Old 01-03-2007, 02:52 PM   #1 (permalink)
BATANG CITY JAIL's Avatar
Diy: Oil Catch Can
there is no actual pic for now...
this can be applied to all engine..
tools needed: plires
use 10mm hose or 9 mm hose for this setup. just run the hose from PCV to catch can and the 2nd nozzel on the catch can, run it on the intake manifold oil feed..
PCV location for the k20's
this i have in mind... for having the valve cover breather connected.
pics of oil catch can...but they are for sale now..
BATANG CITY JAIL is offline
Old 01-03-2007, 03:03 PM   #2 (permalink)
MoDiFiEd
sickyute's Avatar
Marvie
You must spread some Reputation around before giving it to BATANG CITY JAIL again.
i'll get u later
Shift when it blinks!
sickyute is offline
Old 01-03-2007, 03:03 PM   #3 (permalink)
MoDiFiEd
sickyute's Avatar
Marvie
now what u going to do about the breather up top?
sickyute is offline
Old 01-03-2007, 03:25 PM   #4 (permalink)
are you talking about number 1 or number 2?
Old 01-03-2007, 03:31 PM   #5 (permalink)
MoDiFiEd
sickyute's Avatar
Marvie
number 2
sickyute is offline
Old 01-03-2007, 03:58 PM   #6 (permalink)
number 2
picss up-date
Old 01-03-2007, 05:08 PM   #7 (permalink)
Originally Posted by BATANG CITY JAIL
When you boost using the above configuration, you will be blowing the pressurized air into the valve cover. If you want to run it that way, then I would suggest installing a one way check valve off of the intake manifold connection. This will also prevent the catch can from having to store the pressurized air.
blueroadster is offline
Old 01-03-2007, 05:11 PM   #8 (permalink)
^^ so its better to have a breather up in the valve cover??
Old 01-03-2007, 05:15 PM   #9 (permalink)
Marvie was commenting that he was having oil blow out of the breather filter that connects to the valve cover. The configuration that you drew is fine, but you just need to add a one way check valve between the intake manifold and catch can.
Old 01-03-2007, 05:21 PM   #10 (permalink)
thats what i though... thanks eric..
did you check the site that i gave you forthe oil fitting bte?? will that work?
+1 rep...oh wait no more rep!!!
Old 01-03-2007, 05:37 PM   #11 (permalink)
Minister of Discord
Janizary's Avatar
Gas thread Nazi
I'd give rep for this thread if it still worked.
Janizary is offline
Old 01-03-2007, 08:56 PM   #12 (permalink)
MoDiFiEd
sickyute's Avatar
Marvie
point well taken ... however we'll leave comments like these for the other thread.
on a side note ... i think i'm going to do 2 catch cans .. haha ... i just feel like it.
sickyute is offline
Old 01-03-2007, 09:04 PM   #13 (permalink)
and where are you gonna connect the other one if ever?
i mean you leave one more nozzel open on the other can..
Old 01-03-2007, 09:10 PM   #14 (permalink)
I think that you are cutting yourself short...At least three catch cans are required to solve the problem as well as provide the necessary clutter in the engine bay.
Old 01-03-2007, 09:23 PM   #15 (permalink)
MoDiFiEd
sickyute's Avatar
Marvie
i'll plug the outlet. i've seen it done this way ... it works
sickyute is offline
Old 01-03-2007, 09:25 PM   #16 (permalink)
^^ cool... but that just expensive for me lol...
Old 01-03-2007, 09:27 PM   #17 (permalink)
MoDiFiEd
sickyute's Avatar
Marvie
yeah... it will be expensive ...
what i do is cancel one mod to do the other .... so one more catch can my mean no drag radials or something like that ...
sickyute is offline
Old 01-03-2007, 09:28 PM   #18 (permalink)
Then why not just plug the connection on the valve cover itself?
Old 01-03-2007, 09:34 PM   #19 (permalink)
MoDiFiEd
sickyute's Avatar
Marvie
i didn't know that could be done...
i always thought it had to be an outlet ...
my reasoning was it came with a hose stock so it has to to be open to let something out ...
can it be plugged? is that a good thing?
sickyute is offline
Old 01-03-2007, 09:47 PM   #20 (permalink)
Well...If you are connecting the line to a catch can and then capping off the other connection on the catch can, then you might as well eliminate that catch can all together.
DIY 2006 SI Turbo Related: Subframe & Oil Pan Removal/Installation (PIC Heavy) blueroadster Engine 20 07-07-2008 10:49 AM
Oil Change DIY ethlar Engine 211 07-03-2008 03:12 PM
Everything Oil: All you'll ever wanna know atruhondagrl Bolt-Ons And All-Motor 14 06-16-2008 12:45 PM
Oil Life Elmacho Civic SI 28 04-25-2007 06:54 PM
Oil change DIY? letsgoflyers81 Do It Yourself Articles 21 10-11-2006 10:07 AM
