Install of fuel pressure gauge on 07 SI
Ok, What you'll need to install it.
Go out to your local autoparts store and buy a 'T' then buy 2 barbed ends that screw into it. Fuel doesn't seem to like plumbers tape so I used locktite [blue] and don't forget the hose clamps. Let the car sit for a min. or two so the pressure in the line goes down. Then there are 2 quick locks on each end of the line disconect these and remove the line. now cut the line you will notice there is a plastic liner running thru this fuel line. Now it's not that easy to shove the barbs in you really have to push hard but they'll fit. Don't forget you will be cutting out a small section of the fuel line so it's the same length. Just cut small amounts off and keep holding up to the lock connectors to make sure it fits. And that it! Now you know that installing a fuel pressure gauge like we have down is only for show! But later if you decide to install a fuel pressure regulator you'll be able to take adavatage of the gauge. Took about 15 min.s to install. Have Fun!!!!! ![]() |
#10 (permalink) | |
| Boosting an FG FAQ | Highrev1 | Forced Induction And Nitrous | 52 | 05-25-2008 04:58 AM |
| DIY 2006 SI Turbo Related: Fuel Injector and Rail Removal/Installation (PIC Heavy) | blueroadster | Engine | 38 | 02-13-2008 10:20 AM |
| Nitrous 101 | FG*SQUAD Nick | Forced Induction And Nitrous | 22 | 05-26-2007 01:50 AM |
| Tire pressure check method?? | MADDOGSI | Mechanical Problems & Technical Chat | 19 | 02-19-2007 02:14 AM |
| 2006 honda world news | webby | Garage | 0 | 07-25-2005 09:31 AM |
