Oil Change DIY - Page 9 - 8th Generation Honda Civic Forum
LinkBack (6) Thread Tools Display Modes
Old 02-12-2008, 02:47 PM   #161 (permalink)
maiku's Avatar
Maiku (m-ai-k)
Originally Posted by racerex View Post
After many years of removing oil filters on imports and domestics, I still find the freezer storage bag/large zip-lok bag trick to work the best. I've done four oil/filter changes on my Si so far and plastic bag trick has worked like a charm each time.
!#$^ing genius. you will save me many cursing at sideways mounted oil filters from now on.
maiku is offline   Reply With Quote
Old 02-13-2008, 10:21 PM   #162 (permalink)
0720Steve's Avatar
what does anyone make of this...? first oil change, cut apart factory filter and saw this....
2,6xx miles
0720Steve is online now   Reply With Quote
Old 02-14-2008, 09:53 PM   #163 (permalink)
corza's Avatar
It's a good thing we use filters to remove that stuff that somehow gets into the engine. Perhaps we are better off not knowing.
corza is offline   Reply With Quote
Old 02-14-2008, 09:55 PM   #164 (permalink)
0720Steve's Avatar
i didn't order sprinkles with my si
Old 02-17-2008, 01:14 PM   #165 (permalink)
jjackowski's Avatar
Jeff Jackowski
Maybe the sprinkles got there from the process of taking apart the filter. Could be some of the outer shell of the filter. Its a nice hope, anyway.
jjackowski is offline   Reply With Quote
Old 02-17-2008, 01:36 PM   #166 (permalink)
Zeuceone's Avatar
cant be that. the engine would have to be running for them to be sucked into the filter. maybe the internals had numbers onthem..
Old 02-20-2008, 01:38 PM   #167 (permalink)
Originally Posted by snpgotyou View Post
where do you dispose the oil??
most auto parts stores like pepboys, autozone, walmart (with a service center) will take your used oil for no charge just call one near you
Young Gunna is offline   Reply With Quote
Old 02-20-2008, 08:06 PM   #168 (permalink)
fishermoe14's Avatar
R18 FTMFW
we just chuck our oil down the sewer drain... is that bad??
jk jk i kid..
we put in milk jugs and let the recyling comp take it away..
fishermoe14 is offline   Reply With Quote
Old 02-20-2008, 08:59 PM   #169 (permalink)
James N.
man changing oil on the new civic si looks a lot easier than
on the dc5...woot woot
vit0 is offline   Reply With Quote
Old 02-20-2008, 09:01 PM   #170 (permalink)
0720Steve's Avatar
it isn't that bad, but my accord and my girlfriends fit are easy compared to this....
can someone tell me about my sprinkles ^^^^^^
Old 02-20-2008, 09:07 PM   #171 (permalink)
James N.
dude it looks like stuff from the filter the green stuff isnt the outside of the filter green
and isn't this your first oil change ever on the car? it could be the metal parts in the engine coming from the factory thats why you're supposed to have the first oil change pretty early because of ^^^^^^^^^^^^^ the metal floating around in the engine
am i correct?
Old 02-20-2008, 09:09 PM   #172 (permalink)
0720Steve's Avatar
am i correct?
no, not quite. they generally tell you to run the oil till 15% and that usually is 5-8k for most. i did it before 3 because my car was feeling funny, the oil appeared super dark, and then i find these....
Old 02-20-2008, 09:19 PM   #173 (permalink)
Justin
so I read that someone suggested drilling the filter before taking it off so that the oil in it could drip out, good idea? say drilling down in the bottom of the filter so it can drain into a ziploc bag? yes? no? also, RP, best oil by general consencus?
PFCCarvajal is offline   Reply With Quote
Old 02-20-2008, 09:21 PM   #174 (permalink)
0720Steve's Avatar
not necessary at all. i used one of those caps/wrench, fit on a socket, to losen it, then i put the bag on and started twisting, used a gallon sized zip lock....worked fine....almost no drips.
Old 02-20-2008, 09:26 PM   #175 (permalink)
Justin
and whatever did drip was easily wiped up with a papertowel correct? also, I've read multiple sides of how much of your passenger side to expose, anybody got what works best as far as being able to get to the filter in the event that oil does get all over the place? it seems like just taking off the wheel and fender lining works, but is it as easy as say taking off the front bumper?
Old 02-20-2008, 09:29 PM   #176 (permalink)
0720Steve's Avatar
passenger wheel yes, lining, not necessary, i just laid down and was able to reach up in there....it's a little odd, but totally doable....and yes, what little bitty drip there was is easily cleaned up with a shop towel or kitty litter.
Old 02-20-2008, 09:32 PM   #177 (permalink)
Justin
right on, so sorry to be a bother to anybody, but the total parts list would be 5 qts of 5w-30 synth, a new filter, new crush washer (still kinda in the dark on this one), and what else? it doesn't seem like much work and I can't wait to get my oilchange destiny into my own hands
Old 02-20-2008, 09:34 PM   #178 (permalink)
0720Steve's Avatar
well that's all you'll need for your car.....don't forget the funnel and oil drain pan jug thing.
about the crush washer thing...i have reused them many times before without a problem, but they do say to do it each time...but if you have a torque wrench you won't be doing much damage to the washer each time and can get a couple uses out of each one.
i usually go by the honda parts counter and the guy gives me a few for free when i ask to buy some. he's a cool dude.
hope this helps.
Old 02-20-2008, 09:36 PM   #179 (permalink)
Justin
so you would suggest replacing the crush washer say...every three or four changes?, thanks for answering all the questions
Old 02-20-2008, 09:36 PM   #180 (permalink)
imfrom7thGEN's Avatar
yes thats all you need
here is a link to what a crush washer looks like if your not sure...also some good deals on filters and stuff Honda Civic Accessories - Maintenance Items
imfrom7thGEN is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/18649-oil-change-diy.html
Oil change question... - 8th Generation Honda Civic Forum This thread Refback 01-16-2008 03:51 PM
Oil Change DIY - 8th Generation Honda Civic Forum This thread Refback 01-10-2008 12:39 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-09-2008 12:23 PM
Oil Change DIY - Page 2 - 8th Generation Honda Civic Forum This thread Refback 12-27-2007 07:55 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 12-21-2007 05:45 PM
Oil change DIY? - 8th Generation Honda Civic Forum Post #0 Refback 12-05-2007 03:25 PM
Oil Change Info. jc21 Mechanical Problems & Technical Chat 42 06-14-2010 09:30 AM
Oil Life Elmacho Civic SI 33 01-05-2009 09:36 PM
Recent oil change with lab results ChristopherSi Garage 12 11-03-2006 01:43 AM
Oil change DIY? letsgoflyers81 Do It Yourself Articles 21 10-11-2006 11:07 AM
