Old 12-06-2006, 11:59 PM   #21 (permalink)
PrivateTune's Avatar
Nice Write up...
I will save all the instructions for future reference.I have some questions for you. I saw there are two tiny air filters one below the fuel line, the other by the crank cover. What are those for and what's the purpose of changing them to filters?
Thanks A Lot
PrivateTune is offline
Old 12-07-2006, 12:13 AM   #22 (permalink)
Moderator
They are breather filters (not needed if you have the stock intake) that replaced the two stock lines that ran to the intake plumbing. Once the lines were removed, you place the breather filters on the pipes that stick out where the lines were previously connected.
The pipe for the crankcase vent (upper one) has a slightly larger diameter than the second. It is worth pointing this out as you may need to buy a third filter that has a larger rubber grommet to swap if you want to have two of the same filters connected to both pipes.
blueroadster is offline
Old 12-07-2006, 08:54 AM   #23 (permalink)
NewDanger's Avatar
Originally Posted by sickyute
bigger injectors without a new map to support them will just cause u problems...
1. the car might not start
2. it will idle a lot richer or leaner if it did start
3. ur driveability will suffer if u do get it running
cool cool. thanks mucho.
NewDanger is offline
Old 01-05-2007, 09:48 PM   #24 (permalink)
Moderator
Here is a very useful link that provides a wealth of information to consider should you decide to upgrade the fuel feed or return lines:
Click Me
Old 01-05-2007, 11:24 PM   #25 (permalink)
BATANG CITY JAIL's Avatar
^^ did you purchase it..??
BATANG CITY JAIL is offline
Old 01-05-2007, 11:29 PM   #26 (permalink)
MoDiFiEd
sickyute's Avatar
Marvie
i think ajp used 6AN in my return ...
end of the fuel rail is an 8-6 fitting .... so fuel rail is 8AN but hose is a 6 obviously
Shift when it blinks!
sickyute is offline
Old 01-06-2007, 07:19 AM   #27 (permalink)
Moderator
Purchase what? If you mean the fuel return kit, then no.
Old 01-06-2007, 11:03 AM   #28 (permalink)
Nice DIY Blue..
Ben10 is offline
Old 01-13-2007, 01:06 PM   #29 (permalink)
bump...
Old 10-13-2007, 06:08 PM   #30 (permalink)
*Northeast Crew*
CrackThatTec45's Avatar
Crack
subscribed
CrackThatTec45 is offline
Old 10-13-2007, 08:03 PM   #31 (permalink)
280whp, 219tq, GReddy FTW
GalaxyGreySi's Avatar
Phil
Holy thread revival!
If you must whine about my Avatar, do it in this thread:
http://www.8thcivic.com/forums/showthread.php?t=35167
GalaxyGreySi is offline
Old 10-13-2007, 08:05 PM   #32 (permalink)
^^ still have the face..
Old 10-13-2007, 08:40 PM   #33 (permalink)
*Northeast Crew*
Crack
gonna need the reference in the not so distant future
Old 11-04-2007, 04:06 AM   #34 (permalink)
Rems07si's Avatar
Remy
nice job
Rems07si is offline
Old 11-13-2007, 10:47 PM   #35 (permalink)
vtec_marine's Avatar
Rob Danhoff
also need the info. thanks
vtec_marine is offline
Old 11-25-2007, 02:58 PM   #36 (permalink)
squidmaster's Avatar
Jesse
kinda old, but great write up and just what I was looking for!
thanks! +re[
squidmaster is offline
Old 01-07-2008, 01:46 PM   #37 (permalink)
110100100
Adlh29's Avatar
Adam
+ rep
Adlh29 is offline
Old 02-13-2008, 10:08 AM   #38 (permalink)
"Its all about yur "ness"
"Ridge"Racer's Avatar
Justin
thanks for the diy i wanna get an aftermarket fuel rail and this is what i needed to know!
Even sexier than nycclaye's car.
"Ridge"Racer is online now
Old 02-13-2008, 10:20 AM   #39 (permalink)
Moderator
[edit]Don't use breather filters on either of the above mentioned connection points. Instead, run some hose from these connections back to the intake track so that only metered air enters these connections. If you do use breather filters, then a cold start idle will be rough and it will also allow for unmetered air to enter the crankcase which will eventually be sent out of the PCV connection and into the combustion chamber. [/edit]
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/21983-diy-2006-si-turbo-related-fuel-injector-rail-removal-installation-pic-heavy.html
ajp turbo kit instructions? - 8th Generation Honda Civic Forum This thread Refback 12-07-2007 08:41 PM
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Powered by vBulletin® Version 3.7.0
