Oil Change DIY - Page 8 - 8th Generation Honda Civic Forum
LinkBack (6) Thread Tools Display Modes
Old 11-20-2007, 01:06 PM   1 links from elsewhere to this Post. Click to view. #141 (permalink)
fishermoe14's Avatar
R18 FTMFW
ok the first one is the hole that is right by the wheel...
the second pic shows the hole that is more near the back...
first you stick your oil wrench in the first hole and get it on the filter... then move back a little bit and put your other arm in the rear hole... then it will be a piece of cake to take out...
srry for craptastic cell phone pics
fishermoe14 is offline   Reply With Quote
Old 11-24-2007, 02:21 PM   #142 (permalink)
Nice write up I'll be using these for my first oil change Thanks!
chriscj99 is offline   Reply With Quote
Old 12-10-2007, 10:38 PM   #143 (permalink)
Often the oil drain bolt & oil filter will be over torquedc from the factory. If you have the right size socket of decent quality it should come right off. At this point I'd suggest that you leave it alone & go some where and have them get it loose for you.
eddyo is offline   Reply With Quote
Old 12-29-2007, 04:55 AM   #144 (permalink)
'08 Civic Si
Considering regular oil is $3 a litre in canada and the filter is $5 or more I think I might just get the dealer to do it for $35 and skip the mess! I have an Si.
rob76 is offline   Reply With Quote
Old 12-31-2007, 01:35 AM   #145 (permalink)
TexasK20Z's Avatar
the ONLY oil filter wrench I will ever own is one like this:
You can buy them at autozone for less than $10 and you will NEVER have to worry about not being able to get a fliter off again!!!
TexasK20Z is offline   Reply With Quote
Old 12-31-2007, 01:54 AM   #146 (permalink)
'08 Civic Si
I've got something similar but it has teeth that bite into the filter.
Old 01-09-2008, 09:01 PM   #147 (permalink)
nice! thats what i got at pep boys and it has gotten the filter off. now it did take a little muscle to take off for my initial oil change but its good to go now!
SI_Smiley is offline   Reply With Quote
Old 01-15-2008, 11:42 PM   #148 (permalink)
Originally Posted by Harry View Post
Oh...almost forgot...how do we know what size to buy for the crush ring/washer thing?
part# 94109-14000 - it's a 14mm
twsi is offline   Reply With Quote
Old 01-23-2008, 05:54 PM   #149 (permalink)
Originally Posted by projek7 View Post
Just did my first oil change tonight and all I have to say is... WHO EVER PUT THE OIL FILTER ON AT FACTORY, SCREW YOU A$$HOLE!!!!! I know it was going to be a pain reading all the posts but jeeeez, it took me forever to get that damn oil filter off on my Si.
yeah same problem with mine. but i came to the conclusion that the factory machine puts it on. that might be why!
luv2redline is offline   Reply With Quote
Old 01-23-2008, 05:58 PM   #150 (permalink)
on mine it takes exactly 4 1/2 qrts! alot of people say 5 to 5 1/2 but thats kinda dangerous. personally on my si it tops the full mark with 4 1/2!
Old 01-23-2008, 06:14 PM   #151 (permalink)
Si_Sedan_Fan's Avatar
If you dont mind regular oil going to the dealer isnt bad at all. My dealer charges 24.99. Now if you want to use Mobile 1 or something like it your going to spend about 32 bucks just for the oil with the filter your up to 40 bucks and thats without labor.
Si_Sedan_Fan is offline   Reply With Quote
Old 01-23-2008, 08:56 PM   #152 (permalink)
8 pages for an oil change DIY?
deviousin10tion is offline   Reply With Quote
Old 01-23-2008, 09:25 PM   #153 (permalink)
where do you dispose the oil??
snpgotyou is offline   Reply With Quote
Old 01-23-2008, 09:32 PM   #154 (permalink)
I just pour mine down the sewar drain in the street. Just make sure nobody is looking. I think you can get fined or something.
Just kidding of course.
Old 01-23-2008, 10:47 PM   #155 (permalink)
Seemund's Avatar
Just bought a M1 110 FILTER. I'm going to buy 5qtrs of Mobil 1 5-30W tomorrow @ WalMart..
Checked the prices today..
Walmart: $5.79
AutoZone: $6.79
C.A.P: $5.99
Walmart UHULLLLLLL
Seemund is offline   Reply With Quote
Old 01-27-2008, 02:42 PM   #156 (permalink)
Walmart: $5.79
AutoZone: $6.79
C.A.P: $5.99
Walmart UHULLLLLLL
dam dude were they on rollback?
they are $10.79 here in socal even @ walmart.
candell is offline   Reply With Quote
Old 01-27-2008, 08:14 PM   #157 (permalink)
Seemund's Avatar
I was talking about the oil prices :P
Filter was like $8-9
Old 01-27-2008, 08:31 PM   #158 (permalink)
Jason
people, if u are struggling to get the drain bolt and oil filter off, ur putting it way too tight. both should be placed on nice and snug, to where it should not take much effort to loosen both, but at the same time dont put it on so lightly to where it'll unscrew itself and fall off.
Old 02-10-2008, 10:36 PM   #159 (permalink)
This did absolutely nothing for my stock filter other than turn uselessly. They couldn't even make the socket hole deep enough to properly connect the 3/8th socket wrench. I got my 6$ back on this after complaining. A piece of crap.
Affect is offline   Reply With Quote
Old 02-11-2008, 09:37 PM   #160 (permalink)
the one i purchased is similar in theory but it actually has 3 prongs/hooks that tighten as u turn the ratchet. it works like a charm but ofcourse the first time is a bit hard. u have to put some elbow grease into it and it will come right off.
for some reason when i commented on his earlier post it showed the tool i used and then outa nowhere the image changed. site where he got it from prob changed or he changed the pic.
LinkBack to this Thread: http://www.8thcivic.com/forums/engine/18649-oil-change-diy.html
Oil change question... - 8th Generation Honda Civic Forum This thread Refback 01-16-2008 03:51 PM
Oil Change DIY - 8th Generation Honda Civic Forum This thread Refback 01-10-2008 12:39 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-09-2008 12:23 PM
Oil Change DIY - Page 2 - 8th Generation Honda Civic Forum This thread Refback 12-27-2007 07:55 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 12-21-2007 05:45 PM
Oil change DIY? - 8th Generation Honda Civic Forum Post #0 Refback 12-05-2007 03:25 PM
Oil Change Info. jc21 Mechanical Problems & Technical Chat 42 06-14-2010 09:30 AM
Oil Life Elmacho Civic SI 33 01-05-2009 09:36 PM
Recent oil change with lab results ChristopherSi Garage 12 11-03-2006 01:43 AM
Oil change DIY? letsgoflyers81 Do It Yourself Articles 21 10-11-2006 11:07 AM
