#1 (permalink)
Geezer Squad member #72
DIY: Throttle Body coolant by-pass...
If you want a no-cost mod. to lower the temperature of the intake charge, the following DIY shows you how to by-pass the hot coolant that is normally circulated around the Throttle Body. Keep in mind that if you live in the northern U.S. or Canada where winter temperatures drop well below freezing, this mod. may not be for you. Only attempt this mod. if you feel that there would be no potential for icing up of the throttle plate inside your throttle body.
First step is to prepare about 18" of 5/16" I.D. fuel hose to be used as the new by-pass hose. ![]() Then remove your intake to be able to get to the two 5/16" I.D. coolant hoses that run from the engine to the TB. Remove the two hoses shown ![]() Next, remove the coolant line that runs to the top side of the engine as shown ![]() Take your new hose and clamp and secure it in place there. Next, remove the lower hose that connects to a nipple on a black coolant pipe and clamp the new hose in place. ![]() Wash away any spilled coolant at this point, taking care not to get any water into the TB or the manual transmission vent (small right-angle rubber tip facing forward sticking out of the tranny). I also flushed out the Throttle Body after removing the lines and capped the nipples. Optional: Take some 1/2" I.D. plastic corragated cable covering and place over the new by-pass hose to protect the near-by fuel line from heat. ![]() Reinstall your intake, making sure you reconnect the MAF sensor harness and vent lines and start 'r up and check for leaks. This mod. really drops the temperature of the throttle body which in conjunction with an intake manifold insulating gasket (Hondata style) should really help drop the intake air temperature making for a denser and more powerfull charge. Enjoy... Bill. ============================= |
#5 (permalink) | |
Tuna Fiddle
![]() Join Date: Jan 2006
Dave
#6 (permalink) | |
#7 (permalink) | |
:banned:
Yeah...you might wanna do that asap. your car might have met an early death if you drove in AZ or Tx in the summer like that.
#9 (permalink) | |
#14 (permalink) |
Andrei
I've tried this on my older 1994 Mitsubishi Mirage, good no bad effects. But with my friend's 01 Honda Civic (lives in socal) his throttle body iced up and his throttle response and acceleration sucked until we reversed the modification. Also tried this on a 2003 Nissan Sentra XE, dad drove the car, coolant leaked, engine overheated. A month later car has problems starting. Under emissions warranty following a Technical Service Bulletin they changedthe fuel pump or pressure regulator. A year later the problem came back progressively until the dealer got their hands on it and said it needed a new head gasket. Be careful with this mod.
#15 (permalink) | |
![]() Join Date: Dec 2006
Jordan
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/25348-diy-throttle-body-coolant-pass.html
| Coolant by-pass - Club Civic Quebec :: Forum | This thread | Refback | 09-20-2011 06:43 PM | |
| Throttlebody coolant Bypass mod - Page 2 - 8th Generation Honda Civic Forum | This thread | Refback | 02-19-2008 10:19 AM | |
| DIY: Throttle Body coolant by-pass... - 8th Generation Honda Civic Forum | This thread | Refback | 02-13-2008 03:20 PM | |
| TB spacer - ClubSi | This thread | Refback | 01-05-2008 03:44 PM | |
| DIY: Throttle Body coolant by-pass... - Page 2 - 8th Generation Honda Civic Forum | This thread | Refback | 12-27-2007 11:23 PM | |
| Big-Bore Throttle Body for the K20 | Ep3racer954 | Forced Induction And Nitrous | 16 | 09-02-2009 10:03 PM |
| Throttle Body Coolant Bypass On ((R18)) | sparda | Bolt-Ons And All-Motor | 22 | 06-29-2009 10:50 PM |
| Just a thought about our throttle body | legendman | Civic SI | 12 | 10-02-2006 02:12 PM |
| 06 si vs 02-05 rsx intake manifold and throttle body.. | OneSi | Intake & Spacer Discussion | 11 | 12-28-2005 09:02 PM |
