LinkBack (1) | Thread Tools | Display Modes |
#21 (permalink) |
Nice Write up...
I will save all the instructions for future reference.I have some questions for you. I saw there are two tiny air filters one below the fuel line, the other by the crank cover. What are those for and what's the purpose of changing them to filters?
Thanks A Lot |
#22 (permalink) |
Moderator
They are breather filters (not needed if you have the stock intake) that replaced the two stock lines that ran to the intake plumbing. Once the lines were removed, you place the breather filters on the pipes that stick out where the lines were previously connected.
The pipe for the crankcase vent (upper one) has a slightly larger diameter than the second. It is worth pointing this out as you may need to buy a third filter that has a larger rubber grommet to swap if you want to have two of the same filters connected to both pipes. Last edited by blueroadster; 12-07-2006 at 12:19 AM. |
#23 (permalink) | |
#26 (permalink) |
MoDiFiEd
i think ajp used 6AN in my return ...
end of the fuel rail is an 8-6 fitting .... so fuel rail is 8AN but hose is a 6 obviously
#31 (permalink) |
280whp, 219tq, GReddy FTW
Holy thread revival!
If you must whine about my Avatar, do it in this thread: http://www.8thcivic.com/forums/showthread.php?t=35167 |
#39 (permalink) | |
Moderator
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/21983-diy-2006-si-turbo-related-fuel-injector-rail-removal-installation-pic-heavy.html
| ajp turbo kit instructions? - 8th Generation Honda Civic Forum | This thread | Refback | 12-07-2007 08:41 PM | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
