:25 AM   #112 (permalink)
ley
Dimitri
Its a piece of cake if you buy the Honda clip remover for like 5 bucks
ley is offline
Old 10-31-2007, 09:44 PM   #113 (permalink)
Best. Soft Drink. Ever.
Gonzo's Avatar
I need to buy some newclips. They can't handle but so many times of being pulled out and put back in. (Note: I have taken off the bumper many many times.)
Gonzo is offline
Old 11-11-2007, 03:33 AM   #114 (permalink)
Drisko's Avatar
This mod combined with a throttle body bypass mod and a CAI will definitely see some HUGE decrease in intake air temps!
Drisko is offline
Old 11-11-2007, 04:21 PM   #115 (permalink)
Just finished doing this mod. I have to say it was a bitch and a half to do. The hardest part of it was getting the clamp underneath the manifold loose (circled in red on the dyi) and wiggling that manifold out. Worth it though. After a few minutes of driving and a few hard runs, the manifold was cool to the touch the the throttle body was even cooler (tbs).
Old 11-13-2007, 07:56 PM   #116 (permalink)
Scott
Followed your DIY and did the install this weekend. It was a great help. Thanks!!!
sb12007 is offline
Old 11-25-2007, 11:24 PM   #117 (permalink)
Micah's Avatar
micah
would this void you warranty?
Micah is offline
Old 11-26-2007, 03:03 AM   #118 (permalink)
Moderated
ErichPryde's Avatar
Erik
no. not unless you screwed up your engine and honda determined it's because you: 1) didn't tighten the intake manifold down again properly, and something catastrophic happened. 2) forgot to reconnect a vacuum line and something screwed up permanently (which is highly unlikely) 3) dropped something INTO the combustion chamber while you had the intake manifold disconnected, 4) had an issue getting the fuel rail connected and something catastrophic happened (also unlikely).
essentially, unless honda can directly prove that either this IMG, or something associated with it, caused a problem, it can not void your warranty.
ErichPryde is offline
Old 11-29-2007, 02:29 AM   #119 (permalink)
civictypesEX's Avatar
AWESOME! Thanks for the DIY.
civictypesEX is offline
Old 11-29-2007, 05:44 AM   #120 (permalink)
Jordan
no problem. glad i could help out!
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/44275-diy-hondata-img-install-q-style.html
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 02-25-2008 07:22 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-03-2008 08:23 AM
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
