Old 06-17-2007, 08:30 PM   #21 (permalink)
Artem
for those who have installed the IMG. Do I need to move the grounding wire to the valve cover? I would rather have it hidden behind the cover... any opinions?
infiniti_4_life is offline
Old 06-17-2007, 08:41 PM   #22 (permalink)
Northeast-the place to be
Qshooter151's Avatar
Jordan
i drove my car with it both ways without any problems...
Qshooter151 is offline
Old 06-17-2007, 09:02 PM   #23 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
Great write up. I watched dentrecords attack this project yesterday and the road blocks he ran into sometimes sucked.
That's the worst clamp ever. There is hardly any room whatsoever to get underneath the pinch the clamp and there is no clearance in our engine bays to get it from the side.
Yodums is offline
Old 06-17-2007, 09:08 PM   #24 (permalink)
Jordan
tell me about it bro. it was at this point when i almost decided to put my sh*t back together. i had to step away, take a breather and grab some water...
Old 06-17-2007, 09:12 PM   #25 (permalink)
Raging's Avatar
Now that you have it..... Do you feel "any" difference whatsoever??
Raging is offline
Old 06-17-2007, 09:16 PM   #26 (permalink)
Jordan
ummmm.....no. but it's designed to work with other bolt ons. it's a piece of the N/A puzzle if ya know what i mean. each piece adds a little here and a little there...
Old 06-18-2007, 10:40 AM   #27 (permalink)
dentrecords's Avatar
Thanks for the write up.. exactly what I ended up doing with that clamp. I ended up using a dremel to get the original off!!!
I wish I'd seen the recommendation (or at least thought of it) to remove that front bracket.. getting at a few of those bolts was a real challenge.. to say the least.
the left bolt coming out of the block had to be shaved by a thread or so simply to get the manifold off. Great write up man, you have rep.
search · FAQ · rules · report bad post · learn how to spell
Originally Posted by mitsukaiSI
just like to point out whoever it was that wrote that letter was VERY uneducated for owning a bmw . . . he must have bought it second hand cus with grammer like that theres no way he a job that pays enough for his car . . . maby his dad bought it . . . anyways whoever the **** in the civic was it was a habi si
dentrecords is offline
Old 06-18-2007, 11:21 AM   #28 (permalink)
Jordan
Yeah, that clamp sucked! If I had a dremel on hand, that ish would've been history! lol... Wish I put this up a day earlier for ya bro. Job well done. ...and thanks for the rep and comments everyone...
Old 06-18-2007, 01:12 PM   #29 (permalink)
I C U !!!
06blaksi's Avatar
Muffin Eater
Nice Write up!......you coming over to do mine now?
You must spread some Reputation around before giving it to Qshooter151 again.
Priscilla
Come to 8thcivicfest....watch Rick take my eyelids off!!!
Originally Posted by SoCal07Si View Post
are u guys blind? Of course thats a 4" drop. 1" on each wheel
06blaksi is online now
Old 06-18-2007, 01:17 PM   #30 (permalink)
Jordan
Without a doubt Paul. You know I'll help you out bro...
Old 06-18-2007, 04:41 PM   #31 (permalink)
honda06si's Avatar
justin
like Q said, you should go ahead and move it, i never moved mine because i tested the continuity between the IM and the valve cover and i also tested the volts between the positive terminal and the IM and also the postivive terminal and the valve cover and they were the same. BUT hondata recomends it, so i would do it
honda06si is offline
Old 06-18-2007, 05:47 PM   #32 (permalink)
alexv305's Avatar
Alex Valledor
Im going to be doing mine this week I hope and I still have some questions that i havent found by searching..
1. Do the IMG nuts and bolts have to be torqued? if so how many ft-lbs?
2. I am also doing the throttle body Spacer, I did the throttle body coolent bypass, when i take the throttle body off will coolant leak out or is it empty because I did the bypass?
3. Does the throttle body bolts need to be torqued also?
I will post pics also!
alexv305 is offline
Old 06-18-2007, 05:49 PM   #33 (permalink)
alexv305's Avatar
Alex Valledor
Oh one more thing to add to that...i cant edit my post for some reason..
but heres number 4.
4. Does this void my warrenty because I did it on my own or would my warrenty be valid if its installed by a certified honda mechanic?
alexv305 is offline
Old 06-18-2007, 07:57 PM   #34 (permalink)
Throbbing Member
CaliGuy's Avatar
J. M. back by popular demand!
Yes: 16 ft lbs
Yes: A little bit
Yes: 16 ft lbs
CaliGuy is offline
Old 06-18-2007, 07:58 PM   #35 (permalink)
Throbbing Member
CaliGuy's Avatar
but heres number 4.
It could (as any aftermarket part could). In reality: No
CaliGuy is offline
Old 06-18-2007, 08:09 PM   #36 (permalink)
Throbbing Member
CaliGuy's Avatar
Cant edit:
I would post up a pic of the exploded view of the Intake Manifld and TB, but it's not allowed. My suggestion: Invest in a Helm Manual for your ride (if you plan to continue modding)---best money you'll ever spend!
CaliGuy is offline
Old 06-18-2007, 10:57 PM   #37 (permalink)
DATA02's Avatar
Great Write Up man! Maybe it's just me, but I don't see the need to remove the front bracket, everything for me went just fine except for the whole TB maneuvering (it really needed encouragement).
DATA02 is offline
Old 06-22-2007, 07:02 AM   #38 (permalink)
Jordan
thanks!...yeah, you don't have to remove the front bracket, however it makes the job much easier...
Old 06-25-2007, 04:52 AM   #39 (permalink)
hondaonchrome's Avatar
Lonny
Well i am going to tackle this later today so wish me luck.......
hondaonchrome is offline
Old 06-25-2007, 06:33 AM   #40 (permalink)
Jordan
good luck bro! i'll be on & off 8th all day. post here or shoot me a pm if ya need some help...
Digg this Post!
