Franken Car
Justin aka Mr. JT
DIY Custom exhaust
This is for all of those who can't afford to buy a $300+ axel back or exhaust.
I will be doing this piece by piece so bare with me. Some of my parts aren't in yet. Below are pictures of measurments (I know they are corny but they helped out alot). picture 1: ![]() picture 2: (new exhaust) ![]() Here is a picture of parts I got from a local exhaust shop (Thank you Midas): ![]() You can't use the stock axel back because the outlet pipe is offset to far to right and up. So rather than modify that i will be starting fresh. The parts are: 2 pre bent pipes to create angle I need 2 1/4 to 2 1/2 Cupler 2 inch to 2 1/4 Cupler 2 1/4 exhaust flange 2 inch to 2 inch Cupler 2 8 inch threaded rods to use as hangers for muffler (will bend with torch) 2 3/8 nuts (all hardware is Galvanized) 2 3/8 washers I will take measurments after welded and assembled. Picture Assembled not welded: ![]() This is all I have for now muffler didn't come yet. Will keep you posted. The total so far on parts is around 30 bucks The muffler costs 31 bucks Total 61 dollars. I will be going to track to do: 3 runs stock 3 runs new exhaust W/silencer in 3 runs no silencer If it doesn't give me performance i will start from scratch. LOL Here are pix of flange pressed to outlet pipe. In this picture it shows you the tapered edge so I can use the stock exhaust gasket. ![]() ![]() ![]() ![]() Assembled long view one: ![]() Assembled long view two: ![]() Now all I need is muffler and a good welding some assembly and all done! Got the muffler! ![]() Im going to have to add 2 more screws to keep silencer centered. ![]() Assembled on floor! ![]() Outlet view ![]() inlet view ![]() The next Pictures are the muffler and piping hung under the car with some Zip ties, Sharpie marker and alot of patience........... picture 1 ![]() picture 2 ![]() picture 3 ![]() Finally picture 4 ![]() Note: I did this so I can get precise measurements for final weld and build. I will be welding the pieces together monday night! Here are the pix of welded exhaust: ![]() ![]() ![]() I have to grind the welds we ran out of oxygen in the tank so we had to make do.... Nothing a diegrinder can't fix!. I will also be changing the hanger setup to a different type of rod so it is easyer to bend. Unfortunately I found out the hard way but that is what this is all about. Final weld pictures ![]() ![]() ![]() Video's Drive by: ![]() Cold start in morning: ![]() Last edited by fiji06si13; 03-01-2007 at 09:30 PM. |
#4 (permalink) | |
Franken Car
Justin aka Mr. JT
a axel back you know. If it does hurt power i will redo the piping. we will see lol! |
#6 (permalink) | |
Franken Car
Justin aka Mr. JT
I'm doing this for fun. Anyone can buy a axel back and put it on. I would rather make my own and see how it is. It's only 60 bucks down the tube and last I checked you could spend more than that at a night in the tity bar. Plus who says it isn't right? |
#11 (permalink) |
Franken Car
Justin aka Mr. JT
I hope you guys like the muffler I chose it goes well with the car as long as all goes well.
![]() The tip should go nice with the color of my car. Last edited by fiji06si13; 02-09-2007 at 08:51 PM. |
#13 (permalink) |
Franken Car
Justin aka Mr. JT
flange and gasket surface
I will be cutting the pipe that will except flange 2 morrow and put the pix up in evening. I will be doing this to create a tapered edge for the gasket to seat to.:)
#17 (permalink) | |
Franken Car
Justin aka Mr. JT
