Closed Thread
LinkBack (4) Thread Tools Display Modes
Old 07-01-2007, 01:02 PM   #81 (permalink)
mO 64 StAnG 06's Avatar
It's very simple.
-Find the two hose's on the TB and follow where they connect to.
-Remove just one hose completely.
-With the one still left on, Remove the end on the TB and route that line (while still connected to the engine) to the other port on the engine. (Where you removed the previous hose from).
-With the one you have left over it, modify it or whatever and connect the two ports on the TB together.
So basically you are just connecting the two engine ports together with one of the hose's, and the TB with the other.
mO 64 StAnG 06 is offline
Old 07-01-2007, 01:59 PM   #82 (permalink)
jameslewis178's Avatar
ok that made it alot easier to understand for some reason. i think a pick was missing or something
jameslewis178 is offline
Old 07-01-2007, 05:28 PM   #83 (permalink)
NewYorkJon's Avatar
Jon
someone should just make a little video on how to do this, that would solve everyone's problems, ya know
NewYorkJon is offline
Old 07-05-2007, 02:23 AM   #84 (permalink)
CaliGuy's Avatar
J. M. back by popular demand!
I was going to do this today, but my buddy who was helping me with my IMG was saying that if the EGR is running into the TB that the coolant may be needed to cool the hot exhaust gases coming in. So, does the EGR run into the TB? It doesn't look like it does in the manual...
http://i61.photobucket.com/albums/h52/jbpray/cali-1.jpg
CaliGuy is offline
Old 07-05-2007, 10:31 AM   #85 (permalink)
We do not have an EGR. Instead, there is a block off plate near where the upper radiator hose connects to the block.
blue1 is offline
Old 07-08-2007, 06:04 PM   #86 (permalink)
fatality122887's Avatar
luke
Originally Posted by Zeuceone
yeah just water. water runs thru it as it is. it will evaporate with the heat of the engine.
well if u cap it how is the water going 2 evaporate? its just going 2 turn into a gass then turn back into a liquid when it gets colled off then back into a gas. there is really no need at all 2 flush it, because it is just a pasage way around the TB for colant to flow into around and back out. thats all it is. so flushing it is kinda pointless but if you do flush it with watter just take an air gun or caned air(if u don't have a compresser) and blow it out 2 dry up the watter and blow it all outa there befor u cap it.
fatality122887 is offline
Old 07-09-2007, 02:32 AM   #87 (permalink)
projekt1's Avatar
Originally Posted by mO 64 StAnG 06
It's very simple.
is this really all it is???.....
projekt1 is offline
Old 07-09-2007, 01:03 PM   #88 (permalink)
CBRGuy954rr's Avatar
do you have to cap the two tubes?
CBRGuy954rr is offline
Old 07-09-2007, 05:47 PM   #89 (permalink)
blanz's Avatar
Geezer Squad member #72
No. it is totally optional. I just capped them to keep potential crap out of the throttle body in case I revert back to the way it was. And yes, this is a stupidly simple mod. to drop the temp. at the T/B.
blanz is offline
Old 07-13-2007, 03:44 PM   #90 (permalink)
Yep, that's all it is.
Easiest mod I've ever done.
Old 07-18-2007, 12:16 AM   #91 (permalink)
AXIS's Avatar
Ga-Ga-Ooh-La-La
i've asked this before but i'm not sure if i asked the question. I live somewhat close to the desert but work in the desert, is this mod a good idea... we also get some snow, not a large amount but it does get below the freezing level, my car is garaged but i still want to be cautious before i attempt this mod
AXIS is offline
Old 07-21-2007, 10:03 AM   #92 (permalink)
GeorgiaBoy's Avatar
Cool Thanks
I know it has been a while since you posted this, but i am just getting around to hooking up the SI. I have however put over 35,000 miles since Feb 06 and know have several mods. This was well explained and great pics.
GeorgiaBoy is offline
Old 07-24-2007, 07:42 PM   #93 (permalink)
firstsi's Avatar
did mine today took al of 5 minutes
firstsi is offline
Old 08-09-2007, 06:22 PM   #94 (permalink)
ThatsMrGimp2U's Avatar
Everette
Took all of five minutes for me too, but after one minute of having the hose disconnected of the black pipe, coolant started gushing out of it. Hehe, needless to say my gf is on her way to pick up some more =). Prolly common sense, but do it when your engine is cold =)
ThatsMrGimp2U is offline
Old 08-09-2007, 06:50 PM   #95 (permalink)
firstsi's Avatar
yeah i took both clamps off and did the switch fast
firstsi is offline
Old 08-25-2007, 02:01 AM   #96 (permalink)
rp215's Avatar
Ronnie
It's very simple.
Thank You!
I felt like we were missing a picture and it was hard to tell what to do after blocking the TB nipples but you made it really easy without pictures.
rp215 is offline
Old 09-07-2007, 11:50 PM   #97 (permalink)
Nitto Neo Genness!!!!!!
fiji06si13's Avatar
Justin aka Mr. JT
gonna switch mine back soon getting cooler in Jerz...winter FTL....
RIP Bernie Mac, Ricardo Montalban, Lux Interior, Dom Deluise, M.J., Ed Kennedy, DJAM, Patrick Swayze, Brittany Murphy...
fiji06si13 is offline
Old 09-08-2007, 12:52 PM   #98 (permalink)
firstsi's Avatar
im gonna wait and see what happens here in md
some times i dont think its cold enough to worry about
firstsi is offline
Old 09-17-2007, 01:37 PM   #99 (permalink)
i did the same mod...however i keep the same hoses and just looped them together.....it was the same doesnt it?
gszam is offline
Old 09-17-2007, 06:11 PM   #100 (permalink)
If you meant, does it work the same, then yes.
That's what I did, I just used and trimmed the stock hoses and reused them instead. No point buying more hose.
Closed Thread
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/25348-diy-throttle-body-coolant-pass.html
Throttlebody coolant Bypass mod - Page 2 - 8th Generation Honda Civic Forum This thread Refback 02-19-2008 10:19 AM
DIY: Throttle Body coolant by-pass... - 8th Generation Honda Civic Forum This thread Refback 02-13-2008 03:20 PM
TB spacer - ClubSi This thread Refback 01-05-2008 03:44 PM
DIY: Throttle Body coolant by-pass... - Page 2 - 8th Generation Honda Civic Forum This thread Refback 12-27-2007 11:23 PM
Big-Bore Throttle Body for the K20 Ep3racer954 Forced Induction And Nitrous 16 09-02-2009 10:03 PM
Throttle Body Coolant Bypass On ((R18)) sparda Bolt-Ons And All-Motor 22 06-29-2009 10:50 PM
Just a thought about our throttle body legendman Civic SI 12 10-02-2006 02:12 PM
06 si vs 02-05 rsx intake manifold and throttle body.. OneSi Intake & Spacer Discussion 11 12-28-2005 09:02 PM
