#21 (permalink) | |
1/8 ratchet long extension 12mm open wrench. ill try to post up some pics later.... |
#22 (permalink) | |
Added to DIY Sticky. Thanks BCJ!
![]() search · FAQ · rules · report bad post · learn how to spell Quote:
#24 (permalink) |
BEWARE THE REP!!!!
Not trying to be that guy, but the DIY didnt really go into enough detail I think. Pretty much said remove everything and put on the new gasket, put it back together. Good DIY should show how to remove all the parts involved in the process. My $0.02
#25 (permalink) | |
#29 (permalink) | |
I have the TB gasket. I also bypassed the coolant to the TB at the same time. I wish I had recorded the temp before/after, because the TB stays nice and cold now |
#30 (permalink) | |
#34 (permalink) | |
#38 (permalink) |
8thcivic Sponsor
You guys should look at using our extended intake manifold stud kit. The stock studs are a little on the short side (35mm) to make up for the thicker Hondata gasket. We use a premium German stainless steel stud (50mm) and we also include brand new Honda flange nuts and also heat insulating washers. The washers are important because heat is still transfered from the head to the manifold via the stock studs/nuts/bolts. You can check them out here:
http://www.kingmotorsports.com/categ...59#Product_494 ![]() |
#39 (permalink) |
All right, this is my second Saturday in a row wasted attempting this install . . . I CANNOT GET TO THAT BOTTOM HOSE! I can't get my hand in there to pull it off. I don't even care if I get flamed for it at this point . . . SOMEONE HELP! Any tips or advice are appreciated.
#40 (permalink) | |
Pull out the studs. I had to do it. I tried and tried and tried for hours to get that bottom hose off, and I couldn't. I ended up taking the studs out (they aren't more than finger-tight from the factory). The simplest way to do it would be to tighten two nuts together on the stud, then use your open-end wrench on the inner nut to back out the stud. When you're done and ready to put the studs back in, just finger-tighten them, then use a pair of pliers to GENTLY snug them into the head (be careful not to ruin the threads). I did this and everything went back together great. Hope this helps. |
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/27974-diy-hondata-img-install.html
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-19-2008 10:45 PM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 01-09-2008 11:24 AM | |
| K&N Short Ram Intake DIY Install for Si, with Pics! | dowNNshift | Do It Yourself Articles | 88 | 01-18-2008 12:25 PM |
| How easy is it to install the Hondata IMG......... | Dwn4nythng | Bolt-Ons And All-Motor | 14 | 05-20-2007 05:11 PM |
| Need DIY!!! Want DIY on hondata gasket install | xxmstajxx | Do It Yourself Articles | 3 | 12-29-2006 03:51 PM |
| Hondata IMG Install ? on 06 Si | Nox | Bolt-Ons And All-Motor | 4 | 09-14-2006 12:58 PM |
| IMG install?!? | SonicK20Z | Bolt-Ons And All-Motor | 1 | 06-21-2006 05:45 PM |
