Old 09-06-2008, 06:06 PM   #141 (permalink)
Garrick Mundy
i got mine from autozone
Show Stoppa FG1 is offline   Reply With Quote
Old 09-29-2008, 10:54 PM   #142 (permalink)
08_Civic's Avatar
Bboy
anyone know how long did it take to install this? Planning to order this soon.
08_Civic is offline   Reply With Quote
Old 09-29-2008, 11:15 PM   #143 (permalink)
phil
estimated cost for someone to do this for me at a local shop?
akronmusician413 is offline   Reply With Quote
Old 09-30-2008, 12:23 AM   #144 (permalink)
Garrick Mundy
mine took 20 min. me n a friend just went at it, no problems at all!
Old 09-30-2008, 10:55 PM   #145 (permalink)
08_Civic's Avatar
Bboy
What tools did you all use?
Old 09-30-2008, 11:57 PM   #146 (permalink)
Garrick Mundy
damn, um, socket wrench, flat head screw driver and a 3 foot pipe i found in my neighbors yard as a breaker bar, other than that, i really dont remember
Old 10-01-2008, 12:14 AM   #147 (permalink)
08_Civic's Avatar
Bboy
Sorry for Double Post but Has anyone did this without an Impact Gun?
Old 10-01-2008, 01:13 AM   #148 (permalink)
Garrick Mundy
i didnt... hand tighten, and ive had it on there for about 3 months now i believe
Old 10-01-2008, 08:13 PM   #149 (permalink)
08_Civic's Avatar
Bboy
Okay thanks cause I don't have an Impact gun and I just wanted to know if it was possible to install the pulleys without the gun. So Anyone else did it with out the impact gun?
Old 10-01-2008, 08:53 PM   #150 (permalink)
r18lx's Avatar
Paul
^ you can get a cheap impact gun... but if you have along pipe that u can use as leverage to easily remove the bolts and use a torque wrench to get it to specifications...
r18lx is offline   Reply With Quote
Old 10-02-2008, 06:00 PM   #151 (permalink)
08_Civic's Avatar
Bboy
I really don't want to waste money on it because this is going to be my only time using it.But if i really need it then ill buy one. Does the pulleys need any special tighing? if not then Ill just unbolt it without the impact gun and do the same putting it back on. Think it will work?
Old 10-02-2008, 07:10 PM   #152 (permalink)
r18lx's Avatar
Paul
^ yeah it should be fine just get some type of pipe for more torque cause them bolts are really tight... then re-tighten them, drive then be happy!
Old 10-02-2008, 08:02 PM   #153 (permalink)
08_Civic's Avatar
Bboy
^ Thanks man. That's all I needed to know. I don't want to buy the pulleys and not have the right tools to get the job done. Waste of time and money. So I was just making sure of things before I do it.
Old 10-02-2008, 08:36 PM   #154 (permalink)
r18lx's Avatar
Paul
^ just make sure you get that pipe trust me!
Old 10-08-2008, 07:37 PM   #155 (permalink)
i payed 100 bucks for pro installation
yifantasia is offline   Reply With Quote
Old 10-15-2008, 04:06 AM   #156 (permalink)
sgtmorph's Avatar
Keep in mind though, every nut and bolt on the car requires a specific torque value. You DON'T want to just tighten it and hope it's right. Do the research and find out exactly what these torque values are. I'm sure NST might be able to answer these questions for you.
sgtmorph is offline   Reply With Quote
Old 10-31-2008, 02:46 PM   #157 (permalink)
RCHamel3's Avatar
Rob
I def could not get the bolts off by hand. Me and a friend tried over and over and didnt move. So im waiting for my friend to get an impact gun that he has been planning on and give that a try otherwise go to a shop.
RCHamel3 is offline   Reply With Quote
Old 11-18-2008, 10:56 PM   #158 (permalink)
raybyduhbay's Avatar
Ray
Originally Posted by el_ben2 View Post
Shut up Marco! nobody invites you here
lol
j/k
well here is a lil video i made about 15 min ago
not that good... not 0-60 but it shows how the car rev... i continue spinning a lil... gonna try again tomorrow
is that rev only from a NST pulley mod?
raybyduhbay is offline   Reply With Quote
Old 11-18-2008, 11:00 PM   #159 (permalink)
Ray
19.- re install the belt, here i drew a diagram of the belt
what are the other pulleys for? the gray ones
Old 11-19-2008, 01:00 AM   #160 (permalink)
sgtmorph's Avatar
one is definetly for the a/c compressor.....
not sure about the other 2 though...??
Tags
nst, pulley
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/29230-r18-nst-pulley-kit-diy.html
NST pulleys - 8th Generation Honda Civic Forum This thread Refback 01-22-2008 05:38 PM
R18 NST pulley kit DIY - Page 3 - 8th Generation Honda Civic Forum This thread Refback 01-07-2008 03:02 PM
R18 NST pulley kit DIY - 8th Generation Honda Civic Forum This thread Refback 12-14-2007 06:39 PM
DIY: Injen CAI install on R18 (lots of pics) peliROJO Engine 120 02-03-2010 02:27 AM
NonStopTuning (NST) K20 SI Kit DIY, Pics, Dynos... 8civic Engine 99 09-13-2009 09:56 PM
NST tuning pulley kit rw_blaze Engine Swaps, Mounts, Pulleys 62 05-01-2009 05:34 PM
DIY ** NST Civic SI underdrive pulleys MADDOGSI Mechanical Problems & Technical Chat 200 08-11-2008 01:54 AM
NST for R18 mfinlay04 Bolt-Ons And All-Motor 0 01-18-2007 03:15 PM
