#1 (permalink)
![]() Join Date: Apr 2006
Dent
DIY: Si axleback on DX/LX/EX
What you'll need.
-Si Axleback Exhaust -Si gasket off resonator -12mm socket, Ratchet -Can of PB Blaster is very helpful -Long flathead screwdriver -Jack, Stands, Chocks (you really shouldn't be messing about underneath the car if you haven't taken the appropriate precautions) -A nice warm place to do this. I found a heated garage before the start of my shift is perfect. Let's get started. Collect the Si Axleback exhaust and the gasket from the resonator. ![]() Jack the car up using the appropriate precautions. The bolts that hold the axleback on are located just in front of the rear axle. You will need to remove these. ![]() You may find they don't come off like they were just installed from the factory so you may want to give them a squirt with PB blaster. Alternatively, you can also use an impact wrench or long breaker bar. ![]() ![]() ![]() Use the long flathead screwdriver to break the muffler free from its hangers. You can also use your hands. ![]() Here are the two mufflers. The Si exhaust has a larger diameter inlet pipe and a much nicer looking tip. ![]() Remove the gasket from the resonator. I used the flathead screwdriver and wedged it in between the piping and the gasket itself. Take care at this point not to damage the original gasket in case you want to reuse it (although a new gasket is the recommended way to go). ![]() The Si gasket on the left, versus the LX gasket on the right. ![]() The resonator sans gasket. ![]() With the Si gasket. It's a little bit loose, and you'll need to sandwich in between the axleback and the resonator until you get the bolts in place. I used the same bolts that I just took off to put the axleback in place. ![]() At this point, once you've got the bolts back in, re-torqued, and the hangers in place, you can get out from underneath the car and admire your work. ![]() Enjoy your car's improved appearance and sound. |
![]() Join Date: May 2006
Mikey
You gotta check the tension on the springs that go with the muffler bolts. If the springs are loose when the bolts are bolted all the way in, you have to take it apart and stretch the springs or add a big washer. If you don't, you get some ghetto fabulous spring rattling.
#8 (permalink) | |
Its a Live2Hustle Thang...
you just solved my problem THANK YOU |
#10 (permalink) | |
Dent
http://www.8thcivic.com/forums/sale-trade-items/ |
#11 (permalink) |
Chris
I hate to bump this old of a thread, but I have one question. I have a OEM Si AxleBack being shipped to me, but it does not have the SI Gasket. Is the gasket something I can go buy at a local hardware store? or is it really custom fit to the Si?
I'm going to be doing this as soon as my AxleBack arrives, so I just want to be prepared. Thanks! |
#18 (permalink) | |
Chris
#19 (permalink) |
Dent
heh
clearly you've not been through a Canadian winter with salt on the roads.. take a look at the original date posted oh and by the way, that's my girlfriend's.. here's mine http://www.8thcivic.com/forums/showthread.php?t=39496 |
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/31535-diy-si-axleback-dx-lx-ex.html
| Exhaust thread: Will it fit? - 9th Gen Civic Forum : 2012 Honda Civic Forums - 9th Generation | This thread | Refback | 09-21-2011 05:45 PM | |
| Exhaust thread: Will it fit? - 9th Gen Civic Forum : 2012 Honda Civic Forums - 9th Generation | This thread | Refback | 09-21-2011 04:48 PM | |
| Exhaust sedan sur un coupe - Club Civic Quebec :: Forum | This thread | Refback | 06-22-2011 11:56 AM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-19-2008 11:46 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-05-2008 08:24 PM | |
| DIY part II: Cable Shifter bushings (Big Pictures inside) | atruhondagrl | Transmission | 171 | 02-04-2012 06:11 PM |
| DIY Fabric Change on Doors | esx005 | Interior Style Mods | 1319 | 02-04-2012 07:14 AM |
| DIY: Aftermarket rear speaker install on FG2 (excluding subwoofer) *Lots of pictures* | mort | Audio | 144 | 01-10-2012 05:08 PM |
| DIY - LED Ambience Light on 4DR sedan :) | bad andy | Lighting | 28 | 03-15-2010 02:11 PM |
| Need DIY!!! Want DIY on hondata gasket install | xxmstajxx | Do It Yourself Articles | 3 | 12-29-2006 04:51 PM |
