DIY--DCRH Install - Page 25 - 8th Generation Honda Civic Forum
Old 08-09-2009, 02:17 PM   #481 (permalink)
asdf's Avatar
rich
asdf is online now   Reply With Quote
Old 08-09-2009, 06:28 PM   #482 (permalink)
UnlimitedSi's Avatar
Anything with proper torque specs is worth archiving.
UnlimitedSi is offline   Reply With Quote
Old 08-10-2009, 10:01 AM   #483 (permalink)
rcallaham's Avatar
Russell
^Agreed. Excellent info.
rcallaham is offline   Reply With Quote
Old 08-12-2009, 12:04 AM   #484 (permalink)
Michael Wofford
i'm having some diffculty maneuvering the new header into place. my car is on ramps and the header seems to be getting stuck on the hanger. any suggestions???
mwofford3 is offline   Reply With Quote
Old 08-12-2009, 12:26 AM   #485 (permalink)
Zeuceone's Avatar
Put the right side in first at an angle. Then while pushing the right side in put the left in. It will take some maneuvering after that. If you get stuck try tilting it foward, left, right.
Old 08-12-2009, 01:34 AM   #486 (permalink)
Wyatt
I'm both excited and depressed at the same time.. Excited because I just got my DC yesterday, but depressed because it's sitting in the garage and I don't have an exact date of when I'm going to get it installed..
I bought it from jzollars used and he sent the gasket that goes between the header and exhaust, but I need to know where to get a new gasket for the manifold.
feralbrute is offline   Reply With Quote
Old 08-12-2009, 01:43 AM   #487 (permalink)
asdf's Avatar
rich
reuse your stock one...
Old 08-12-2009, 02:13 AM   #488 (permalink)
Wyatt
Alrighty then.. Guess I'm good to go then. Thanks!
Old 08-12-2009, 03:02 AM   #489 (permalink)
asdf's Avatar
rich
It is recommended, but I don't think anyone has bought a new one. If you wanted its like ~$13 from the dealer.
Old 08-14-2009, 10:45 PM   #490 (permalink)
Piotrush's Avatar
Peter
Installed my header last night... My buddy who is a tech helped me. Took about 1.5 hours :-)
Piotrush is offline   Reply With Quote
Old 08-15-2009, 04:16 PM   #491 (permalink)
CMS062407's Avatar
I bought a used BCRH and it did NOT come with hardware, the nuts and bolts and w/e else....will i be able to use my STOCK nuts and bolts from the stock header? also, shoud i replace any gaskets as i do this?
thanks guys!
CMS062407 is offline   Reply With Quote
Old 08-15-2009, 05:23 PM   #492 (permalink)
Robstunner's Avatar
Rob
thanks guys!
i got my strup new and it didnt come with anything but stickers and a gasket (and bolts for the exhaust side). i would replace ur gasket, but using your stock bolts and nuts should be ok.
Robstunner is offline   Reply With Quote
Old 08-15-2009, 09:36 PM   #493 (permalink)
db8typer's Avatar
thanks guys!
I think you are going to need to get some bolts and nuts as well as a gasket to go in between the header and exhaust. I can't remember exactly but I think the stock bolts are connected to the cat where it connects to the exhaust. You can re-use the exhaust manifold gasket.
db8typer is offline   Reply With Quote
Old 08-18-2009, 08:18 PM   #494 (permalink)
Undftd:Fiji's Avatar
I have a Vibrant RH w/ HFC thats going to be bolted on my Ti-c.
Was wondering what size for 3 bolt gasket do I need? (where the header flange meets the midpipe)
I think its 2.5" but I want to make sure of it.
Undftd:Fiji is offline   Reply With Quote
Old 08-22-2009, 03:26 AM   #495 (permalink)
Wyatt
I finally got my header installed today with a lot of help from GGEX and iiVtec. To those who got it done in less than three hours, I am very jealous of you..
The bolts and studs to the head as well as the bolts connecting the exhaust weren't any problem at all. But for some odd reason, the 14mm bolt connecting the stock header to the frame took FOREVER to get off. Once it was gone, the stock header came right out.
This guide and posts were very helpful, but having an extra set of hands or two makes all the difference.
Old 08-27-2009, 07:36 PM   #496 (permalink)
i_Vtec_2's Avatar
this is a good diy. i just installed my dcrh today and followed this DIY. very helpful. it took me 5 hours on a lift bymyself. i took many break and had to wait for the engine to cool down. plus i spent over an hour messing with the dang exhuast manifold gasket, had it on backwards. two ppl would be nice becuase its hard trying to align everything up by yourself. oh yeah, i got a busted finger too, so far over 50 miles no cel
i_Vtec_2 is offline   Reply With Quote
Old 08-29-2009, 10:55 PM   #497 (permalink)
ryyiann's Avatar
Ryan
good diy... i used it to install a vibrant header today
ryyiann is offline   Reply With Quote
Old 09-02-2009, 08:44 PM   #498 (permalink)
Pete
So from reading half of this thread, it's mostly directed towards installing the DCRH (obviously, lol). I am not the most mechanically inclined person, but do have access to a shop with air tools, lift, etc.
I am ordering Vibrant RH (catless) with the Vibrant Gen 2 exhaust along with FlashPro. I have no concerns with the exhaust, but here's what I would like to confirm:
1) Do I need to lower the sub-frame at all to get the Vibrant in?
2) Given that I will have FlashPro at the time of install, can't I disable the secondary O2 sensor?
2) If #2 is yes, then do I even need a defouler, or can I just put the secondary 02 in the rear bung and disable it and be all set?
Also, can someone summarize some tips for me?
Thanks in advance for your help.
Silversweet09 is offline   Reply With Quote
Old 09-02-2009, 09:16 PM   #499 (permalink)
Zeuceone's Avatar
1. No
2. Yes
3. No defouler
Old 09-02-2009, 09:52 PM   #500 (permalink)
Pete
Thanks very much Zeuzeone!
Follow up question - regarding the bolts/nuts that attach the header to the engine...the studs are in the engine, correct? So all I am taking off is the nuts, and when they are off the header slides out and I should see studs coming out of the engine block? I've read some people have issues with the studs coming out, how do I prevent this from happening?
Are there any tips/tricks that you can share with me? Given that the only things I have ever done on a car before are intake, brakes, oil changes, calibers & once I replaced a Master Cylinder...do you think this is something I should try and tackle, or pay 250 bucks to get it done at P-Tuning?
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/35288-diy-dcrh-install.html
K20Z3 spark plugs This thread Refback 06-18-2011 11:32 AM
2006+ Honda Civic and Civic Si Performance Parts This thread Refback 02-21-2008 02:21 AM
DIY: Injen CAI install on R18 (lots of pics) peliROJO Engine 168 02-04-2012 02:53 PM
DIY: Aftermarket rear speaker install on FG2 (excluding subwoofer) *Lots of pictures* mort Audio 144 01-10-2012 05:08 PM
K&N Short Ram Intake DIY Install for Si, with Pics! dowNNshift Do It Yourself Articles 88 01-18-2008 01:25 PM
Need DIY!!! Want DIY on hondata gasket install xxmstajxx Do It Yourself Articles 3 12-29-2006 04:51 PM
DIY install of new head unit in sedan UK/AUS aussiebuddha I.C.E., Electrical, Security, & Navigation 4 04-04-2006 03:30 PM
